Question about E-Machines eMachines Desktop PC
Unable to find replacement motherboard for e-machine 5220
The replacement is seen as the solution to the curent problem where the PC shuts down the systen randomly and leaves the power and fans on.
No error messages are generated, no problems rebooting.
However, everyone seems to say - forget that solution get anew system.
Is the situation really that hopeless?
  • Mark Kessler May 11, 2010
    Have you tried replacing the power supply to see if that may be the cause?
    Sergeant:
  • 207 Answers
JS,
If your current system meets your needs, then there should be no reason to COMPLETELY replace it due to a problem that probably isn't ON the Motherboard.
The symptoms you describe CAN come from a number of different things. I will list them in the order that I believe is the likely cause.
1.) Bad power supply - If the motherboard isn't getting enough power, or is not receiving the right "Power on" signals from the power supply that can cause your problem.
Solution: Remove the Motherboard connector(s) from the motherboard there should be one atx connector (Long 20pin connector) and anywhere from 0-2 12V (4pin square connector) on the board.
When you do so look at the connectors (On the cable & the board) look for any scorch marks.
If you find scorch marks there was likely a short in the system due to a power surge and there could be damage to you PSU (Power Supply Unit) and/or CPU, and/or Motherboard
If you don't find scorch marks then blow in the connectors (To clear any accumulated dust) [Canned air would be best but if it's not in you finances you can just blow in them yourself]
Then reconnect your PSU connectors Then give it a shot again. If all is well we've found the problem. If not you might invest in a PSU tester, which can be found at most electronics/computer stores for around $20 USD and use that to check your power ratings.
2.) Overheating; If the temperature of the CPU gets TOO hot most "Newer" motherboards (Late 90's forward) have routines in their BIOS for checking the Temp of the CPU. If it gets too hot they will "Power down" the System but leave the fans goin to cool off the CPU.
Solution: Overheating can be caused for a number of reasons. Vents/Fans clogged with dust(Particularly if there are smokers around the PC), a failing fan, Thermal breakdown of the "Thermal pad/paste between the processor and the Heatsink. ..... Blow out any dust using compressed air(no substitution this time can't get any moisture on the board) check to make sure ALL the fans are spinning when the systems on, If necessary get a new thermal pad/arctive silver from your local computer/electronics store. Clean any of the old pad/paste from the CPU & heatsink using Qtips and rubbing alchohol (When handling the CPU be careful NOT to bend pins) make sure to dry off any excess Alchohol then let "Air dry" for about 15 minutes before applying the new pad /or paste(Arctic silver) If using a pad, place this on the heatsink where you cleaned up the remnants of its predecesor. If using paste, squeeze an amount about the size of a dime over the "Core" of the CPU (Usually raised a bit (If its not obvious WHERE the core is just apply it to the center of the CPU).
Spread it evenly over the CPU (do NOT use your finger for this. Oil from your finger can dramatically effet the pastes performance) then Rapply the heatsink.
3.) Bad RAM: If a memory module goes bad it can bring the whole system down with it.
Solution: Theres a freeware app available on the web called "Memtest86" that will be able to check your memory modules for fault and if it finds a problem can even tell you what DIMM slot the bad RAM resides in. Run Memtest (Be forewarned this WILL take a long time. I usually allocate several hours to wait for this to finnish. But check back regularly [in case the problem exhibits itself again])
If the memtests finds bad RAM replace it with the same sized module (Or if you preferr since you have to replace ram anyway, THIS might be a good time to update it)
Hopefully this gets you back up and running, If not please post your results back here and we can further help you.
Thanks
Dave
Posted on Nov 20, 2008
    President:
  • 2,992 Answers
Try www.blueraven.com. I've gotten a number of system boards from these folks.
But before you decide the system board is bad, you might want to try another power supply. The ones emachines uses are known to be a common problem.
