Question about GE Spectra JGBP30 Gas Kitchen Range
Oven takes a very long time to heat.
Our gas oven takes a good 30 min to heat to 350 & an hour to heat to 400. We had a repair man come to take a look at it. He said this is normal. What?!? I have never had an oven take this long to heat...So, after researching it ourselves, we replaced the glow bar a year ago. Obviously, that wasn't the answer, because we still have the same problem.
  • Christine Daniels Dec 17, 2006
    I forgot to mention that the broiler and the stove top burners work just fine.
  • Rick Berk Feb 15, 2008
    I also have the slow pre-heat problem. It was not that way when the oven was new. It takes now about 30 to 40 minutes to reach 400. The burner flame is a perfect blue but not very large. Any guidance as to how long the flam should be? I estimate the flame to be about 3/8 inch long and uniform.
  • 175 Answers
Do your burners work ok when the oven is on? if not you may have low supply pressure to your range or the regulator may be limiting the gas flow. Also, I have a wolf gas range and it takes 30 minutes to heat to 350 as well, haven't timed it to 400. Has it always taken that long? Another thing to check is the door seal. If its not sealing it could cause a long preheat. If the door seal is smashed flat and/or not soft it needs replaced. Hope this helps.
Posted on Dec 21, 2006
    Welcome Back:
    Visited the website for 2 consecutive days.
I came to that conclusion also and replaced the igniter and that solved the problem.
Thanks
Posted on Sep 17, 2008
  • 943 Answers
Thanks for the question the problem is with the igniter it gets hot enough to ignite the gas but not enough to give a big flame change igniter thanks the appliance doc
Posted on Sep 16, 2008
Frigidaire gallery stove
Hello Debbie - Sounds like the unit has loss some of its heat inside of the oven cavity. This means it cannot reach the proper preheat temperature in the programmed 30 minute timeframe. A technician would be required to further diagnose this concern. They would most likely assess the convection heating element, thermal cutout, thermal oven sensor and all wired connections for repairs. Lastly the oven cavity and insulation should be checked to ensure there are no gaps or damages that will leak out the heat. At t his time, I would recommend contacting a professional to assist you further.
May 24, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Have Whirlpool electric range super capacity 465 with accubake system oven will not shut off
Karen, We are sorry to hear about your Oven. We are happy to look into your concerns but we will need your your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to Whirlpool_Digital@whirlpool.com.
Jun 12, 2017 | Whirlpool 30" Self-Cleaning Freestanding...
Oven is taking to long to heat
look for the temperature sensor inside the oven cavity in the upper left or top center of the upper oven cavity,its will be a silver or copper colored rod about 1/4" by 2" to 6" long this rod senses the oven temp and cycles the heat to the oven
Jun 03, 2012 | Kenmore 30464 / 30465 / 30469 Gas Single...
GE profile Spectra gas range/oven is taking approx.20-30 min to preheat. Once it finally reaches temp. it seems to hold at that temp and maintain it. I have noticed occasional puffing sounds when it...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Apr 17, 2011 | Ovens
Set oven to 350 takes long time to heat never hitting 350 after 1 hour of being on. flame comes on but never very powerful broiler and burners work fine.
Oven not Working or
Oven not Heating
heatman101
Feb 15, 2011 | Kitchen Ranges
My oven is taking 30 min to heat up to 350 degrees. the light sensor is turning orange what might the problem be??????
If your electric2_bing.gif oven is not heating then you probably have a bad heating lelement in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
May 07, 2010 | Maytag CWG3100A Gas Single Oven
After the oven initially warms up and the oven is in use for over about 30 mins. the oven is not relighting allowing the oven to cool down.
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Dec 22, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
My Kenmore gas oven sporadically takes forever (30+ min. to heat up to 350 degrees). Sometimes it works fine, & other times it takes at least 1/2 an hour. Also, I periodically smell natural gas when I...
Sounds like a weak ignitor. If it doesn't get hot enough to allow the proper amperage through to the gas valve, you will have this symptom.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 25, 2009 | Kitchen Ranges
Kitchenaid Model KGST307HBS5 intermittent will not heat up
the gas leak can be the safety valve. in side the oven where the burner sits on you have to remove the burner to get to it.
Dec 09, 2008 | KitchenAid KGST307 Gas Kitchen Range
Kenmore model 790 oven pre heats incorrectly off by 50 degrees
Temperatures vary for two main reasons, component tolerances and positioning of the sensor.
Feb 15, 2018 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Open Questions:
See all GE Spectra JGBP30 Gas Kitchen Range Questions
GE Spectra JGBP30 Gas Kitchen Range Logo
540 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
