Question about Samsung CLP 300 Laser Printer
BLACK TONER SUPPLY ERROR
HI. MY PRINTER KEEPS SAYING " BLACK TONER SUPPLY ERROR". I DON'T KNOW WHAT THAT MEANS, I CAN'T FIND IT IN THE TROUBLESHOOTING SECTION.!! I JUST CHANGED THE BLACK INK CARTRIAGE AND THAT INK WASTE STORAGE THING. MY CYRAN COLOR IS LOW, I DON'T THINK THAT HAS ANYTHING TO DO WITH IT. WHEN THE ERROR COMES UP IT WONT PRINT, I HAVE TO TURN IT OFF FOR A COUPLE SECONDS THEN BACK ON REPRINT IT THEN IT WORKS, HOWEVER THERE IS A LIGHTER INK BAR RUNNING VERTICAL THE WHOLE PAGE AND ABOUT 2" WIDE. PLEASE HELP. THANK YOU
  • jlhsi Nov 20, 2008
    I can't find my answer.
  • kbarrie Nov 26, 2008
    My printer keeps throwing a BLACK TONER SUPPLY ERROR message. The black toner cartridge is new, I even replaced it with another one thinking the first one was bad. I turn the printer off and now I get a faded area print on the left side of all documents. I have checks to print and need any answer
For anyone with a similar issue viewing this page (like me), first take a look at this video: http://www.youtube.com/watch?v=Ipw1RjwzUDg
You want to follow those instructions and see if they work for you. If they don't, which they probably won't, take a look inside the black toner transfer unit (by removing the metal plate with the 5 screws, see video for further instructions), if the transfer unit is empty then this probably means the printer does not supply enough toner to the transfer unit. You could compare the amount of toner inside the transfer unit with that of another colour and you'll will probably find that there is comparatively barely any black toner in there. A temporary fix would be to manually add toner to the transfer unit by simply pouring it in there, after which the printer should print perfectly again. You might need to actually drill a hole in the black toner cartridge or buy a toner refill kit. Of course this is only a temporary fix and you'll have to do it again once you get the same error message. Unfortunately I'm not yet aware of a permanent solution.
Posted on Mar 06, 2013
2 Suggested Answers
  • 479 Answers
SOURCE: Printer worked fine for a long time, then black
Issue seems to be linked with the printer's scanning unit.
Thanks
Posted on Jan 04, 2011
I had newly replace the black color toner cartridge into my hp cp1515 printer but the LCD still shown re-install the toner cartridge and 10.1000 supply memory error. Please advice. Thanks.
The error says that the black cartridge e-label is missing.
Pull the black toner and make sure packing tape isn't covering it up.
Compare the black toner to one of the other ones to make sure that it isn't missing the e-label.
If you put the old black back in the printer, does the error go away?
Feb 14, 2011 | HP LaserJet CP1515n Printer
TROUBLE SHOOTING AND ROUTINE MAINTENANCE
Click here to visit Brother Official Support & Download page for DCP-7030. User Guide, Troubleshooting information etc are available. You can also search for specific issues from the troubleshooting section. The most important point as far as routine mainenance is concerned is I think keeping the printer clean, using good quality paper and genuine supplies/toner.
Let me know if any further clarification/ assistance is required.
Hope this helps! Good Luck!
CreativeTECH
Jan 10, 2011 | Brother DCP-7030 Digital All-in-One Laser...
Put in new toner into KonicaMinoltaBizhub200,says exchange toner
Machine is still saying to exchange toner because toner is not feeding into the machine. to supply the toner always do this, 1-insert the new toner bottle in the toner section and close the cover. 2-Press "Utility/Counter" Button. 3-click on "USER CHOICE" or "USER SETTING" 4-click on "Toner Supply" 5-Toner bottle will start moving and hence the error message will not appear again.
Oct 27, 2009 | Minolta bizhub 200 All-In-One Printer
It is not printing the document. the message coming says ' supply error'.
This means the toner chip is damaged or missing or can't be read from the printer. If you have changed the toner recently, or have a third party toner in it. You need to replace the toner and if the error is still there then you know it is the reader failing.
Aug 23, 2009 | Office Equipment & Supplies
COF36 error on a Bizhub C350
Hi
C0F36 error means abnormally low toner density detected Black ATDC Sensor. Check for the black toner and try reinstalling the cartridge if replaced already. And if the toner crtridges are empty then replace the cartridge.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Apr 21, 2009 | Konica Minolta Office Equipment & Supplies
HP 2840 *(Error Message) = replace supply using black only Will only print in black All color and black toner are 75% or more full The drum was low so I replaced it just in case but error message remains.
By repalce supplies, it means that you have to replace the other toner cartridges and that it is only going to print black only
Al
Eliteprintersolutions@gmail.com
Apr 14, 2009 | HP LaserJet 2840 Printer
OKI C3400 printer keeps saying
Okay, I had the same problem with my C3300. I phoned the people i purchased from and this is what fixed it for me:
looking directly at the printer:
-open printer
-remove drum in question (the drum is what houses the toner cartridge) in my printer it is black.
-look on the right side of the drum & there is a little (approx 5mm x 5mm) hole that has a little panel that opens- push this up to open it.
-replace drum close the top and try printing.
I had to do this 2 times before it worked, but it worked.
Jan 19, 2009 | OKI C5100n Laser Printer
Gestetner dsc38 error code
You have an improper black toner density. Likely your black toner suction mechanism is clogged or the black toner supply clutch is not working.
Feb 21, 2008 | DSC GESTETNER - DSc38u Color Printer
Toner install error
they could be a knows fulty black toners for these do u have all latest software is ther firmware update for the machine avb tonner droped in very well instaled lid latch broke
Jan 29, 2008 | Dell 3100cn Laser Printer
My printer is not printing
My printer at work kept saying it was low on black toner. I finally replaced when I got the message Black toner supply error. I gave it a minute or two to adjust itself and when that didn't work, I turned off for about ten seconds and then restarted it. I've only had two problems with this printer and I have had to turn it off both times before it would work perfectly, if that helps anyone.
Nov 05, 2007 | Samsung CLX 3160fn All-In-One Printer
Samsung CLP 300 Laser Printer Logo
239 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
