Question about Toshiba MW24FPX 24 in. TV/VCR/DVD Combo
Bright lime green screen with horizontal lines
The DVD player was broken when I got this tv. I ordered and replaced the DVD player, now when turned on all I get is a bright lime green screen with horizontal lines through it. I have taken it apart three times and inspected everything that I touched and it all looks good. Any suggestions would be greatly apprciated. Thanks
techman
  • 3130 Answers
SOURCE: Top of screen is stretched
There are capacitors in the vertical circuit that can cause this problem. You may be able to find these capacitors by using a hair dryer pointed to the suspected bad cap and then when the problem happens you can spry a little cooling spray on it to see if the problem clears up. The vertical output IC could be going bad but this can be checked the same way. if you have no TV solid state repair experience, play it safe and take this set into a local repair depot. Good Luck
Posted on Mar 17, 2007
premtech
  • 934 Answers
SOURCE: a bright line on the screen
A line running across the screen like that and then returning to a picture I would guess is the vertical IC has some poor solder joints. The vertical IC in that unit IC401 is an LA78041 a seven pin IC that is mounted to a metal heat sink. On the foil or under side of the board take a careful look at the pins of that IC and any that look suspicious carefully re-flow some solder over.. Careful not to keep your iron on the pin too long.. And if have to re-solder several take some time between them to allow the IC to cool so you don't damage it.. Good Luck Bill
Posted on Jun 10, 2007
  • 375 Answers
SOURCE: toshiba 57h82
your convergence amp ic's./if you want to cheat/align the other two colors and manualy move the green yoke rings on the green picture tube neck so the green cross aligns with the red and blue.,they shuold form white when all three are aligned,on top of each other.
Posted on Sep 13, 2007
  • 1694 Answers
SOURCE: hi toshiba 43 rp
You have a confusing mixture of data......Please provide
Make,model,age and chassis off sticker on back of set.....T.
Posted on Nov 27, 2007
premtech
  • 934 Answers
SOURCE: horizontal line
Olao,
Your symptoms suggest that your vertical Ic401 has failed. In your Tv that Ic is a LA78040N-E Toshiba p/n# AE002783. Also it would be wise to test the feeder caps in that circuit, especially anything in the 100uf range.
This is not an expensive repair for a qualified shop. The Ic is under $20.00 dollars and caps are a buck or two - the labor will be your most expensive element of the repair and it shouldn't take an hour start to finish..
Hope this helps!
Bill
Posted on Dec 01, 2007
When tv is turned on you get poicture and sound but there are broken horizontal lines from top to bottom of screen. this occurs on all hdmi inputsincluding roku and dvd player.
How to fix lcd lines on Sharp tv screen, hdmi video board ...
? 3:43
https://www.youtube.com/watch?v=cHki4D0EwOo
May 24, 2014 - Uploaded by Tampatec
How to fix LCD lines on Sharp TV screen, hdmi video board easy ... Make Money From Your Broken Cracked LCD LED PLASMATV ... TV Repair Help for Vertical & Horizontal Lines on Your TV Screen ... Sharp Aquos LC-32 37 46 52DH65E 66E 77E - NoPic/Sound with ... Get video URL at current time.
comments on LCD Display Symptoms and causes. - YouTube
https://www.youtube.com/all_comments?v=DedJvyNm_s4
We have frequent outages causing the TV to turn on from standby mode when power returns. (These ..... Sharp LC-70LE650U 70-Inch Aquos TV TURNS ON WITH PERFECT PICTURE AND ..... It has thin horizontal lines on the top quarter of thescreen. ..... hey there, bought a 52lg60-ua had no image/picture but had sound.
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Jan 28, 2016 | Sharp aquos 52 in lcd 1080p aquos 52...
Model 42LG70. Why is nothing on screen except for horizontal green and pink pixel line?
Black square on the screen Vizio Gallevia 47" 1080p - Fixya
www.fixya.com/support/t355299-black_square_screen_vizio_gallevia_47
Jan 16, 2008 - Black square sized app. 10"x10" pops up on the bottom right corner of the screen and won't go away. .... Model 42LG70. Why is nothing on screen except for horizontal green and pink pixel line? I am looking at replacing the ...
bad screens display vertical lines with a white background ...
https://www.ifixit.com/.../bad+screens+display+vertical+lines+with+...
iFixitJun 17, 2014 - I am now replacing a screen on a different G2 and I am on the secondscreen. ... A touchscreen smartphone made by LG Released: 09/2013 Model: VS980..... on the rigth side, from the top to the botton has 6/7 black lines.Missing: 42lg70 ‎pixel
Broken LG LCD TV Capacitor Black Screen My Wont Turn ...
? 6:27
https://www.youtube.com/watch?v=EbGiXqBAvvo
Aug 25, 2010 - Uploaded by FixItUrselfDummy
Broken LG LCD TV Capacitor Black Screen My Wont Turn On ...How I fixed my LG TV, Won't turn on or show picture Model: LG42LC7D ...Missing: horizontal ‎pink ‎pixel ‎line
Jan 05, 2016 | LG Televison & Video
My tv/ dvd player has appeared with a green line down the screen
There are two problems occurs on your TV, one is the line down the screen because of faulty horizontal deflection or faulty horizontal yoke winding. 2nd is...color of the screen are not balanced, check the RGB transistors in CRT board circuit.
Aug 05, 2014 | Prima Televison & Video
The tv comes on and then goes completely out after about 20 sceonds. While it is on there are diagonal lines on a lime green field that do not move.
yes. if you have a black bright screen with about 16 to 20 horizontal lines going across, you have no video. suggest local service center. if it is a magnavox, this is easy. you have an open 1 ohm(approx. value) resistor on the crt board.
Nov 12, 2009 | RCA Televison & Video
Wavy lines
Are the wavy lines horizontal or vertical? If they are horizontal and up near the top of the screen it could be 60HZ interference from a power cord running over the cable from the DVD player to the TV. There could also an internal breakdown of the shielding by the power supply of the DVD player. If the lines are vertical it is likely the cable or maybe the input jack on the TV. Could be a number of things.
Nov 09, 2008 | Sony DVP-S500D DVD Player
Green horizontal lines
Hi, I have a Philips 29PT9009/12 TV. Recently I have begun to see horizontal green lines on my tv, when either watching a dvd or watch tv. This has gotten worse and now the green lines are more visible and the background is now turned a shaded green. Please help me. Thanks in advance
Apr 30, 2007 | Philips 28PW6506 28" TV
Green screen with almost horizontal zigzag lines
Is good that you hit it and it reacts,very likely you have loose conections in different places but for the distorted picture you need to check the horizontal driver transformer and flyback after that is corrected you need to check the complete chassis for loose conections.Take your time.Good luck.
Sep 07, 2006 | Sony FD Trinitron WEGA KV-27FS100 27" TV
I have a thin bright white line,horizontal,no picture
i have panasonic sophia tv 29" i have white horizontal line on middle of screen i know i have to solder ic but where is the ic located on main circuit board. thankx
Aug 22, 2006 | Jensen TS2750J TV
Some part of TV has been fused causing no picture on screen , only bright green horizontal lines , not even video channel could be set ,cannot see menu on screen please help by specifying possible...
if the screen is real bright green with thin small white lines in it its probably a shorted picture tube. Or a shorted Green driver Transistor. Good Luck
Apr 12, 2006 | Thomson 14MG135 14" TV
Toshiba MW24FPX 24 in. TV/VCR/DVD Combo Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
