And when i am going down the road it will stall and backfire. i checked my battery leads they were tight and clean. i drained the gas tank put new fuel in and it ran fine for about 200 miles then it started doing the same thing again. after it shuts off a few times the engine light will not come on when you turn on the ignition.
SOURCE: 99 HD softail stalling problem
If this is occuring everytime you ride the bike and always when it gets warm. I would think there is a good chance that the sensor in the timing cover is getting hot and then developing a short. You can replicate this synario by taking a hair dryer and warming the cam cover around the timing plate, if the bike wont start after warming the timing cover then you have a bad ignition sensor plate. if the bike still starts you can also try the same technique with the ignition module itsself which should on that model be located behind the battery. heat causes shorts in those 2 items quite often. try it out and let me know what happened.
SOURCE: 06 Road King Classice shuts off when in 4th gear beloe 50mph
It's normal for the check engine light to take from 0 to a couple seconds to turn off. The computer runs a system check. Put an oil pressure gauge on the bike and watch it closely. If your pressure drops when the bike loses power, the engine may be locking up from lack of oil. Another possibility is your lean-angle cut-off switch is defective. The switch cuts power to the bike in case you lay it down. Harley also has had problems with their fuel injection system losing power for no apparent reason.
SOURCE: 2001 Road King. Runs fine for three or four
The same thing just happen to me and a friend of mine on our 2001 Road Kings. I am 95% sure your problem is the crank position sensor. We replace ours and the bikes are back to their glory.
SOURCE: I have a 2003 Heritage Softail Classic started then died
Fuel clog in carb or injector, or the magnetic pick up for the electronic ignition.....the spark plugs need to be checked also....lots of variables, but thats a start
Testimonial: "Thanks"
