Question about Yamaha DV-C6480 Multi-disc DVD Player
Disc tray is stuck open
The disc tray will not close and is stuck half way open. I tried pressing the open and changed disc buttons both on the remote and the player itself. No luck.
4 Suggested Answers
  • 236 Answers
SOURCE: Tray opens but won't close or closes but doesnt play
deferctive laser lense already. try to replace if more economical than buying new unit
Posted on Mar 31, 2008
SOURCE: Yamaha dvd player S530 disc tray no open, Outer
I downloaded a service manual for this unit. It showed where the manual release mechanism was. Released the cd stray, examamined the mechanism and found nothing. Added a little lubrication to some of the moving parts. Reassembled, and everthing now working fine.
Posted on Dec 20, 2009
  • 1285 Answers
SOURCE: DVD Tray stuck open
the tray is not catching (underneath the tray is ridges). unplug the dvd player from the wall for 5-10 min...plug back up and give the tray a lite push while tapping the open/close button
Posted on Jul 17, 2010
SOURCE: My DVD tray on my Yamaha DV C6480 (it holds 5
This happens to us all the time. Here is the note I keep on how to fix it quickly:
When tray gets messed up, the drive wheel (with pegs that interlock with pegs on the tray) needs to be such that the tray slides in and out freely. Push tray all the way in. Turn on.
Hope that gives a hint.
Posted on Jan 18, 2011
0 characters
1 Points
What is the model number of your DVD player? You may try power resetting the unit and check if it helps. To power reset, turn OFF the DVD player and unplug the power cord from the electrical outlet for 30 seconds. Plug the power cord back into the electrical outlet and turn the player ON. Attempt to open the disc tray.
Depending on the model number of your DVD player, simultaneously press the POWER + STOP + EJECT buttons. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons.
NOTE: This step may not apply to all models as DISC1 is not available on all DVD players.
If this does not work and if the DVD player has DISPLAY and PREV buttons, press and hold the DISPLAY+PREV buttons for two seconds to unlock the drawer.
This issue may occur if the disc is damaged or if the disc was not inserted properly into the Blu-ray DiscĀ® player. Follow the steps below to open the disc tray and eject the disc.
  1. Turn off the Blu-ray Disc player.
  2. Disconnect the power cord (mains lead) or AC adapter.
  3. Allow the disc player to remain without power for 30 seconds.
  4. While pressing the OPEN/CLOSE button located on the front of the disc player, reconnect the power cord.
    IMPORTANT: For some Blu-ray Disc Home Theater models it is necessary to press and hold the OPEN/CLOSE andPLAY buttons simultaneously, then reconnect the power cord.
    NOTE: This step may require the assistance of a second person.
  5. After reconnecting the power cord, when the tray opens, release the OPEN/CLOSE button.
  6. Remove the disc.
  7. If necessary, disconnect and then reconnect the power cord to recover the player.
Aug 24, 2015 | DVD & Blu-Ray Players
I put a disk in and there was already one in now it wont eject
The disc tray does not eject when the OPEN/CLOSE button is pressed. Solution
sp.gif sp.gif Follow the steps below to troubleshoot this issue.
    IMPORTANT: The disc tray will not open while a disc is loading; this is normal operation. If this is the case, wait until the disc is finished loading before pressing the OPEN/CLOSE button to open the disc tray.
  1. Make sure the disc tray is not locked; if necessary,
  2. Perform a power reset.
    1. Press and hold the POWER button for 10 seconds until the BD player turns off.
    2. After the BD player turns off, press the POWER button again to turn it back on.
  3. Attempt to open the disc tray by pressing the OPEN/CLOSE button on the front of the BD player.
  4. If the disc tray still does not open and a disc is stuck inside, follow the steps below to force the disc tray to eject:
    1. Turn off the BD player.
    2. Turn the BD player back on.
    3. Immediately after POWER ON is displayed, press the STOP button on the front of the player. IMPORTANT: Only use the STOP button on the front of the BD player. The remote control cannot be used for this operation.
