Question about Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load - F11 Fault
I have seen/read other postings for this same problem, but mine has a small twist. I get the dreaded F11 fault, but only intermittently. If I unplug/plug in the machine and give it another try, it usually works fine. I may then get several loads without another error, but it always returns. The service tech brochure (located inside the back of the washer in a plastic envelope for those of you that may want yours) is little help. A lot of check this/check that (but for what it doesn't say). I pulled the front lower panel, top, and back to check all these serial wiring connections - seem OK to me. They want you to "check" the CCU, MCU, and Motor - the 3 most expensive parts (electrically) in the machine. So am I supposed to start buying/replacing $200 and $300 parts until I find a fix? It seems that is what they would have you do.
  • 5 more comments
  • Andrew Weber Mar 30, 2007
    I agree with what you are saying about the construction and vibration of the machine. Mine is compounded even more with the addition of the drawer/base assembly. While this raises the unit up to a more comfortable working height and gives you some storage, it simply raises the center of gravity of the machine and makes the vibration worse. The wall in my laundry room is more than 1 1/2" away and it is beat up from the washer.
    I have - since posting the original - tried to remove the serial cable connectors from both ends of the cable and soldering the wire right to the PC boards. It seemed to help, but the F11 returned. I think the temporary help had to do with powering down and up. In fact, I found that if I powered down and let the machine "rest" I could get at least one load out before F11 came back.
    I finally bit the bullet and bought a new MCU at around $200. I have a family of 6 and a malfunctioning washer just isn't an option. I replaced it in mid January and haven't had the dreaded F11 since.
    I did notice that on the MCU (that I removed) there is a small transformer that must be for the DC power supply to the board. I bet this powers the low voltage inputs/outputs as well as the processor (via some additional regulation). This transformer looked like it has been getting hot. The iron laminations and dielectric of the windings was irregularly blackened in places.
    I further speculate that as the transformer gets hot, it starts to sag the DC Voltage of the MCU. The lower DC voltage could cause faults in the processor, faults in the serial comms, any number od problems.
    Unfortunately, I feel the ultimate resolution to the problem is to replace the MCU. I do believe that the anti-vibration techniques listed in this thread would be good preventive measures. Vibration is no friend to electronic components hanging on by solder - especially relatively heavy objects like transformers and bigger capacitors.
  • Andrew Weber May 15, 2007
    The F11 fault is actually described in the tech sheet as a "Serial Communication Fault" involving the MCU (the washers computer) and the DC Drive assembly that runs the motor. If you are not familiar with a DC drive, it is simply a controller for the motor that varies the voltage to the motor to change speeds. This is so the washer can crawl slowly to tumble your clothes as well as spin at the ridiculously high speeds using the same motor. I would argue that "Jay's" is wrong about the door latch - there is a different specific code for that malfunction (I think it flashes F and DL). I wish it was the door lock - that's cheap, unfortunately, I think you are in for a MCU @ ~$200.
  • Anonymous Mar 02, 2008
    I know that problem betwen CCU, MCU and motor, can somebody who knows what is the voltage in each pin tell me how can I check it?
    I whant to know the voltage that sends CCU to MCU, and MCU to the motor. To identify which one is damaged.
    Thank You for helping me.
  • Anonymous Nov 12, 2008
    wow!!! I have been getting the f11 as well....... hmmmmm did everyone buy theres from Sears????? Maybe we all need a recall!!!!!
  • Anonymous Nov 13, 2008
    I am FURIOUS! I too, have started getting the F11 error code within the past few months.....and my washer is, yep, you guessed it, a little over 3 years old! This is ridiculous....for a $1000 washer to do this.....people keep the old top loader kind of washers for 10-15 years without these kind of problems! I will definitley think twice before getting this kind again........when this one dies, I think I want to to back to a top loader, I will NOT pay to replace the motor/computer/whatever.......!!!
    Oh, and to the user who asked if we all got them at Sears, yes, Kenmore Elite is a Sears brand, only sold there.
