Question about Concord Camera Eye-Q Go 2000 Digital Camera
Digital Camera Will Not Save Images To SD Card
My camera automatically saves images to it's internal hard drive (or flash drive) I have my SD memory card inserted, the camera just will not save to it. Anyone know why it's doing this? Or maybe how I can copy the images on the flash to the SD card? I went through the menu and saw nothing.
    President:
  • 2,961 Answers
Take a look at this caption, it may be your setting is not correct.
Posted on Dec 16, 2006
I have an intova IC12 digital camera. It will snap a picture and show on the display but not save to card?
Please save any images to your desktop that you want to keep. Access format function in camera's setup menu and format both SD card and internal camera memory to clear all data. After formatting, perform a sys reset that is also found in the setup menu. If your camera still cannot save images to the SD card after performing format and sys reset, then the card reader/writer is probably broken. Please contact us directly at 808-837-0074 if you have a sales receipt showing date of purchase 1 year or less which would qualify for warranty exchange under our 1 year warranty coverage.
Thank you
Apr 25, 2015 | Intova Ic12 Digital Camera
DC6550
We need to be sure of some things:
Are you saving the picture to the internal flash memory or an external SD card?
1) The internal memory will only hold 16MB of pictures, check if it's full.
2) The external SD memory can only be up to 1GB in size, anything bigger will not be recognized by the camera
1. Make sure the SD card is not "locked". Some SD cards have a little switch to prevent them to be written into.
2. SD card should be formatted by the camera preferably or as the FAT format in your PC.
Does this help you in any way?
Please give us more information as to how you are saving them and/or any further questions you may have.
Dec 12, 2007 | Cobra Digital DC6550 Digital Camera
How to transfer pictures from camera to sd card
The pictures that are stored on your camera memory cannot be transferred to the SD Memory Card. They must be downloaded to your computer first and then transferred via a card reader, if you intend to get them to the SD Memory Card. The two memory areas, internal and SD memory work separate of each other and the camera only operates from one. IF the system detect SD Memory than that is where the images are saved, if not, they automatically go to the internal memory.
Here it the manual for your camera:
http://www.pentaximaging.com/files/manual/E30_E.pdf
May 18, 2011 | Pentax Optio E30 Digital Camera
My kodak easyshare C813 is telling me that internal memoryis full. What do I do!
You have to upload your images from your camera to your computer and save and delete the pictures on your camera.
You can buy SD memory card which can store lot more images than the internal memory.
If you will be using the SD card, you have to select from the menu that you want the camera to write images on the external memory instead of the internal memory.
You can upload images on the camera to your computer through USB cable. The cable is cheap if you buy from eBay especially ones that are being sold from Hong Kong.
USB cable from Hong Kong worked well on my Kodak.
Jun 17, 2010 | Kodak EasyShare C613 Digital Camera
Internal memory
You can only access the internal memory, when there is no card in the camera. So, turn off the camera, remove the card, connect to the computer and save the images to the computer. After checking that images are saved, you can delete the images in the internal memory, before inserting the card again.
May 04, 2010 | Fuji Finepix Z20fd Digital Camera
Saving images from S5 Pro directly to laptop hard drive -how?
Hello Brian,
Are you writing to the camera memory because your card is full?
I'm not sure what USB auto/fixed is meant to do but try this.
Connect you camera to the pc as normal and switch the camer on.
The camera may ask you if you want USB or pictbridge, choose USB.
XP Then tries to offer you the best way to get at the photos. Rather than use the transfer option us the open as a folder option.
If XP doesn't offer anything click and open my computer, look for your camera it will appear as a new hard drive.
Click on the new hard drive, normally with olympus you get a folder, the first is you camera memory, click on that you should see photo's and another folder.
Copy or cut and past the photo's to a new folder on your PC. The click on the last folder, should be you memory card, move those photo's as before.
Having copied all photos you can delete them from you camera memory and card using the PC. Just as you'd delete any file.
With luck you should be back in action, a whole card to fill................. Good Luck.
Mar 07, 2010 | Fuji FinePix S5 Pro Digital Camera
Photos do not save after camera is turned off
Check the manual. Most digital cameras give you the option to save to an internal memory or an SD card(or whatever your camera takes). If it doesn't have an internal memory...that may force you to have a memory card in so you can keep the images. Good luck.
Aug 04, 2009 | Panasonic Lumix DMC-TZ3 Digital Camera
Camera does not read SD Memory Card
thank you so much this worked great it solved my problem thanks.
Oct 31, 2008 | Kodak EasyShare M863 Digital Camera
Problem saving images to memory card
Make sure you have set the camera to use the memory card. It wont automatically use it, default is internal memory.
May 18, 2017 | Samsung Digimax A503 Digital Camera
Concord Camera Eye-Q Go 2000 Digital Camera Logo
85 people viewed this question
Top Concord Cameras Experts
Damen Wong
Damen Wong
Marvin
Marvin
Are you a Concord Camera Expert? Answer questions, earn points and help others