      • The disc tray should eject and the BD player will turn off. If it does not eject, repeat steps A-C.
      • It may be necessary to press the STOP button in step C two or three times.
If the issue is still unresolved, service may be required
Sep 15, 2011 | Sony BDP-S300 Blu-Ray Disc Player
How to change toshiba sd-412v region 1 to free region?thanks
Hi friend. Try this:
Press the power button on the Toshiba DVD player remote. Press the "Open/Close" button to eject the disc tray. Remove any disc that might be on the tray before proceeding.
Press the following keys on the remote in this order: 2,4,0,3,9,6,0.
Press the "9" key on the remote.
Press the "Open/Close" button to close the disc tray. Press the power button to turn the Toshiba DVD player on.
Hope it works.
Jun 16, 2011 | Toshiba DVD & Blu-Ray Players
Hi, the dvd on my recorder stayes ejected? It will close but then will eject straight away? What can I do? Cheers.
The fault is not from the disc, it is from the player.
The disc tray is actually malfunctioning. Which is as a result of a fault on the mechanism that is controlling the opening and closing of the disc tray.
Another fault might be that the button that controls the disc tray might be stuck.
test if it is the button.
  1. Unplug the player from the power source,
  2. plug it back,
  3. turn it on,
if it opens without you pressing the open button, then the fault is from the button.
check it for any irregularity.
  1. get the appropriate screwdriver,
  2. open the cover of the player,
  3. carefully force the front control panel open from the sides,
  4. then check for any damages,
  5. change the open button and it will be okay again.
test if it is the disc tray
press the open button, if it opens closes continuously.
then there is a problem with the mechanism that controls the open and close of the disc tray.
to fix this,
  1. Get the appropriate screwdriver,
  2. open the back cover of the player,
  3. look to the left side of the player and you will see a mechanism that controls the tray,
  4. change the mechanism with a new one.
after doing that, the player will be in good condition again.
take care
Jun 18, 2010 | LG RH1777 DVD Recorder
My coby-514 dvd won't open up when the open/close
disc is stuck, remove cover screws and carefully remove the disc, do not force the unit, once the disc is out use the remote to close the unit, then use remote to open and use a different disc press play and hopefully it will work, try to avoid not using the remote for all functions,including open-close. do not push tray in manually.
Dec 10, 2009 | Coby DVD-514 DVD Player
Disc table does not open or close - stuck open
Hello the unit is out of timing now, it will have to be taken apart and retimed. You have skipped some gear tracks and the unit will not close until the Tray is realigned. Try hitting the eject button so the tray comes all the way out then pull on it gently to see if it realigns it self. When it trys to go back in it is hitting the clamper because the tray has not reached home and the clamper that gasps the disk is closing before it has a chance to return home.
Nov 30, 2009 | Pioneer BDP-95FD Blu-Ray Player
I would like to change regions on my portable Durabrand DVD player model PDV-722
Alright, just follow these steps and let me know if you have any problems or questions
  1. Power and switch on the Durabrand DVD player.
  2. Open the DVD disc tray tray or lid.
  3. Press Stop.
  4. Press 3 - 5 - 9 - 7 (3597 in sequence). Can be done on remote control.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control
  6. Press OK.
  7. Close the disc tray and press Standby on the DVD player front
Dec 19, 2008 | DVD & Blu-Ray Players
I need to change region code for goodmans GDVD200CDGM
Region Code Hack: GOODMANS GDVD-200-CDG:
To convert this player to Multi-Region
1. Open the disc tray.
2. Place a region 1 disc in the tray, but don't close it.
3. Press the buttons 0, 1, 2 and then 3 on your remote control in order, one at a time.
4. Press the play button on either your remote or the player.
To return this player back to Region 2 only and its factory default settings
2. Press the Zoom button on your remote control.
3. Press the Retu To return this player to Region 2 only (alternative method) rn button on your remote control.
4. Your player should now go into Standby mode.
5. Press the Power button on your remote control.
i). Open the disc tray
ii). Place a region 2 disc in the tray, but don't close it
iii). Press the buttons Return and then Play on your remote control in order, one at a time
Aug 21, 2008 | Goodmans DVD & Blu-Ray Players
Region change to multi on govideo #DV1140
This might help gurantees...... take care...
