Question about Zanussi ZCM611X Dual Fuel (Electric and Gas) Kitchen Range
Noisy fan The fan on the Zanussi Oven is very noisy. Heating is not a problem. The spindle mechanism stops abrupty when turning off. I think it is the bearings - do I need a new motor? It is also very difficult to remove the blade mechanism - should I want to remove the motor. Any advice? Many thanks
  • Zanussi Master
  • 24,414 Answers
The fan works in a very hostile environment of heat. It draws some cooler air from the rear of the oven, but essentially it is working in high temperatures, so bearing do wear out and motors seize. Removal is generally from behind the oven from the rear of the stove. The fan is on a shaped spindle and has a locking allen key grub screw, or the fan blade is pinched between two washers.
See the link for videos on how to replace and for spares themselves. Make sure they are model specific.
zanussi oven replace fan Google Search
Posted on Feb 02, 2018
2 Suggested Answers
SOURCE: zanussi zce7551x bottom oven not working
The
Posted on Feb 09, 2009
What would happen if fan is disconnected noisy and not wanted?
NO NEVER EVER DISCONNECT FANS OR ANYTHING ELSE ON YOUR COOKER.
Your cooker may have at least two fans, one for heating the oven cavity and one for cooling the electrics etc inside the oven. If the fan is noisy, check to see the fan has not come loose on the motor (maybe left had thread) if the fan is ok, then the fan motor may need replacing!
Oct 20, 2014 | Ovens
Noisy fan and no heat
Kitchen aid is made by Whirlpool. There is a very good chance the then thermal fuse on the back of the oven has tripped. Whirlpools are very prone to this fuse tripping after a clean cycle. The noisy fan is just that a noisy fan it will probably need replacing. I have replace a couple of them over the years. When you pull the oven out to replace the thermal fuse replace the fan motor at the same tiome.
May 06, 2014 | KitchenAid KEBC207 Electric Double Oven
My Neff U1721 bottom oven has just stopped working - the fan still works, although is a bit noisy - what could be the problem/
Sound like the element has burnt out but if your fan is also noisy it is probley running slow which may have caused the element to overheat and burn out so it would be a good idea to replace the element and the fan motor
Regards
Ian
Apr 20, 2011 | Neff U1721 Double circotherm Electric Oven
Cooling fan is very noisy
It is probably a worn fan bearing, or loose or broken fan blade.
You could try spraying the bearings with WD40,
which may quiten it down, but normally the only solution is to replace the fan motor complete.
[Please rate my solution.
Thankyou.
Jan 30, 2010 | Zanussi ZDQ495 Electric Double Oven
Delonghi ESM465ST Oven Noisy Fan
If it is a fan assisted oven, then you are likely to have 2 fans, an external cooling fan, and a fan inside the oven for ciculating the hot air.
So to answer your query, yes it is a noisy fan you are going to have to establish which fan.
It could be a worn bearing, or the fan blade has come loose.
If it is a worn bearing, thge only cure is a new fan.
Hope this helps with your problem.
Dec 02, 2009 | DeLonghi Ovens
Loud droning noise from fan.
You are correct in assuming that is a noisy fan bearing, only solution is to replace the motor complete unfotunately.
Please rate my advice.
Thanks.
May 27, 2009 | Ariston Technologies Ovens
Noisy oven
Make certain that the heating element is properly seated WHEN THE OVEN IS COLD! When you put "current" through wires and heating elements, they vibrate. Zip tie the wires together outside the oven cavity.
Apr 25, 2009 | DeLonghi Ovens
How to remove a fan/motor from a Zanussi oven
You are probably trying to undo the nut the wrong way.
It is a left hand thread, so to undo it, you go clockwise, as though you were trying to tighten it, and vice versa to tighten it up again. If you can't unscrew the nut, you will have to grip the fan spindle with something whilst you undo the nut.
Plz rate my solution.
Thanks.
Jan 22, 2009 | Zanussi ZHQ575 Electric Double Oven
Zanuisi top oven making noise
Yes , there is a cooling fan located at the top of the oven
It could be the fan blades catching, or a noisy fan bearing.
You would have to access it by removing the top oven cover to check., and yes it could be as a result of having it cleaned.
Thanks.
Dec 31, 2008 | Zanussi ZDF490 Electric Double Oven
Zanussi ZCM611X Dual Fuel (Electric and Gas) Kitchen Range Logo
74 people viewed this question
Top Zanussi Kitchen Ranges Experts
Paul Bade
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Zanussi Kitchen Range Expert? Answer questions, earn points and help others