If the system board is bad, another option is to purchase a new board from any of the many online sellers (I like tigerdirect.com and newegg.com). The case takes a standard system board, not some special proprietary design, so you can put in any one that fits and uses the same processor. Then you can reuse the processor and memory from the old board. New system boards start at only about $50, and you can find them on ebay for even less.
If you decide to replace the board with something other than the original, unless it's the same brand, chipset and features as the original, you won't be able to use the emachines software recovery CD. You'd need to install a new copy of WIndows, but you should be able to activate it with Microsoft using the product key on the computer. Preloaded systems don't make you activate Windows, it's already done.
(I'm doing this right now for a friend's Acer. His system board died, so I'm putting in a new one and a better processor and more memory as well. Parts cost for all the new stuff is $147, and a replacement original system board would cost $199. He'll get a better computer for less money this way.)
Unrecognized usb ports
If you have pulled too much curent through a USB it will be shut down. A restart of the computer should bring the port back-leave whatever you had plugged into the port leave disconnected.
Mar 12, 2014 | E-Machines eMachines Desktop PC
Suddenly stopped working ,won't restart my PC?
First of all disconnect all peropheral connected to your motherboard. Take out Your RAM and clean it with soft clothe. Reinsert ram and restart your PC. If you can get display at this point then shut down your PC connect all peripheral back and restart your PC.
If not you will need to replace your ram.
Nov 29, 2012 | Computers & Internet
Presario f750us, push power button it lights up and goes right back off
I have seen another Presario desktop with this problem, and it was dust in the front panel jamming the switch on. Pushing the switch turned the machine on, but because it stayed on, after 4-5 seconds the PC shut down again.
I had to remove the front panel and clean out all the dust, then lubricate the switch movement.
Dec 19, 2010 | HP Compaq Presario F500 F700 and G6000...
My E machine 5220 keeps shutting down leaving just the amber light on the front of the tower lit.
eMachines are known to have cheap/bad power supplies.
If you have access to an extra good working supply you can disconnect the power supply from the computer with out removing it (unpluged of course), and connect your good one as a test.
Power supplies are very inexpensive off of sites like Newegg, Pricewatch, etc.
Do this right away.
You don't want a bad power supply to burn out your motherboard, and, or, CPU and end up costing you more to replace.
Also It could be possible something is overheating too and causing the machine to shut down.
Open the side panel and make sure the CPU fan is spinning freely when the power is on.
Some times what happens too is a machine can get so full of dust, dirt, and, or pet hair that the whole CPU fan and heat-sink get blocked so air can flow through and around them.
Jul 29, 2010 | E-Machines T1862 PC Desktop
System Shut Down while playing online Games , without error message or sth
Does the PC do graceful shutdown or shuts down straight away?
If it does graceful shutdown perhaps make sure you are not pressing a shutdown button or sleep button.
If the PC shuts down completely without warning first thing to check would be the fans and interior of case in case is full of dust.
Oct 22, 2009 | Packard Bell Computers & Internet
Not working
Here is some great PC solution by Some FIXYA EXPERT. Get any kinds of PC solution from bellow.
  1. Intel MotherBoard
  2. Mercury Motherboard
  3. Gigabyte Motherboard
  4. MSI Motherboard
  5. P5GC-MX/1333 Motherboard
  6. via
atttererawe19
Apr 10, 2009 | A-Trend ATC 5220 (ATC-5220) Motherboard
Emachine 5220 keeps tuning its self off
I think the problem  may be that your operating system  may have gone corrupt
try  to enter the Safe mode  (if you can )
and see if you can  revert back to old settings and whether it helps or not
else   you would have to
  reinstall the whole operating system
Nov 09, 2008 | E-Machines eMachines Desktop PC
Cmos checksum bad...usb current status detected system shut down 15 sec
cheak bios settings diable serial port parrel and any onbord stuff u wont use ok
Feb 01, 2008 | ASUS P5LD2 Motherboard
E-Machines eMachines Desktop PC Logo
74 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
