Question about Jensen A600HLX Car Audio Amplifier
Jensen A600HLX I am trying to fix my Jensen A600HLX. I have fixed the fried componets, but now the protect light comes on then goes off. Yet nothing out of it. Need help.
  • Anonymous Feb 16, 2008
    Ditto
  • 113 Answers
Check pwm ic 494 or other
Posted on Aug 09, 2007
Protect light on zx 1000.1
Hello
Disconnect all speakers from the set and switch it ON. If it goes into protection mode, surely the device need service. Something shor circuit is with it inside the circuit. If it does not goes into protect mode without speakers, make sure that any one among the speaker connection has some kind of short with the car body of the speaker itself has damaged. Connect the speakers one by one and find out the damaged speaker or faulty speaker line. OK.
Jan 17, 2012 | Jensen A600HLX Car Audio Amplifier
How should i run my Jensen A600HLX Amplifier if i am using it to power 2 10inch Rockford P1 Subwoofers?
U need to check the impedance of your woofers .If they are 4 ohm i would reccomend hooking them in series, which is the positive output of your amp will go to the positive of one woofer, the negative of that woofer goes to the positive of your other woofer and the negative goes to the negative output of the amp.If that amp is bridgeable this will give u a good bass and the impedance will be 8 ohm so your amp will run cool and stable
Jul 30, 2010 | Jensen A600HLX Car Audio Amplifier
Red light on an insignia amp
Sounds like you do not have Enough room for it to Breath. It will overheat and Short out if not Ventilated Properly.
Jan 04, 2009 | Jensen A600HLX Car Audio Amplifier
I got it smoking
it would be cheaper and smarter to buy a new one
Nov 25, 2008 | Jensen A600HLX Car Audio Amplifier
600 watt 4 channel bridgeable mosfet power supply jensen amp
Swap the wires from one speaker to the other to see if it is the speaker or the Amp/wires.
Oct 23, 2007 | Jensen A600HLX Car Audio Amplifier
Help
No. The amplifier gets its signal from the RCAs connected to the "input" jacks, but the "output" jacks are just there to make it easier to add another amplifier. You only need to connect the inputs for the amp to work.
Jun 29, 2007 | Jensen A600HLX Car Audio Amplifier
Jensen A600HLX
These solid state amps have no user serviceable parts inside them as everything is soldered into place and your gonna need to know how to use a multimeter to trouble shoot the parts inside the amp on the printed circuit board. Sorry But without the proper training and the right tools you could cause more damage to the amp if you dont know what your doing. You cannot just open the unit and see whats bad. You must test each suspected bad part and replace it as needed. You should take the amp in to have a pro look at it, as there is no easy fix on these unless its an external fuse, and a fuse will very rarely blow all by itself. Good Luck
Jul 17, 2006 | Jensen A600HLX Car Audio Amplifier
My amp went into protect
See my solution for: http://www.fixya.com/problems-solutions/t115301,p424435/Eclipse-Car-Amplifiers.aspx And they shouldn't need a schematic unless they can't read the part numbers of the fried components.
Jun 08, 2006 | Jensen A600HLX Car Audio Amplifier
My amp wont put out sound
it's blown....probably, check your connections and make sure your presenting it an ohm load it can handle....so check the sub with a dmm.
Feb 28, 2006 | Jensen A600HLX Car Audio Amplifier
Jensen A600HLX Car Audio Amplifier Logo
300 people viewed this question
Top Jensen Car Audio & Video Experts
Mike Duncan
Mike Duncan
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
