Question about LG L1520B 15" LCD Monitor
LG L1520B the monitor shakes making some lines running horizontal making the view difficult to see anything on the screen.Infact when i switch on the monitor behaves very well then starts shaking again making the distortet lines running horizontally at the bottom of the screen and then the whole monitor.Please advice what to do
  • 4 Answers
If you keep any magnetic/electro magnetic objects near the monitor these kind of problem may occur, Example Speakers, mobiles.etc.,
But in you case, i hope the problem is with the hardware, Please change the Main Filter capacitor in SMPS of your monitor.
Note: It is not advisable to open the cover of the Monitor. Monitor and TVs stores power even they are disconnected so if you are not sure, please get help from a Service Engineer.
Posted on Sep 10, 2008
    President:
  • 2,961 Answers
This sounds like either a loose lead connection or a corrupt driver, if its looking like a driver fault you can click Start>Run then type 'dxdiag' then hit enter for windows to check drivers. If it's a driver fault unistall driver in add/remove programmes and restart pc, when it finds your graphics card on startup insert your Graphic card cd rom to install driver again.
Posted on Dec 16, 2006
SOURCE:
My crt acer ac512 monitar only centre line view,c"not full view why?
there are several reasons why picture of crt monitors did not display good picture. if your monitor had horizontal line at the center of the screen?...the faulty is in the vertical deflection, check the vertical oscillator also the fusible resistors & capacitors around that section. if there had vertical line at the center of the screen?..check the horizontal deflection, horizontal output transistor also check the YOKE.
Jul 31, 2014 | Acer Computers & Internet
Black horizontal lines across entire screen.
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to see the latest updates. It will make search easy. There are more than 1350 posts to different brand TVs now. Pull up older posts there or do a search by type in the Brand Name of your device in the Search Box, at the top right of the display window.
Dec 08, 2012 | LG FLATRON W2252TQ-PF 22" LCD Monitor
Pc switching on but lines on screen only
If you can't see anything - even the text from BIOS when it boots, I would suspect that it is probably the monitor. If the PC USED to boot fine, then suddenly started behaving this way it is very possibly either the monitor or the signal to the monitor.
You didn't say if the PC is a desktop or a laptop. If it is a laptop, try to find an external monitor to connect to. Of course, in most cases laptops require that you switch them to a dual monitor mode, which will be difficult if you don't see anything on the main monitor.
Is the a Windows machine? What version of the OS are you running? Have you made any changes to the system?
Also: be sure that if you are using an external monitor, the cable is seated fully and tightened down.
Jun 03, 2012 | Dell Dimension 5150 (DIM515MIN) PC Desktop
My LG Flatron L1520B monitor "Locked/Unlocked"
press the power button for 1 mn and release it if still the same problem change your inverter board.
Oct 28, 2010 | LG FLATRON L1717S 17" LCD Monitor
I'm changing out my monitor from a large CTR monitor to the LG monitor I plugged the monitor into my computer that is running xp I get a screen that says it is not in range what do I do to fix the problem...
restart your computer hit ALT F5 run safe mode setting graphics rasulation adjust monitor frequency only 60 Hz and again restart run normal mode then its OK. if are not OK again install windows this monitor.
Nov 23, 2009 | LG L1520B 15" LCD Monitor
A vertical white line appears on my LG L1520B 15 monitor
This is a horizontal sync circuit gone.
In English, probably cheaper to replace than repair.
Wouldn't hurt to get a quote if it is free.
Jul 29, 2009 | LG L1520B 15" LCD Monitor
Syncmaster 245B Monitor Shivering horizontal lines
Which type of video connector are you using? VGA or DVI?
If you are using VGA, the horizontal line could be due to interference, like from an electric motor (fan) near the video cable.
Other thing to try is to change the refresh rate. In Windows XP: Control panel --> Display Properties --> Settings tab --> Advanced button --> Monitor tab --> Screen refresh rate. The default ot 60Hz for LCD monitors. Bump it up to 75Hz. That could give a clue to the problem or maybe even fix it.
Jan 08, 2008 | Samsung SyncMaster 245BW Monitor
Problem in monitor
Hey vinay i guess its hardware problem ... coz software doesn recognise u hitting it ,,, ; )
Nov 28, 2007 | LG L1520B 15" LCD Monitor
Horizontal lines are appearing and moving acrosss the screen of my View Sonic E50C Monitor...
What is wrong with your monitor is that the Horizontal section is going faulty, the lines you are seeing are the Horizontal Retrace lines, usually invisable in a working unit. It is often a faulty capacitor(s) OR a Diode breaking down.. in the area of the Flyback Transformer. Probably time for a new one unless ya can fix it yaself.
Jun 11, 2007 | ViewSonic E50C 15" CRT Monitor
LG L1520B 15" LCD Monitor Logo
146 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
k24674
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
