Maintenance
I know this is a maintenance question but I'm looking for a little local information.
I went to clean my chain yesterday and noticed that it's way too long. There's a bit of kinking too so it's time to get a new chain.
The chain maintenance info on this board seems pretty detailed and doesn't look too hard (lol perhaps I should mention that I'm a noobie and haven't worked on my bike much yet). Should I attempt this on my own? Any suggestions where in TO I should get the chain and tools?
Or should I take the bike to Rev Cycle (any rough estimates on price)?,Depending on your skill and comfort level you can probably tackle this job OK, here are some rules (I'm making up early Saturday morning without the benefit of coffee)
Buy the best quality chain you can buy, (x or o ring) If the chain is screwed chances are your sprockets are too (yeah I know $$$) It's a good time to go up in the rear or down in the front (sprocket teeth, don't do both) if your bike has a single swing arm forget it (tools stands etc too much hassle adjusting probably not worth it just take it too the dealer unless your very determined and are investing in the tools and time etc) otherwise no biggee.
Now so your chain lasts don't over adjust, unsprung the chain will appear loose get some else to sit on the bike as you check the chain tension all the way through the suspension travel check chain and sprocket alignment (laser, eye ball whatever) sometimes shims or other pieces go missing (especially when chain have kinks or wear prematurely) chain wax is your friend, lube it hot and use a clean rag to get excess and clean sprockets.,,,
