Question about Philips 34PW9817 34" TV
Philips 34PW9817 34" Shouts off and red light continuously blinks
You will be watching TV and it just turns itself off and the red light continuously blinks. The only way I have been able to get the TV to come back on is to unplug the TV and count to 10 and plug it back in.
  • dbrb49 Jan 03, 2008
    same problem-get a clicking noise and sometimes it goes off for a second or two and comes back--but most of the time shuts off,blinking red light and only unplugging and leaving it off long enough can get it back- I talked to one person who said it could be the high voltage circuit board and it would cost $500(California) to fix--
I guess the guy never fixed the problem since he never updated his post. PEOPLE UPDATE YOUR POSTS OTHERWISE YOURE A TAKER! Karma will get you.
Posted on Jul 28, 2008
I am having the same problems with my 34PW9817. I spoke with someone at a Philips service depot today regarding the problem and they suggested that I unplug the unit and leave it that way overnight. The tech told me that more often that I would expect, this solution fixes the problem. They mentioned something about this allowing the microprocessor to reset itself. If that doesn't work then I am supposed to expect a repair of between $210 and $265 for problems relating to the power supply. The backlog on getting the unit in and out of the service depot is about 5 days for my area (Denton, TX). I am planning to try the reset tonight but do not expect this to really do much. The problem didn't start until my last move (San Antonio -> Dallas) and other than this, I have had excellent service and picture quality out of the unit. Will update this post after I rectify the problem. David
Posted on Mar 13, 2007
  • David Tucker Aug 24, 2014
    UPDATE 8/23/2014: I keep getting emails from Fixya telling me that the info above was helpful. However, the prognosis with the Philips TV didn\'t end there. What follows is my resolution to the problem. NOTE: I\'m an experienced in fields of electronics repair and high voltage applications. Please DO NOT attempt this at home unless you know how to take the necessary precautions. Otherwise you risk DEATH by electrocution!!! With that said, I removed the cover from the back of the unit, discharged the HD CRT (display tube) to ground, discharged all major capacitors and potential static sources, then unplugged and removed the boards for the power supply and flyback (High Voltage) transformer. Using a magnifier lamp I carefully examined the boards and found a number of suspect "cold" solder joints. I used a tempurature controlled, grounded, soldering workstation to resolder any joint that looked like it could have been a cold joint with possible separation. There were 20-30 of these. After carefully checking the board for any obvious component damage (overheated/darkened resistors, blown apart capacitors, cracked chips/transistors, etc.) and finding no other problems, I replaced the boards in the chassis and reconnected the various module connectors and jumpers. I then replaced the back cabinet cover of the unit and plugged it back into the wall outlet. After recabling inputs and outputs, I turned the unit on. It tested fine and never gave me another problem. I surmise that it had gotten jostled around a bit by the moving company during my prior relocation, as the problems didn\'t begin until after the move. But I was amazed at how many cold solder joints were on the board when I examined it. This is an obvious QC issue with Philips and should be addressed. Hope this helps!
    Scholar:
  • 68 Answers
Hi there, If the tele has been on for some time so that it has finished warming up inside and then shuts off, it could be an overheating problem. If the tele switched itself off radomly after switch on from cold, then there may be a dodgy connection or component. If you are familiar with what circuits are in this tele, especially the high voltage ones, try using a freezer spray, if you can locate the circuit which controls fault diagnosis. Make sure any fans are running, if there is one, and that dust has not built up on hot components. Lastly, if it is a regulator problem, I would have thought you would see other symptoms, such as a distorted, changing picture at irregular times, followed eventually by shut down. Good luck.
Posted on Jan 15, 2007
    Novelist:
    Champion:
  • 236 Answers
Sounds like you have a power supply problem. Possibly the regulation circuit.
Posted on Jan 13, 2007
I have a philips remote control and I need the code to control a pioneer DVD player
Though all remotes are differnet just try this it can be kind of standard. But not all remotes are always compatible
1. On the remote control, press DVD once and Turn DVD player off
2. Press and hold SET until the red light blinks twice, then release SET.
3. Aim the remote control at the TV and press SCAN. The red light will blink twice.
4. Continue aiming the remote control and click on and off at the DVD Player (which may take up to 5 minutes) until it turns off. Immediately press any key except VOL-, SCAN, or SET. If SCAN is pressed again after any key stops Auto Scan, the remote will continue Auto Scan of the next ID from where it stopped. If you have passed by the code that turns off the TV, press VOL- one or more times until the TV turns on again.
5. To lock in the code and exit Auto Scan, press and release SET the red light will blink twice.
1. Or if you have a code. Press Set
2. Wait for blinks
3. Put in code.
4. Test it and if it works click set if not try next one.
Jul 17, 2011 | Philips Televison & Video
Red light blinking, tv doesn't start
Your TV is in Protection Mode right now. A part inside the TV has failed and the TV will not turn ON to prevent other parts from being damaged. The red light blinking is an error code for diagnosing the problem part on the one of the power supply boards. The problem boards that need to be looked at is the Backlight Inverter Board or the Main Power Supply Board.
There is a slim chance you can leave the TV unplugged for an hour so the TV can discharge and reset itself. But other than that, I would use the warranty if possible. The TV repair shop maybe expensive, so get some price quotes to see if it worth the trouble.
Sep 09, 2009 | Philips 50PF9631D 50 in. HD-Ready Plasma...
Blinking red light, no picture or sound
You goingto need to replce the powersupply inside www.partstore.com should have it or preorder it for you from the manufacture i think there around $150 they could be cheaper. Another option is Ebay. thanks for using fixa.com please rate.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Aug 21, 2009 | Panasonic TH-50PX75U Plasma HDTV
No picture or sound just six red blinking lights
Use your warranty in a hurry before it expires. Your TV when into protection mode to prevent further damage. Most TVs have a 1 year warranty. Good Luck.
Jan 24, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
TV doesn't turn on, blinking red light
I will study the manual and find your problem.I have some similar philips model manuals that should work.I may have yours,but I have to search my database.I will find symptom and solution within a day. - edcarson
Feb 12, 2008 | Philips 42FD9935/17 42 in. Plasma...
Tv turns itself off after a few moments of clear viewing
HLP, HCN HL-S The Start-up Problem or/and
3 LEDs in the front blinking.
Unplug the set, pull out the lamp module (not all the way - leave it on the track) and push it back in.
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues
good luck
please mark the post with a fixya!
Feb 07, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Philips 42 in. Plasma shut down
did u cheak the input cables does it do it on dvd input as well as others ?
Feb 01, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Philips 34PW9817 34" TV Logo
560 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