  • Anonymous Dec 15, 2008
    Well I use to work at a huge appliance dealer in Tulsa,Ok, and I got the whirlpool front loader when it first came out. Ecstatic to say the least, I had a fellow employee hook it up for me. Now two years later the darn thing keeps doing this F11 thing. I replaced the door mechanism myself, with the background in appliances it seemed the best idea. It did nothing but add to the anger.Now I'm out 75$ and the washing machine is still doing it. I mean people have had these front-loaders forever and it just seems that the best answer is 20 or30 years ago they were not making 200,000 of these things a month. Simply put, there attention to detail has slipped.
I have also had the F11/DL problem with this machine. One technician came out and told me the following: I was not using HE detergent, the standard detergent was causing too much sudsing and the machine was having to run too long on the rinse cycle, and it was causing the F11 error. So. I got HE detergent, (it took a while to find an environmentally friendly one), but this has not solved the problem. He tried to change the MCU board - the replacement board did not work, so I'm still waiting for a replacement. He did replace the door lock mechanism, but I still get the DL error. My machines are on 3 or 4 inches of concrete, so vibration is a non-issue. I have found a good whack on the side of the machine seems to work. No kidding. Here's what happens: Stupid F11 flashes. I hit the pause/cancel button. It flashes the remaining time on the cycle. I hit the start button. Sometimes that just does it. If it doesn't I give it a whack on the left side of the machine, (if you're facing it), in the middle, about 6 to 8 inches above where the drawer is. Sometimes it's a few whacks, but I can hear a "chu-chunk" sound, which I think may be the door mechanism. Sometimes there's a sound sort of like a fritzy noise first, but then I get the "chu-chunk" sound. My husband has watched me do it, and he just shakes his head. Well, there ya go. Not buying one of these damned things again, though. I don't think it washes that well to tell you the truth. The loads often come out smelly, and have to be rewashed, and the rubber gasket at the door is a pain to keep clean. Any recommendations for a better front loader would be appreciated. Cheers! Phila
Posted on Sep 18, 2007
I once had located a code combination to push on the control panel to clear the F11 code. I cannot locate that again. Can you please give me the combination to reset the machine?
Posted on Sep 16, 2007
I have the HE 4t and now have the same F11 code. If someone comes up with an answer on this please post the results.
Posted on Jun 11, 2007
  • holleyp Jan 15, 2011
    I have had f11 code and dl f code. I took the top off my machine and wriggled the conectors into the mother board. It has worked ok, they may get loose from the spinning.There is also a booklet of codes telling you what the error means and what connector it is on the mother board. Nobody tells you the booklet is there, i found that out on this site.It is taped inside the machine if you take the front off.
I was told by Jays authorized appliance repair in hollywood florida that an F11 is a faulty door lock and that they ordered one for me which will take 5 to 7 days to get and then they will call to schedule service for me. How do I find out if this is really what F11 means? It seems from these others have to say that's not the problem HELP!!! I love my machine but it's only 2 years old and broken
Posted on May 11, 2007
We bought the Sears Kenmore Elite He3t, and after three years it began throwing F11 and DL codes, first on an intermittent basis and eventually on nearly every load. My research showed many people solving this problem with a replacement of the control unit or the relays inside of it. I have a different theory which is that the problem is really due to excessive vibration making the serial/tach connector to the motor intermittent. This forces an error code when the unit is spinning and vibrating. The problem with the engineering and design of these washing machines was that they all vibrate excesssively unless they are sitting on a floor constructed of a ton or more of solid concrete. The vibration eventually makes either the motor serial/tach connector (or possibly one of the five relays in the control unit) intermittent, and the machine begins to throw error codes. My solution was to take three hefty rubber bands and remount the control unit so that it hangs from the three bands inside the washing machine. This requires removing 3 screws on the rear of the lid on the machine with a 7mm wrench, taking the lid off, and prying the control unit from the mounting tangs with a flat blade screwdriver. The rubber bands can be looped through the mounting ears of the control unit and the original steel mounting bracket. No other modification is required, and the relays will not need to be replaced. The DL codes are only the result of the system shutting down with and F11 code and then discovering that the door is already locked in the restart attempt. People often make this problem worse by then yanking the door open and destroying the interlock system. It is a pity that a one-cent connector and the cheap mounting scheme of the control unit is what kills the reliability of this otherwise very nice $1000 washing machine. Have fun.
