Question about Miele Novotronic W1918A Front Load Washer
Intermittent hot water valve not opening
Over the past several months, I have noticed the "check water inflow" light flashing and the washer door locked at the apparent end of a cycle. Initial testing proves up that it only happens at the end of a hot water cycle; cold or warm seem to work fine. Manual only suggests to clean both hose filters. Have done so twice now; they're fine. Ordered & replaced the hot water valve; no change. Went through all the diagnostics w/ Miele tech on the phone, and it passed everything OK -- all valves opened and closed as requested. Observing the machine through a whole wash cycle this morning, it appears that sometimes the valve does not even receive a command to open at the start of a rinse cycle (or both old and new valves intermittently fail to open? -- seems unlikely to me), after which the machine times out trying to fill up, the "check water inlet" light starts flashing, and the cycle jumps to the end w/ the door locked. (That can be fixed by choosing "fine rinse", after which everything is OK.Anyone have any ideas about what to check next? Thanks in advance!
  • douglasa2 Dec 17, 2007
    This is the same issue I am experiencing on my 9 year old front loading Novotronic W1930.
    Exactly the same. I wonder if one of the controllers has failed in the same manner ?
Douglasa2,
We're having the same problem. Did you have any luck replacing the right electronic valve on the cold water input connection?
WarrenF
Posted on Dec 31, 2007
Cold Water Pressure is not an issue. I took the top metal piece off and can see the whole washer - I put my hands on the internal hoses and I can feel there is absolutely no cold water flow in the machine. My guess is the electronic valve right on the cold water input connection.
Posted on Dec 17, 2007
  • appin Oct 26, 2010
    The reason the final rinse works is that that uses a different solenoid valve in order to allow the use of fabric softener in the final rinse.
    The question is whether the other solenoids are getting a voltage to them at the appropriate times. Check at the start of the main wash program to see whether any of the wires to the solenoids are carrying mains voltage. If so, it should be possible to either get a replacement or switch another solenoid to do the task of the failed one.
    President:
  • 1,462 Answers
Problem may be low water pressure. try putting in a y-piece so cold water is supplied to both valves. only effect will be that wash cycle will be a bit longer
Posted on Mar 31, 2007
Cold water trickling into washer - what would cause this?
CHECK AND SEE IF THERE ARE SCREENS AT THE WATER VALVE IT MAY BE CLOGGED THERE
Jun 18, 2014 | Frigidaire CWS3600AS Top Load Washer
That is what I wondering. I leave the door open and have noticed there will be water in my washing machine. It wasn't there when I removed my laundry. It doesn't happen all the time. I can't find a...
Hi you have a faulty water valve that is allowing water to weep past. if the machine is hot and cold fill. turn off the hot water tap. the machine will still work with cold water only. if it stops the weeping through you know the hot valve is faulty if it does not the cold valve is faulty. just replace whichever is the culprit.
Jan 20, 2011 | Washing Machines
After instillation, the washer runs several times-then we noticed my hot water heater is shutting the pilot light off. Back pressure possibly on the Hot water side? Was purchased as floor model and N
what kind of water heater do you have?? as far as the washer it has a mxing valve inside the unit that mixes the hot and cold water to get the proper tempreture, write me gary1121@aol.com let me know about the water heatrer,, that is what you are asking about
May 19, 2009 | GE Profile WPRE6100G Top Load Washer
Fisher Paykel GWL11 Cold Water Not Flowing
you can swap the hot and cold valves over and see if this fixes the problem as it sound like your cold valve is faulty but not the hot valve.
Cheers
Mar 24, 2009 | Fisher and Paykel GWL11 Top Load Washer
No water inflow
make sure door is closed...also check water input hose and when u turn on the machine the lights are on telling you machine is ready,,,,,if this does not solve the problem call LG customer help and service
Mar 07, 2009 | LG WM-2277HW Front Load Washer
Water inflow even after the cycle is complete
Seems to me that you having problem with water valve in this machine. Some solenoid on water valve is stock and water entering the washer even power is off.Water valve Part # 8181694.
Valve located on the top of the washer. Any questions let me know.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
Dec 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore HE4T Washer Leak
there are 2 possible causes.
either
inlet valve leaking - turn water off and if water fill stops, it indicates valve leaking
valve being powered when machine off. this is very unlikely but to check, disconnect washer and see if problem stops
also, if drain is plumbed into a spigot on the sink trap, every time you empty the sink, some of the water will flow into the machine. to cure this, take the drain hose as high as possible under the sink in a swan neck
Oct 20, 2008 | Kenmore Elite 45986 Front Load Washer
Miele Novotronic W1918A Front Load Washer Logo
362 people viewed this question
Top Miele Washing Machines Experts
Marvin
Marvin
shaun taylor
michael_t919
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
