Front Audio Video inputs not working
Trying to use TV as a Karaoke Monitor. Signal works fine on my newer TV, but not when video goes into the front yellow, and the audio in white.Went through all the channels, and nothing on the screen except regular programs. Regular sound, but no Karaoke music. How can I change program to the front A/V Signal?
    Scholar:
  • 188 Answers
What model TV is it?
it may be you need to change the input to video 1 or video 2 to get those front jacks to work. if there is a TV/Video button on the front you should be set. If not you may need the remote control. Sometimes changing the channel to below channel 1 will give you that option.
Posted on Nov 21, 2008
How do yu connect a desktop tower to this tv
First, we need to look at how to make your PC send the correct signal. As a general rule, I can say that you will likely need some sort of adapter in your PC in order to send a signal to the TV. This is typically referred to as a "tuner card." It converts PC output to the input that a TV can understand. I don't normally recommend Wikipedia, but this article does tell you the basics of how to get signals from a TV to a PC:
TV tuner card Wikipedia the free encyclopedia
Then, it would be helpful to know what brand, model #, etc. "this" TV is.
Mar 20, 2015 | Computers & Internet
Ls-180 x factor karaoke mic
A lot of newer tv you'll have to change the input of the tv to receive the signal. Most should be labeled. If it's red and yellow connectors it will be a composite connection. Some tv companies require a signal to be present before they will switch or even show the different inputs
Apr 22, 2014 | Audio Players & Recorders
When i connect my pc to my monitor (LG w2353v-pf) via a HDMI cable the monitor tells me to check signal cable. I know my HDMI cable is fine since i have tested it on my TV. also i know that my computer...
Hi raposo69 ,
I see that you are having an error check signal cable.
Have you tried selecting the correct Input for the LG LCD monitor?
make sure that the Correct Input is selected properly to be able to detect the signal from the HDMI cable that you are using.
The audio will not confuse the video on an HDMI Video will be detected as long as the Input on the LCD monitor is selected.
Audio on the HDMI will only work if the HDMI driver is provided like on a desktop computer you will need to get the driver for the HDMI for Audio and video to come out using an HDMI cable but never will audio conflict to the HDMI video output.
I hope this hepls.
Have a nice day,
mvincentc
Apr 13, 2011 | LG W2353V-PF 23' LCD Monitor
I am trying to connect a DVD player with analog composite video connection with output to HDMI output. Audio works fine, however no video signal detected. Connected to front AUX connection and verified...
I would like to prove the video connector from the DVD to Aux (or wherever) works without upconversion to HDMI. Connect your monitor to the receiver's composite Out jack and see what happens with the DVD video.
Read and interpret the discussion on pages 22 and 100 very carefully to make sure nothing else is assigned to whichever video input path you choose for the DVD. Then try it somewhere else to see if that changes anything.
Jan 23, 2010 | Onkyo TX-SR606 Receiver
Trying to hook my Wii up using the AV audio Jacks
Connect the Wii to your television. Then connect the variable audio output from the TV to the audio in on the monitor section of the receiver. Then use the TV/SAT input selection on the receiver and dolby prologic 2 as your sound mode.
Dec 23, 2009 | Sony STR-DE575 Receiver
Won't play dvd
we have two options in this case:
  1. the receiver is your main brain:
you hook up the dvd in the receiver and the tv works as a monitor (the receiver has to have video output to monitor)
2. anyone works at its own:
in this configuration the DVD (video) is hook up into the tv (any video tv input works fine) and audio goes to the receiver in any audio input.
Apr 14, 2009 | Televison & Video
I have the Rx-V661 and I just got the WII. I input the WII into the Video AUX on the front panel and pressed the aux button on the remote and nothign happened.
Just a thought, but, how do you have your TV/Monitor hooked up to the Yamaha unit? If your only connection between the receiver the and the TV/Monitor is an HDMI cable, and you are plugging your WII into the front v-aux jack using composite video, the receiver will have no way to send the video signal to the TV/Monitor. The receiver upconverts all composite video and S-video signals to component video signals. This means that if you only have an HDMI connection between the receiver and the TV/Monitor, you will also need to establish a second, component video connection between the receiver and TV/Monitor to handle the upconverted WII video signal. You will probably also need to switch your TV/Monitor to use that input when you are using the WII.
Of course, if you already knew this and have it set up that way, this answer won't help you at all!
Dec 25, 2008 | Yamaha RX-V661 Receiver
Connecting vcr to tv
Find Video & Audio Out pins at back of Combo player. This is output signal which will be connected at Video & Audio Input at front of TV. Watch out video pin will go to video input. Now select AV input of TV by remote. Usually its AV-4.
Have fun, or need more info, let me know the out comes.
Oct 22, 2008 | RCA VR546 S-VHS VCR
Televison & Video Logo
254 people viewed this question
Top Televison & Video Experts
