Question about Westinghouse WSTBW2 Waffle Maker
Flashing "E" in display
When I plug in the waffle maker and wait for it to preheat, it starts beeping and flashing an "E" in the display. Why is this happening?
0 characters
1 Points
How to use the waffler by toastmaster model# 2810R026
  1. Preheat waffle iron. Beat eggs in large bowl with hand beater until fluffy. Beat in flour, milk, vegetable oil, sugar, baking powder, salt and vanilla, just until smooth.
  2. Spray preheated waffle iron with non-stick cooking spray. Pour mix onto hot waffle iron. Waffle is usually done when it stops steaming. Cook until golden brown.
Apr 16, 2014 | Toastmaster Waffle Irons
I lost the instructions for my sunbeam waffle maker, and I dont know how long Ihave to bake it.
Here is a direct link to the User's Manual for your appliance:
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
See page 2 of the manual for detailed operating instructions. Basically they read as follows:
Preparing Waffles
1. Close Waffle Maker and plug into outlet. Use only voltage specified on bottom of Waffle Maker. The Power light (Red) and Ready light (Green) will come on.
Caution: Touch Waffle Maker only by handles during use or directly after use. Take care not to touch hot surfaces.
2. The Waffle Maker is ready for initial use when the Ready (green) light goes out (approximately 2-4 minutes).
3. Open Waffle Maker, pour approximately 3/4 cup waffle batter onto grids. For best results, pour batter around outer edge of waffle maker. Close cover. It is very typical to have a small amount of batter run over grid and down Waffle Maker. However, if an excessive amount of batter runs over, use less batter.
4. Close the Waffle Maker by lowering the upper plate onto the lower plate and secure with the safety latch. Do not open cover while steam is escaping. Most waffles bake in approximately 2-4 minutes, depending on personal taste. Waffles are generally done when the Ready light (green) goes out and when steam no longer escapes from sides and front of Waffle Maker.
5. When waffles are done, remove with a fork or wooden tongs. Note: Be careful you do not scratch the non-stick cooking surface.
6. Close cover and wait for Ready light to go out before preparing another batch of waffles. The next waffle may be baked in less time because the plate will store heat.
I hope that was helpful to you, good luck and take care.
Aug 31, 2011 | Sunbeam 3852 Waffle Maker
I had continue beep sound when I turn on power. Can you help?
Beep sound indicates that the timer is finished and can be stopped by pressing start/stop button, however, it is not normal to hear continuous beep sound upon switching on the unit. Try to check if the timer button is not stuck and or check if you have programmed time.
May 12, 2011 | Star SWB7RB Waffle Maker
Goodmorning, I bought a sunbeam waffle maker at a garage sale. It looks pretty old. When I use it the batter sticks even though I put oil in the batter, and spray the griddle. Is there something I can...
Try preheating the griddle for 5 minutes, then spray a light coat of pam on the hot waffle iron plates, and then add the batter (standard batter should work) (I wouldn't add oil if it's not in the recipe). Good Luck to You with that....
Oct 11, 2010 | Sunbeam 3852 Waffle Maker
When making waffle cones, some come out too soft to serve ice cream in, why? We use our waffle maker daily and on some days all day. Most of the waffle cones are good but every now and then some come out...
Are you certain you are cooking your waffles long enough? If they are not completely baked they will not harden. Additionally if you are in a humid climate they may take a bit longer when you cook them otherwise the moisture will cause them to stay soft.
Aug 05, 2009 | Gold Medal 5020 Waffle Maker
I need instructions for a waffle maker mine are lost
When making a waffle have your batter made plug in your maker and get it started heating if there is a light it will go off whenit is hot enough if not wait aprox 2-3 minutes at the most 5 then spay or brush the inside of the plates with a nonstick cooking spray or brush with butter then pour your batter in the center of the bottom plate and close the lid it should start steaming right away watch the steam it is a never fail indicater of how done your waffle is the less steam the more done your waffle is, there is a lot of trial and error with waffle makers, you should spay or brush between each waffle or they will stick. Let me know how it all cooks out. goofballlovers
Mar 24, 2009 | Waffle Irons
Plug it in, and wait for light to go off..
When light is off, pour (aprox) 1/4 cup batter on each of the 2 (of the 4) waffle panels on the bottom surface. Close lid; then, per manual, wait about 90 seconds. The light may flicker on/off while baking but disregard. You may experiment with different times by observing "steam" from coming out of baking area.
Remove waffles with a plastic spatula (as knives may scratch the non stick coating)
When cleaning, power unit off.. Do not immerse unit in water. Wipe down with a soapy/damp cloth.
I tried using non stick spray and it seemed to make them "soggy"; it also required up to 2 mins (used a "sand timer") then flipped waffles, then another 2mins..
Dec 17, 2008 | Salton WM4 Waffle Maker
Waffle mix spilled over entire waffle maker, inside and out
If it is a non-stick surface brushing cold water on with a pastry brush while it is still ver hot and immediately after removing the food will clean the surface easily. As for the outside, if it is a painted surface a non- abrasive cloth with warm water could possible clean it. I would not recommend pulling it apart.
Sep 06, 2008 | Waffle Irons
Waffle maker keeps popping the breaker panel.
Sorry but it sounds like your waffle maker is toast. It may have shorted in the plug. If you haven't already done so, take it back or contact the maker for a warranty repair.
Oct 09, 2006 | Waring WMK300 Professional Belgian Waffle...
Westinghouse WSTBW2 Waffle Maker Logo
22 people viewed this question
Top Westinghouse Waffle Irons Experts
kenneth njonjo
Chen Dorot
Chen Dorot
Are you a Westinghouse Waffle Iron Expert? Answer questions, earn points and help others
