Question about Barska Optics Barska AE10106 - 900114, 200x professional Telescope with Tripod&Carrying Case- Reflector Type Scope...
Cant find the stars
Hi i got this telescope for christmas and i cant get it to work i can site stars on the siteing scope but when i look in the main eyepiece i cant see anything. is there something im doing wrong or am i missing something
  • ladybugwooki Sep 22, 2008
    i have gotten a used telescope model 82-1151 and i cannot seem too find it here on the web ,i am also unable to put it together . the directions arent helpfull. please if you know how to fix it, thank you
  • lilrainbow Jan 20, 2009
    iam having the same problem.cant see anything, how do you realign, i know nothing about telescopes please help...
    Problem Solver:
  • 12 Answers
You need to have the sighting scope and main tube realigned.
Posted on May 03, 2007
How do i set site scope to aim at what i want
Not familiar with this particular model, but you may like to try using the main scope to obtain an image (doesn't matter what), then adjusting the small sighting scope to show the same object and securing it in place. HTH
Jul 14, 2016 | Vivitar Viv-tel-76700 75x/350x Reflector...
I have a celestron Cosmos 90 GT Wifi telescope and so far haven't been able to use it. I struggle with aligning the telescope to 3 bright stars... if by chance it says its aligned when I choose a star
Aligning a scope requires several things to be correct.
1. You must follow the setup in manual 100%
2. You must pick the correct alignment stars. Most failed alignments are because you aligned on the wrong star. So alignment requires you to learn the names of a few bright stars and be able to spot them in the sky.
3. With many goto scopes there might be a "home position" to start the alignment. For example, tube pointed roughly North, and level. Check your manual for a "home position. Also time, date, and site must be correct.
Clear skies,
TelescopeMan
www.telescopeman.org and www.telescopeman.info
Feb 16, 2015 | Celestron COSMOS 90GT Wi-Fi Refractor...
I need the instructions on how to put a Simmons 600 power / 60 mm telescope together because I have never put a telescope together.
You will not find a manual for that telescope brand. However Meade telescopes has a web site with all of their telescopes--
They all assemble and are used in a similar fashion:
Try these two web site links and look under the REFRACTOR heading for a scope that looks similar to your scope.
http://www.meade.com/manuals/index.html main page
This might be similar to your scope?
http://www.meade.com/manuals/TelescopeManuals/Refractors/90AZ-ADR.pdf
May 18, 2011 | Edu-Science (10166) Telescope
My daughter got a C-Star Stratus UB 450 Refractor Telescope for Christmas with no owners manual. Do you know a website that I can pull a manual from? We tried it out tonight but couldn't see anything....
New telescope users are taken by surprise at the difficulty of just pointing the telescope in the right direction to see anything. The field of view is quite limited, especially if you are using a high power eyepiece. The higher the power of eyepiece on a telescope, the dimmer the image, the more difficult to aim it at any chosen object, and the more difficult to focus. When the scope is not focussed, even if there are stars in the field of view, they will only be faint blurs.
It is best when you are starting out with a telescope to try it with the least powerful eyepiece (the one with the highest number) to begin with, until you become more familiar with how it works. Do NOT use the Barlow lens if one came with the scope.
The finder scope is meant to help you get the main scope lined up on the object you want to view, but it won't be any use in pointing the telescope until you adjust it to precisely line up with the main scope. Telescope manuals recommend that you do this in daylight, by pointing the scope at an object on the horizon and adjusting the finder to match (never point a telescope toward the Sun!). Once you have a tree or mountain peak in the center of the main scope's image, you can then adjust the screws around the finder scope to get the crosshairs (or red dot) centered on the same object. It is very difficult to do this job in the dark, especially as objects in the sky are constantly on the move.
You will find that there is a very wide range of movement in the focus mechanism, because different eyepieces focus at different points, but the actual focus range for any eyepiece will be a small part of the overall range afforded by the focusing mount. It is much easier to familiarise yourself with this in daylight.
At this point you will learn that astronomical telescopes usually show an upside down image. There is a good reason for this- erecting the image needs more bits of glass in the light path, which reduces the amount of light and increases aberrations. Even if this is only slight, astronomers prefer to avoid it, and they don't really care which way up the Moon or Jupiter appear. It is possible to fit an erecting prism or eyepiece to most astronomical telescopes, and some of them come with one, but one wouldn't bother to do this with the small finder scope.