Posted on Mar 25, 2007
I have a top load washer 4.7 cu and in the middle of the load it started beeping flashing a F and I can not get the wash machine to spine the clothes. Washer is about three months old.
Can you please help me!!!
Thank You,
Jackie
Posted on Oct 22, 2008
F11 error code
It is usually just a loose or bad(corroded) connection at the motor control unit.Try this link it should help F11 Fault code repair
Feb 12, 2011 | Kenmore Elite 45986 Front Load Washer
What does the f11 code on a kenmore elite he3 washer mean
A bad CCU (main control circuit board) will cause this F11 problem 90% of the time
Aug 26, 2010 | Kenmore Elite 45986 Front Load Washer
The F11 code keeps coming on
Hello there :\
The dreaded
F/11 Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
  • Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
  • Check the Drive system for any worn or failed components
  • Check MCU
  • Check CCU
  • Check Motor
Dec 31, 2009 | Kenmore Elite 45986 Front Load Washer
When my washer starts I get a F11 fault. What does tis code mean?
It is a indication that the control board is not communicating.Very expensive part.As a suggestion only,disconnect unit from power source,check all wiring connections at board
Nov 10, 2009 | Kenmore Elite 45986 Front Load Washer
What does a F11 error mean on a Kenmore elite HE3t?
the first thing u must do is ID who makes this machine for sears, sears doesn't manufacture anything, here is the page that shows you how to do that, then with that info i can look up the code difintion. go to link
http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#Sears /
Oct 23, 2009 | Kenmore Elite 45986 Front Load Washer
F11 flashing kenmore he washer
The F11 error code indicates a serial communication failure. This happens when the 2 main control boards are unable to communicate with each other. This is either caused by a loose wiring harness connection or one of the control boards is defective. Good luck and please rate FixYa!
Dec 28, 2008 | Kenmore Elite 45986 Front Load Washer
I have a Kenmore Elite Quiet Pak 4 front load washer. I keep getting the DL and F11 error. The door is locked and won't open and the cycle will not continue. I can hear a small clicking noise in the...
f11 eror is a serial coommunication error check the harness wirinbg tio the motor and cpu unit
check the drive system for worn part
check mcu motor the dl error fial code is for door lock error it will try to lock 6 times before error code is displayed that is the issue see repair clinic.com for help hope that helps
Dec 01, 2008 | Kenmore Elite 45986 Front Load Washer
HELP!!
We've had this problem for about a yr when i finally firgured out how to correct it.
the problem is that the circuit board is attached to the washer, when it starts to shake it causes the connections to loosen and theats the fault code you get.
How I fixed this was to suspend the circuit from a bungie strap this will allow the washer to shake all it wants and the circuit board is stable, connections stay tight andwasher works fine, after 6 months not one error code at all
Aug 24, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE 5t
Hello
Please see this weblink here for a ton of info on your problem.
F11 = Serial Communication Error. Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
Do this = Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
Check the Drive system for any worn or failed components.
Please rate this post, if you are happy with my response. Respond back to this post if you need more help!
Jan 09, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore elite 44832 front load washer troubleshooting F11 c01 c02
Was there ever a post back for this problem? I have the same issue, and I tried replacing the central control board, but it is still giving the F11 error. I follow the troubleshooting guidelines, but it never makes it past C01. I suppose the next logical step is to look at the motor control board and then the motor.
Sep 11, 2006 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
2,564 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
