Question about Tascam DP01 All-In-One Recording Package Microphone
Don't know how to actually record
How do you actually record a track i'm trying to used my dpo1 to record from my mixer to make mutitracks mixes from my dj setup, I can here the sound comming out the dp01 but can't record it, what am I doing wrong?
    Novelist:
  • 189 Answers
To record you need to first assign your input to a track, then arm the track for recording, and then press play + record at the same time.
1. So you would patch you mixer's output into an input on your DP01 (say input A). You can run some audio to set the level with the input level knob (located next to input A on the front panel).
2. Then to assign that input to a track simply press and hold the 'input A' button and then press the 'rec' button of the track you with to record on. The 'rec' button will flash rapidly to indicate that the input is assigned to the track.
(To assign the input to a different track you have to clear the input assignment from the first track and assign the input to a new track. To clear an assignment press the input assign key, A in this case, and the track it's assigned to will flash its 'rec' button. Hold down the input assign key and then press the flashing 'rec' button. The button will stop flashing and the input can then be assigned to another track by following step 2 again).
3. Next, to arm the track for recording simply press the 'rec' button for that track. The 'rec' button with flash slowly.
4. To begin recording press play + record together in the transport section and the 'rec' light for the armed track will stop flashing and light steadily. Press 'stop' to end recording.
This should get you started. The operation of the DP01 is actually pretty intuitive once you've gone through it a couple of times (which is one of the real strengths of the unit). You'll be multitracking like an expert in no time.
Cheers,
bd.
Posted on Nov 20, 2008
HOW DO I RECORD MY VOICE ON THE CTK-900 CASIO KEYBOARD?
Not according to the manual. It was not made that simple.
However, there are a few ways you can produce a recording of the music with your voice. Either mixing with the PC or Mac sound program, or using the output of the keyboard into a suitable mixer with preamp so you can get your levels correct- then record the output of the mixer to computer, or to tape.
Audacity is a wonderful little Sourceforge program to consider using along with the suite of programs and widgets Casio includes with the 900.
Apr 06, 2012 | Casio CTK810 61 Key Keyboard
I have a DP2 Tascam 8 track recorder. Can I come out of my 16 channel mixer into my recorder and record my whole band?
The Tascam DP-02 can only record two tracks at a time.
You will have to mix "on-the-fly" and record the master out, or record each instrument seperately, and just record the drums as a stereo mix.
Feb 13, 2010 | Tascam Starter Pack for 4-Track Cassette...
Using the USB connection to send the stereo mix to a computer
You have to insert a track into Reaper "arm" it. If you can't figure it out, I'd suggest posting in the Peavey forums.
May 14, 2009 | Peavey 32fx USB 32 Channel Mixer
No sound in edit view
Well, the settings in edit view and mutitrack view are not, unfortunately, the same... you can set them the same, but it's not that way by default.
I haven't used 1.5 in a while, but my initial guess is that one of these are true:
  1. You've muted audio play-back on the edit view
  2. You've disabled monitoring on edit view
  3. The playback source in edit view is set to the wrong hardware.
  4. I believe there was a playback volume controle even in 1.5.  If so, you could have actually turned the volume all the way down for playback..
If I get a chance later this afternoon, I might try reinstalling 1.5 and seeing if I can get figure it out on that version.
Post back with your results so far.
Also, it'll be helpful to know what version of Windows you're using.  In Windows Vista, there's a volume mixer where you can control the volume for any open applications as well as Windows sounds - different than the typical mixer setup in XP and prior.
Jan 06, 2009 | Adobe Audition 1.5
I need to know how to increase track external recording.
download a freeware program called "audacity" and use that to cut toe audio file up into seperate tracks.
Dec 24, 2008 | JVC XL-R5010 4-Disc CD Recorder
Mini disc recorder question
Just use the first two tracks, one for left and one for right and use the PAN pots to adjust the stereo positioning. Just run the 'tape out' or 'line out' or 'aux out' of the mixer to the REC "IN" on the MiniDisc recorder; hit "record" then the "play" button to start it. Make sure your input selector switch is on ANALOG and not DIGITAL or OPTICAL. Let me know how it works out for you. Okay? Thanks
Dec 01, 2008 | Tascam MD-350 Advanced MiniDisc Recorder
DJ EQUIPMENT
Lot of possibilities.
The DP-01 is like a mixer with built-in recording capabilies. You could plug your tunrntables into your DP-01 inputs, assign the inputs to tracks(channels) on the DP-01, and then output those tracks to two channels on your mixer (which would be connected to your PA.
Alternatively, you could plug the outs from your mixer into the DP-01 either by routing individual channels from the mixer into the DP-01 inputs, or outputting the mix into a single track (or into two tracks in stereo on your DP-01). Just assign the DP-01 inputs as usual to the tracks you want to record onto.
Those are just a couple of basic ideas. You could also route a DP-01 track (or the whole mix) back out the DP-01 send loop and through some external processors and then back to tracks on your DP-01, or you could do this through the mixer and then record the final result on the DP-01.
Jun 28, 2008 | Tascam DP01 All-In-One Recording Package...
Taking recordings from mixing desk
As the Fastrack can only receive one audio signal at a time you would have to record each track seperatly into Pro Tools.
I'm guessing your mixer is a multitrack recorder.
Solo track 1 on the multitracker and playback from there into the Fastrack, with track 1 on Pro Tools set to record. Repeat this for each or your tracks on the multitracker.
When you've finished you'll need to align all the tracks in Pro Tools so they all playback in time with each other.
Jun 25, 2008 | M-Audio Fast Track USB (FASTTRACK) Audio...
Recording live d.j. mixes ,
Audacity and Krystal (free windows based programs)
What about an LE version of Cubase or Sonar (little hard to learn if your just want to record something light and not edit).
May 28, 2008 | M-Audio Fast Track Pro External Sound...
XENYX 1222FX Mixer
I've had the same problem. It just is like the tracks mix up with each other. It's pretty irritation when you come to the mixing process. You just can't mix track where the first one for example actually is some song. But you also got some guitar from track 2 on it and the guitar track has got track 3 and 4 on it and so on and so on.
How do you fix that problem
May 22, 2008 | Behringer Dual Engine 24 Bit Multieffects...
Tascam DP01 All-In-One Recording Package Microphone Logo
150 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
John
John
Michial Gueffroy
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
