I hit something on it any accidentally changed the clock from 12 hour to 24 hour format, i am unsure of how to switch it back to the 12 hour format...
SOURCE: i cant set the clock on the tdk iwave to 12 hour format
hi just wondering if you figured it out considering this was in 2009.. i cant figure it out either
SOURCE: Sharper Image S1785 Clock Settings
When setting-up the time (by pushing the "mode" button), the alarm time set comes up first, followed by the time set.
When setting the proper hour in this mode, simply continue through the military "24 hour" cycle and the second cycle of 24 hours will be in the 12 hour format.
Continue through and finish the mode set-up function and your up and running. --
SOURCE: how do you set the clock for 12 hr time, not 24 hour ??
On most clock radios, there is a Time button. Usually, just hold it down while adjusting the Hr. or Min. I have not seen too many clock radios that do not use that kind of setup.
SOURCE: AWRC-1P How do I the clock from 24 hour to 12 hour
To set AM/PM (12 hour) or Military (24 hour) time - With the system off, hold down Alarm Setup and press On/Off to switch between AM/PM (12 hour) and you're done .
- Press the On/Off button once to turn your Wave radio off.
Press and hold Clock Set, and then press On/Off to switch between AM/PM (12 HR) or military (24 HR) formats
