Question about D-Link (DKVM4K) (dkvm-4k) 4-port KVM Switch
Keyboard and mouse problem!
I am trying to use only one PC on the testing bases, that is this switch is working or not. But I found the problem that it shows the display of the system connected to this switch but its keyboard and mouse is not working at all. It sounds a beep when i power on the system but then i can only see its view could not access any thing coz of no connection of keyboard and Mouse.
    Scholar:
  • 121 Answers
I've had this problem happen lots of times before. usually restarting the PC with the switch enabled to the PC that is booting will solve this problem. For some reason, sometimes the drivers don't load for the mouse and keyboard when starting up the PC.
Posted on Mar 28, 2007
I have purchased TWO Packer Bell ixtremeI5726 with a wireless keyboard and mouse. The keyboard and mouse have come equiped with a wireless antenna which is screwed into the wireless card on the back of the...
The antenna that you found is purely for the Wireless LAN. The Keyboard and Mouse are already paired with the bluetooth receiver. This is "HIDDEN" in the mouse battery compartment. But not where you'll see it... it is in the LID of the compartment.
May 30, 2011 | Compaq Keyboard
My wireless mouse and keyboard have been working fien. When i switched on today, I got a "usb device not recognised" and they no longer funtion. ihave tried to check for new drivers, restarted...
I had that problem when I reinstalled my OS. I went to the Microsoft website and searched for the software for the keyboard and mouse, Intellipoint, for the mouse I think. It comes as a package for the mouse and kb based on the model you have. Pretty simple to find. Just load it and it should install without a problem and be recognized by PC. If your USB drivers are OK, this should be all you need to do.
Dec 11, 2010 | Microsoft Wireless Optical Mouse USB...
I have a micro kb985w mouse and key board and they are not working. How do I fix the problem? Thank you
1.check all batteries.
2. press the connect in the proper sequence. base, mouse , then base, keyboard. (should be listed in the manual) sometimes its base, mouse , keyboard.
3. hook up a old keyboard to boot into windows before you try using the keyboard mouse. (you can run two sets at the same time without an issue)
Aug 25, 2010 | Micro Innovations Wireless...
It doesn't work
Please vote and rate me if this helps.
First you will have to go to this site and download the drivers for the mouse :
http://www.dynexproducts.com/pc-331-25-dynex-wireless-optical-mouse.aspx
And then you will have to follow these directions which were found on the site :
Communication Interference for Wireless Device Owners
If you have multiple Dynex mouse/keyboard sets set-up in close proximity they may interfere with each other causing incorrect operation of the device.
Press the receiver synchronization button on the base unit and the base's blue LED should start flashing. Turn over the mouse and
keyboard and on each device hold down the Connect button for two seconds. This will force the unit to operate on a different channel and
should allow multiple keyboards/mice to operate in close proximity.
If this does not work you may have a defective mouse, but it should work.
Please vote and rate me if this helps,
ETRONIC
Mar 17, 2010 | Dynex Wireless Optical Mouse
Found new hardware bubble pops up then mouse and keyboard freze
disconect all the things that is connected to the pc and do them one at a time
Mar 12, 2010 | Dell OptiPlex SX280 PC Desktop
Mouse Stops Responding
You need to reset the mouse and keyboard to the sensor. On the sensor(base) you should have a button and under the mouse you should have also a button. Press the sensor(base) button first and quickly the one under the keyboard and mouse. If the doesn't work shut down the system, unplug the mouse and keyboard sensor(base) and re-plug it back in . Start the system and try the process again.
Oct 03, 2009 | ViewSonic ViewMate CW2206 DHCW2206...
PS/2 mouse port not working?
Hello fredbeer,
Besides the obvious checking with your device manager, you can download a port test kit HERE. That will be able to test if it's working. The other thing you can do is switch the keyboard into the mouse port and the mouse into the keyboard port. You should get some errors, if not, one of them will work and the other won't. Hopefully, you'll get the keyboard in the mouse port to work, so you know the port is working. Also, if you have any other PS2 devices that you can test it with.
Good Luck and don't forget to leave a rating based on my solution.
Thanks
Mark
Apr 15, 2009 | ASUS A7N8X-X Motherboard
Disable onboard mouse
TouchPad Enable/Disable ( Fn+F9 )
Dec 24, 2008 | Toshiba Tecra A3 Notebook
Wireless keyboard doesnt work with switch
once you have switched pc you will need to re-sync the wireless keyboard and mouse with the new pc, because although you have switched pc the keyboard and mouse do not know this. there should be a reset/resync button on the bottom of both the keyboard and mouse
Jul 30, 2007 | D-Link DKVM-2K 2-port KVM Switch
D-Link (DKVM4K) (dkvm-4k) 4-port KVM Switch Logo
301 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
