I recored one time on a DVD-RW disc, worked fine.I went to formatt the disc to reuse it,seemed to do fine. When i put it back in to record from ( timer recording )it loades the disc then trys to formatt, after about 3sec.it gives me a message: Can not record on this disc.ERROR-E4/54037380. Records fine with DVD-R disc. I have tried new disc,different brand disc,unpluging the unit.My son has same model recorder he has no problem recording.I used the same disc he used (new & used)to do a check on my unit, no luck. Can you help?
CLEANING THE DISC LENS ? If this unit still does not perform properly although you refer to the relevant sections and to ?TROUBLESHOOTING GUIDE? in this Owner?s Manual, the laser optical pickup unit may be dirty. Consult your dealer or an Authorized Service Center for inspection and cleaning of the laser optical pickup unit.
FROM EWR20V5 OWNERS MANUAL FUNAI-CORP.COM
Comment by redurham, posted on Jul 01, 2007
It took about 45 minutes, without a manual. Carefully disconnecting all cables and marking them so the would go back in the right place later. Carefully Disassembling the unit, removing the cover - 6 screws, noting all screws and where they came from, pulling the front panel using the plastic tabs, removing the top front edge cover - two screws, removing the disk assembly - 4 screws, pulling the two thin leads so I could pull the entire assembly out. Removing the back plastic cover from the DVD assembly and identifying the Optical Disc Lense. Spraying some LENSE CLEANER on the same cloth that I clean my glasses with, and carefully wiping across - gentle stroke in same direction, then opposite direction - a few times. Spray lense cleaner on the cloth not on the lense.
Reassemble. Reverse order of above.
Works great now. BEST OF LUCK....Or you can find almost any DVD repair facility. This is not a unique process.
Robert
Was this solution helpful? Show your Appreciation by rating it:
Show your appreciation by commenting on dvd recorder won't record on DVD-RW disc.:
Solution #2
posted on Dec 29, 2007
Guest
Rank: Apprentice Rating: 0%, 0 votes
I suggest all the people,and there seems to be many, who are having problems with their Emerson EWR20V5 units contact the nearest Consumer Protection Agency and lodge a formal complaint and ask that Emerson be forced to fix or replace these units at Emerson's expense or desist operation until such time they have complied.
Solution #3
Guest
It appears that there are several people have problems with the Emerson ewr20v5 unit with little or no help from the tech support at Emerson. I suggest we all contact our nearest Cunsumer Protection Agency and lodge a formal complaint and see if they can encourage Emerson to do something to fix their equipment at their expense or stop operation until they
