Question about Westinghouse 24 in. MDP531 RF Free-standing Dishwasher
Door Springs I need to replace the door springs in my dishwasher how is this done?
Goto for directions
Posted on Oct 09, 2008
Door springs
If the door won't stay shut the issue is with the door catch not the door springs, But if you want to know where the door springs are you need to remove the outer cabinet of the dishwasher and you will see them on the lower sides.
Mar 04, 2012 | Zanussi Dishwashers
Broken door spring on kitchenaid dishwasher
Please read our safety information before attempting any testing or repairs. Before repairing the door springs, unplug the dishwasher or shut off the power at the fuse box or breaker panel to avoid an electrical shock hazard.
The door opens and closes with the aid of springs. If the springs (or the cables that connect them on some dishwashers) break, the door will drop open hard. The door will also be heavier when closing. If the door drops open, it may also bend the door hinges out of shape resulting in a door that does not close properly and possibly leaks.
When replacing the springs or cables, all of them should be replaced at the same time.
To access the door springs and cables remove the lower panel located beneath the door. The panel is usually held in place with two screws either above or below the panel. It may be necessary to first open the door to the dishwasher to get to the screws over the panel, then close the door to remove the panel.
There are two common types of spring assemblies. One type connects the springs from a hook on the dishwasher cabinet of to a tang on the door hinge .
May 07, 2008 | Dishwashers
I have a KitchenAid KUDS01FLSS2 and was wondering if it is normal for the door to fall open... what I mean is the door requires to be supported when opening. Otherwise, the door will swing down and almost...
Yes indeed that sounds exactly like the door springs being broken. The springs are fairly easy to replace, what needs to be done to replace the springs is remove the lowest service panel/kick plate and hook the springs on the tub support frame/leg and the other end goes on a notch in the door hinges. The part number for the spring is 8270182 they could be purchased at your local appliance parts store or online at;
Even though only one may be broke its advisable to replace both at the same time.
Good luck,i hope i have been able to help you fix your dishwasher,
Aug 13, 2011 | Dishwashers
Cannot open the door of the dishwasher.
  • The latch on many dishwashers is adjustable. If your door is easy to close but difficult to latch, adjust the latch to let the door close more easily. If you can't see any way to adjust the latch, yours may be fixed in a certain position. Check for other reasons for the latching problem.
  • If the latch has worn out in a way that makes it impossible for you to close the door properly, you probably need to replace the latch.
  • Your dishwasher has two springs that counterbalance the weight of the door. If either or both of these are broken, the door feels quite heavy and you need to replace both springs.
May 04, 2010 | Maytag 24" Tall Tub Built-In Dishwasher -...
Repair door springs - LG dishwasher - LD-2040WH.
my lg door keeps on falling done something wrong with door springs ; how do i repair it.
Nov 28, 2009 | LG Dishwashers
Squeeking, swaking door springs
Hi there
Thats a common problem with sprung door hinges, get some WD-40 lubricant spray and spray the spring until the squeaking stops.
Good luck and thanks for using Fixya!!
Feb 19, 2009 | KitchenAid Dishwashers
F & P dishwasher 913T/87198 - ? how to replace door springs
I have done this on another make, but most front loading are very similar see pictures and solution here:
Jan 12, 2009 | Hoover 24 in. DT999 Free-Standing...
Door spring on dishwasher broke
I have just done this on my own dishwasher, and managed to bend the next curl of the springs to replace the broken ends, see instructions and pictures here:-
Nov 23, 2008 | Jenn-Air 24 in. JDB8910 Built-in...
I need to replace the Door Springs
if you just need to install springs pull the bottom kickplate can do it there only two screws
Dec 29, 2007 | Frigidaire 24 in. FDB126RB Built-in...
Door Problem
There are set springs for the adjustment of the doors on the Bosch dishwashers. they are colour coded for different applications. They are accessed by laying the machine on its back and pulling the springs out of the base. first you will need to check that the nylon lines which attach the springs to the lower part of the door mechanisms are in place and this can also be done while the machine is on its back. or by first removing the side panels to access the door hinge mechanisms. If you have a custom cabinet panel on your machine it may be too heavy for the springs and new springs will have to be installed.
Jan 10, 2007 | Bosch 24 in. SGS43C12 Classixx...
Dishwashers Logo
113 people viewed this question
Top Westinghouse Dishwashers Experts
Denis FixYa...
Denis FixYa...
Are you a Westinghouse Dishwasher Expert? Answer questions, earn points and help others
