Question about Mitsubishi CS-27407 27" TV
Speaker off Someone just gave me their old Mitsubishi CS-27407 27". I hooked it up through my directv connection, no problems there, but there was no sound, and it said 'speaker off'. The previous owner said he had it hooked up through his sound system, but it had been so long since he hooked up the tv he couldn't remember how he turned off the speaker (and no longer has the owner's guide or remote control). I can't find anything on my directv remote that might help, and there's nothing self-explanatory in terms of the buttons on the front of the machine. Help!
  • 398 Answers
You will need an original Mitsubishi remote. The original remotes usually have 3 large oval buttons labeled Audio (up and down), Adjust (up and down) and Video (up and down). Pressing the Audio button will bring up the usual Bass, Treble, Balance... and Speakers Off. When you see those words press the Adjust button and the speakers will switch to On. Some sets have the Audio, Adjust and Video buttons behind a little door on the front of the set, so check there first and if not, get an original remote.
Posted on Aug 10, 2007
SOURCE:
Game console hook up
What type of hookups are on the back of tv ? Do you have an HDMI hookup if so try using that If your tv comes with a game mode look in back before u hook it up to place it in right spot. One last thing why don't you try hooking up old fashion way buy adapter for regular cable hookup and use channel 3 or4 that might help
Jul 30, 2012 | Mitsubishi CS-32307 32" TV
Logitech Z906 Speaker System "Codes directv" issues
Since you have solid products from the leader in 3rd party accessories it should be a snap. Just go to www.logitech.com/home. You shouldn't have any trouble there. Just ask a CS there CS is outstanding.
Jun 10, 2012 | Logitech Z906 Speaker System
Can't listen to TV without hooking it up to stereo speakers. How to fix? Mitsubishi CS 26301
first of all you have to be sure that the speakers are on.To find out you should go to the main menu and select audio for the speakers status.
Dec 22, 2010 | Mitsubishi WS-65809 65" Rear Projection...
SOMEONE GAVE ME SOME BOSE 6X9 CAR AUDIO SPEAKERS. THE SPEAKER HAS FOUR HOOK UP WIRES. TWO TO THE TOP OF THE SPEAKER AND TWO TO THE BOTTOM. MY QUESTION IS WHEN INSTALLING THESE SPEAKERS IS IT OK TO MAKE...
Hook up the speaker wire like this...Positive wire to positive terminal on top then run a loop from the top positive to the bottom positive. Next run the negative wire to the negative terminal on the bottom then run a loop from the bottom negative to the top negative.
Dec 06, 2010 | Bose Car Audio & Video
Hello, I have a very old mitsubishi color tv, model cs 2657r, which I purchased in the late 1980s. The picture is still great, and I'm trying to connect two small external speakers, though the internal...
Try stripping the speaker wires and exposing it about 1 inch. Then connect the speaker wires in a way that the part that grips or holds the wires touches the metal part and not the insulation. If there's still no sound, Please check the external speakers to see if it's working by using them in another device like a home system or audio player or maybe another tv that has an external speaker port. If not, mostly likely the switches are defective and needs replacement by a qualified technician.
Hope this helps.
Oct 25, 2010 | Mitsubishi CS-13103 TV
I have a mitsubishi cs 35305 and the speakers are off
Too old for on line tech help. If its an old tv it might have a switch in back of the tv to turn speakers on or off.
Apr 24, 2009 | Mitsubishi CS-35305 TV
Rear speakers
Well,i will be the judge of that.Please tell me how do you have your system hook up?Be details...ex. TV connected to receiver with HDMI cable..DVD player connected to receiver...
What component that you are having trouble with the rear speakers?EX. dvd player?Directv box?Both?
solutiondoct
Nov 16, 2008 | Onkyo TX-SR804 7.1 Channels Receiver
Directv D10 receiver
I guess the obvious question is, do you have a DirecTV dish installed on your house? If you do, then most likely the cable you have plugged into the Satellite Input on the back of the receiver isn't connected to the dish. I would recommend calling DirecTV and having them send a tech out to double check the system.
Aug 09, 2008 | Directv D10 DTV Receiver
Coby dvd 755 home theatre system hook to directv
The composite output (red, white and yellow) on the directv receiver should connect to the audio in (red and white) on the coby ht system. Then you have to select the correct input on the coby til you here the audio from the DTV receiver
Feb 10, 2008 | Coby DVD-755 System
Televison & Video Logo
167 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
