Question about Canon imageRUNNER 400S Copier
IR400 ERROR CODE E014,E806
HOW MANY COPIES CAN WEMAKE DAILY
EXCESS LOAD MAY OCCUR THIS PROBLEM
  • sheth_paresh Nov 22, 2008
    which part you replaced &what is cost
E051
Posted on Aug 26, 2009
  • Canon Expert
  • 270 Answers
E-014 - The fixing motor has a problem. This can be the fuser drive motor, DC Controller, or Image Processor circuit boards. The only time I've had this problem is with one of the fuser bearing going bad and causing excess drag to the motor, giving you the error. See if the green fuser advance knob is hard to turn. If so then check the bearings.
E806 - This is not in the book that I have. Be sure of the number.
E-805 - There is a fault with fuser cooling fans ( located on the delivery door )
Posted on Nov 20, 2008
I have problem canon ir400 when copy scaning then copy scaning very slow means scan slow lamp is waiting for scan. we replace lamp,ip board and ram . this problem is no solve please help me thank you
Posted on Jun 07, 2011
    Problem Solver:
  • 3 Answers
Sir, i have ir400 when the dram unite under the charging roll all so gray i can say that bhukro also that hugh copy please give me solusation............
Posted on Oct 06, 2011
Canon ir400s E014 error code problem
I dont know that model,but on the others it may be waste toner bottle full,or fixing motor faulty
Oct 15, 2014 | Canon Office Equipment & Supplies
E806-0000
You are having a fan error. The fan is not operating properly. Here is a copy of the error section from the manual.
Nov 23, 2013 | Canon Office Equipment & Supplies
How to fix error code E014, it shows on screen switch main power off and on then E014, but I turned off and on many time , it stay like that
If I remember correctly..... A E014 mean that the main drive is not spining freely. Most of the time the fuser unit is not turning smoothly. Have you tried to spin the fuser unit? If so is it smooh or tight? Have you looked in the fuser to see if the web is wraped around the upper fuser roller? Or is the lower fusing roller cut? If that all looks OK > it is the fuser drive gears (on the front of the fuser) are locked up... You may have to take the two white gears off and clean & lubract / oil the shafts.... Good Luck > there is not a way to reset the code until it is fixed
Feb 04, 2011 | Canon imageRUNNER 400S Copier
Our Canon Image Runner 330S shows error message E014....
is there an error code appear on panel display?
if there a error appear try to reset you may press * key,press 2&8 simultaneously, the select copier then select fuction then clear then error then ok then turn off& on
Jan 04, 2010 | Canon imageRUNNER 400S Copier
No print, e805 and e014
The E 805 refers to a locked up fan motor, and the e014 is for the fuser (the part that get hot) not turning correctly. both of these problems require a technician to fix.
Jul 29, 2009 | Canon imageRUNNER 400S Copier
Error e014 on canon gp 605
I THINK E014 IS FUSER UNIT MOTOR.REPLACE MOTOR.DO NOT FORGET TO RATE SOLUTION.BY MIAN JEE
Feb 22, 2009 | Office Equipment & Supplies
Error Code E014 Casio PCR-T470
Hi. When they run out of paper, you just load a new roll, and the machine will automatically continue. There is no need to clear the error. It will continue when it senses fresh paper in the receipt side.
Jan 11, 2009 | Casio Parts Cash Register PC Desktop
Canon IR400 copier
dear sir, I have ir400 copier. please help me to solve the error no. e051. thanks,
regards
Jan 10, 2009 | HP Compaq dc5700 Microtower - Free Flat...
CANON GP405 ERROR E014 PROBLEM
when I start my machine the error code e014 appears and machine do not run.
Dec 24, 2008 | Canon imageRUNNER 400S Copier
Iam getting error code E010,E014
A E010 & E014 have to do with the main motor drive. You may have a drum blade that has flipped or it could be that the center screw that locks the drum to the drum shaft is loose ( just tighting screw- you can also get blank copies as well. The E014 deals with the fixing unit, you have to make sure it is spinnig freely. It could be that the lower pick off claws have dug in to the lower fixing roller, or the ball bears are siezed or the web is rapped around the upper fixing roller or a bushing is broken or it may be to much pressure is on the UFR from the web... Just a few ideas.. Good Luck
Nov 06, 2008 | Canon Office Equipment & Supplies
Canon imageRUNNER 400S Copier Logo
2,274 people viewed this question
old marine
old marine