Once you have done the above, you can try the scope at night, on an easy to find bright object like the Moon. Looking at random stars will probably be disappointing, as they don't look different under magnification. You will have to find planets, star clusters or nebula to see anything interesting. You will also find the the object you are looking at swims out of the viewing field, and you must continually move the scope to follow it. This will be more pronounced at higher magnifications. Again, use the least powerful eyepiece. Small scopes are often advertised as having unrealistic powers (300, 500) which can never be practically achieved. You just get dim blurs.
There is an excellent website for beginner telescope users at THIS LINK
There is a collection of telescope manuals for download at THIS LINK
It is unlikely that you will find exactly your make and model there, but there will be similar scopes.
Jan 30, 2011 | Cstar Optics UB-450 (450 x 60mm) Telescope
I have a traq 540 telescope and do not know how to use it. Help please
This is a very nice refractor style telescope. First I would suggest that you locate a local Astronomy club and have the members help you with the scope. It is probably mounted on an equatorial mount which must be polar aligned first in order to use the telescope.
Additionally the small finder scope must be aligned with the main tube so you can use it to locate objects in the sky. Read my Equatorial Mount TIP on my profile page.
Also read this web site:
http://www.astronomy.net/articles/4/polaralign.html
You can download a free monthly star chart here:
www.skymaps.com
Jun 27, 2010 | Vixen A102M Telescope
I was given a Tasco 675 power reflector telescope model #40-114675, but didn't get an instruction book or dvd. I was able to find a star in the finder scope but couldn't see it through the eyepiece. it...
You must first ALIGN the finderscope with the main tube. Locate a bright object with the main telescope. Get it in the eyepiece- then without moving the telescope, align the finder scope on the same object.
Now you can use the finder like a gun site to center targets on the crosshairs. By the way the Fixya picture in your question always makes me laugh- the telescope in the picture is mounted BACKWARDS and pointed toward the ground!
Jun 01, 2010 | Tasco Luminova 40114675 (675 x 114mm)...
Meade LX200GPS The scope does not complete the 'Auto Alignment'
Once the scope has taken a GPS fix and knows TIME, and SITE, and you do a two star alignment your alignment stars overide any automatic alignment issues.
You could turn off the GPS put in Time, Date, and Site, do a two star alignment and everything would be fine. Centering the alignment stars is the "trick". Apparently the scope also finds NORTH OK, or the alignment stars would be way off. Since you pre-level the tripod already the software can FAIL on "tilt" and you still get good gotos.
I would not worry about it, especially since your gotos seem perfectly fine.
May 28, 2010 | Meade LX200GPS Telescope
HOW TO USE AN ORION SKYQUEST XT 4.5 REFLECTOR TELESCOPE
During the day time line-up the small finder scope with the main tube. Use the eyepiece with the largest number written on it. Site on a distant object with the main scope. Then line- up the crosshairs on the finder with out moving the main tube so BOTH are pointed at the same object.
Locate a local Astronomy club and attend their star parties. You have a good beginners telescope by the way.
Learn how to collimate the telescope. Watch this video.
http://www.andysshotglass.com/Collimating.html
Nov 11, 2009 | Orion SkyQuest XT4.5 Dobsonian Telescope
Hi i have an optus telescope when i find a star in my view find or the spacestation orbitating the earth i find it in my view find and when i look through the lens on the scope i see notting and i have...
Your finder is not aligned with your telescope. During the day time focus on a distant small object with the telescope-- then without moving the telescope adjust the crosshairs in the finder to match the telescope.
Dec 27, 2008 | Optics
Zoom
All goto scopes require you to do an alignment on 2 or 3 stars in the night sky-- or they will not find anything. Also the time, date, and site must be accurate-- and the tripod must be perfectly level.
Read the manual again-- and perform all of the setup steps. You can download a monthly star chart here for free:
http://skymaps.com/downloads.html
The alignment stars are ALWAYS the brightest stars in the sky and the first ones you can see when it starts getting dark.
www.telescopeman.us
Dec 21, 2007 | Bushnell NorthStar 78-8890 (300 x 90mm)...
Barska Optics Barska AE10106 - 900114, 200x professional Telescope with Tripod&Carrying Case- Reflector Type Scope... Logo
338 people viewed this question
Top Barska Optics Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
xalint1
xalint1
Vladimir Frolov
Are you a Barska Optics Optic Expert? Answer questions, earn points and help others
