Photosmart 7960 Q3020A CN411310FG Red light flashes. Displays: cartridge service station is stuck. Press OK Result: cartridge until moves freely but fault is still indicated
  • Anonymous Apr 17, 2009
    Have tried all your suggestions to "unstick" a cartridge service station, but it is not working. Any other ideas
    Sergeant:
  • 276 Answers
Unplug the power cord of the printer from the electric outlet and wait for 5 minutes then replug it.it should get resetted and start working.
Posted on Nov 20, 2008
  • 1 more comment
  • smarttech Nov 20, 2008
    http://cob.fsu.edu/tech/printermanuals/i...
    just click this link
    and read the troubleshooting column on page number 50 of this link and follow the instructions to resolve the problem manually.
    CARTRIDGE SERVICE STATION IS STUCK.
    There is an obstruction blocking the path of the cartridge service station.
    Clear any obstruction and press the OK button to continue.
    thanks.
    it also gets stuck up if there is a paper jam in the printer.
    1 Turn off the printer, then
    unplug it from the power
    source.
    2 Remove the rear access door from the back of the printer
    and remove the jammed
    paper.
    3.then ON the printer.
  • 10,515 Answers
Hey dude,
I had this problem with an HP Photosmart 7760 (was getting the message:Cartridge Service Station is stuck.. Press OK.
I followed your suggestion. Except instead of purple covered opening, I just found an opening that exposed a white gear. I turned it as far as I could. Then replaced all plugs, inserted paper, turned on printer......
And presto!! It printed some last item sitting in the buffer and is now working perfectly.
If it will not resolve, We wld start from the bsics :-
. Turn the computer off and unplug the power cord from the back of the
printer.
2. If the printer is connected to the computer, unplug the USB cable from the
back of the printer.
3. Remove any paper from the paper tray.
4. Tilt the printer up so that it rest on its back and the bottom of the printer
faces you.
5. Locate the access hole on the right side of the bottom of the printer.
The access hole may have a purple cover.
6. Remove the cover by turning it counter clockwise.
7. Roll the white gear downwards until it stops.
8. Plug the power cable and USB cable back into the back of the printer.
9. Press the power button to turn the printer back on.
10. If the print cartridges are not installed, install them now........
*****I Hpe i have taken cre of ur needs 4 tday****************
Take Cre.
Why can't I find the ink level of my HP 7960 printer the way I did with Windows XP?
The ink levels are a feature of the HP software. What probably happened is that when you had WIN XP you loaded the entire software package which included the ink level utility and with WIN 7 you may have only loaded the basic drivers which does not provide this capability. Check the HP support site for a full software package and see if that brings it back.
Sep 18, 2014 | HP new photosmart 7960 inkjet printer...
Fast blinking red light, message says cartirdge service station is stuck
Solution
Follow these instructions to adjust the clutch on the printer.
Disconnect the USB cable.
Press the printer power button to turn off the printer.
Disconnect the power cord from the back of the printer.
Open the top cover of the printer.
Remove the print cartridges from the printer.
Slide the cradle to the right side of the printer.
Locate the clutch on the left side of the printer.
NOTE: The clutch is a flat, white, plastic component that rests just above the white roller gear wheel. In the HP Photosmart P1000 and P1100 printers, the clutch is black metal.
Figure 1: Printer clutch
Remove the rear access door from the back of the printer.
Press the clutch firmly towards the back of the printer, while rolling the wheels in the back of the printer upward two full rotations.
Release the clutch and roll the wheels up two more rotations.
Reinstall the rear access door.
Reinstall the print cartridges and secure the latches in place.
Close the top cover and reconnect the power cord.
Turn on the printer.
Print a test page.
NOTE: If the printer continues to display a Print cartridge cradle is stuck message or make grinding noises, click "contact hp" on this page for more support options.
May 26, 2009 | HP PhotoSmart 7660 InkJet Printer
HP photosmart 7960 gives message Cartridge Service station is stuck. Cannot see a jam or obstruction...any suggestions?
Unplug the Power Supply from the Printer.......
Remove both the Catridges from the Printer.........
Just Move the Catridge Carrier which Holds the Catridge Back and Forth for about 20 Times.........
Insert the Catridges back to the Printer.........
Turn the Printer On...........
Good Luck.............
Apr 04, 2009 | HP PhotoSmart 7960 InkJet Printer
Printer won't work
Let me guess, it moves freely otherwise but when it needs to print it fails? Sounds like the service station is broken. Sorry
Mar 21, 2009 | HP PhotoSmart 7760 InkJet Printer
I have a 7960 photosmart printer when i turn it on it goes to a screen which states" Cartridge service is stuck press ok" Ive taken out all jammed paper removed back panel saw no additional paper. it also...
the automatic cartridges cleaning is stuck, probably a mechanism dead or maybe a bit a dirt from ink splash. open it and try to clean it and check for any weird thing, you can do some cleaning but the mechanism need some greassy spot so do not be too clean. Cleaning with water.
There is also a thin small plastic band as long as the printer that the printer head use as guide, It's like a scale but transparent. Clean that one too. Try to run it when the printer is open, you will have to puch some button to make it run. you might see where the problem come from...
cheers
Dec 18, 2008 | HP PhotoSmart 7960 InkJet Printer
solution for...
" CARTRIDGE SEVICE STATION IS STUCK " with a blinking red light...
it's a bit difficult...just fixed it today....
first of all...u have to be sure that your service station is clear from any other old ink that maybe dried....that stuck the movement of the service station...
if it doesn't work again...folow the next step...
1. u have to pull out the service station... ( the difficult one ..!!! )
2. under the service station, there is a small motor....just find a new one and change it..
it works...
.....i found this new motor in an old hp printer's service station that i have...
thank u
Jul 04, 2008 | HP PhotoSmart 7760 InkJet Printer
Print cartridge stuck
Hi please click on the link below to know exactly what you need to do to fix paper jam problem.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpd09128&lc=en&cc=us&lang=en&rule=1823&product=77146&dlc=en
Please let me know if it fixed the problem or not.
Cheers
Jun 10, 2008 | HP PhotoSmart 7960 InkJet Printer
Make sure the cover that holds the ink cartridge in place is completely closed down on the cartridge. Also make sure there is not a pencil or something under the cover where the ink is , obstructing the print head
Jun 15, 2007 | HP PhotoSmart 7960 InkJet Printer
420 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