GoVideo D2730
  1. Power up
  2. Wait for "No Disc" to bei displayed
  3. Immediately enter 7, 3, 8, 7, 9 (the last figure is for the region, 9 = multi-region)
GoVideo DV2150
  2. Press 0, 5, 2, 0
  3. Press UP, DOWN, LEFT, RIGHT
  4. Press the button for the desired RC (0 = codefree)
  5. Close the disc tray
GoVideo DVP750 / DVP950
  2. Press 0, 1, 0, 6, 0
  3. Press the button for the desired RC (0 = codefree)
  4. Close the disc tray
GoVideo DVP850 / DVP853 / DVP855 / DVP860 / DVP865
  2. Press SETUP
  3. Highlight "Custom"
  4. Press 3, 3, 3, 3
  5. A menu should pop up (Secret)
  6. Select region (0 = region-free)
  7. Press ENTER
  8. Press SETUP
  9. Close the disc tray
GoVideo DVP1100 / DVP1165
  1. Turn on the player (without a disc inserted)
  2. Press PLAY 8x
  3. Press 0, 1, 0, 6, 0
  4. 9 should be displayed
  5. Press 9
GoVideo DVR4200 / DVR4250
  1. Change to dvd mode
  2. Insert a DVD and play it
  3. Press STOP
  4. Press PAUSE
  5. Press 3, 1, 4, 1, 5, 9
  6. Enter the region you want (0 = codefree)
  7. Press PAUSE
GoVideo R6640 / R6750
  1. region-free out of the box
GoVideo R6740
  1. Press SETUP
  2. Highlight "Exit"
  3. Enter 2, 9, 6, 0
  4. Press SETUP
GoVideo VR2945
  1. The disc tray has to be empty
  2. Press SETUP
  3. Go to the "System Info Screen"
  4. Enter 1, 1, 0, 1
  5. Enter the region (0 = multi-region)
  6. Press SETUP
GoVideo VR3840 / VR3845 / VR3930 / VR4940
  1. Press SETUP
  2. Scroll down to the lock symbol
  3. Keep Pressing 0 until it says "Congratulations region free!"
  4. Press RETURN
GoVideo D640, D645, DTH7000, DJ350, DP7240, DP8240, DP8440, DV1030, DV1130, DV1140, DV2130, DV3130, DV3140, DVR4000, DVR4100, DVR4175, DVR4300, DVR4400, DVR4550, DVR5000, DVR5100, GVP5850, GVP7811, R6530, R6540, VR1940, VR2940, VR5940
Jul 18, 2008 | GoVideo D645 DVD Player
Locked DVD Tray
I'm pretty sure the force disk eject is the same across all Panasonic models - however I couldn't find anything specific for your model number. Still worth a shot, though.
With the unit in standby, press and hold the 'Stop' and 'Ch up' buttons together. It should power up and force the tray open. If this doesn't work, try changing up your timing by pressing and holding 'Stop' first, then a half-second later, press and hold 'Ch up' and keep them both held together. You can also try the opposite.
If none of these work, it will have to be taken apart to get the disc out. If you aren't comfortable trying, it will have to go to service.
Mar 09, 2008 | Panasonic DMR-HS2 DVD Recorder
Yamaha DV-C6480 Multi-disc DVD Player Logo
54 people viewed this question
Top Yamaha DVD & Blu-Ray Players Experts
Larry Stiles
Larry Stiles
Electro Med Services...
Are you a Yamaha DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
