Question about Black & Decker B2300 Bread Machine
Hard crusts Every time I used my B2300 machine the crust is very hard and thick. Is there a secret to not having that happen? I've stopped making bread for that reason.
  • Anonymous Mar 26, 2014
    crust color button
    Problem Solver:
  • 14 Answers
I have an OSTER Breadmaker but if I wish a very light crust I simply turn the machine off 10-15 minutes early and leave the lid closed, which keeps the steam in and allows the crust to be softer. Then I have a new cold stick of margarine or butter, unwrapped part way, and slowly pass it over the top and sides of the new bread loaf. Sometimes due to weather changes or altitude we need to adjust our recipies, from those in our manuals. If your kitchen is 10-15 degrees warmer in the summer this can affect your machine. As with the amount of moisture in the air. My Gramma never made bread if it was rainy or a snow storm was brewing. The drop in air pressure made it uncertain if her bread would rise. Don't be afraid to fiddle with your recipe and adjust the amount of flour or kind of flour you use. Also have all ingredients at room temperature, for any recipe. Try various amounts of oil, water, an egg added, even if the recipe doesn't ask for one..! It is your bread and you get to eat it, it should be as you like it. The first adjustment is less time. Pull the plug early. Second would be the margarine. Third is play with the contents and adjust. Feed the birds the NOPES. Last reduce the amount of flour, but only by 3 tbsp at a time. This is the trick-y-est. Keep track on a paper and then re-write YOUR RECIPE on the inside front cover of your bread book.
Posted on Nov 21, 2008
The top of my crepe maker has started to peel. How do I repair it?
After a while, a crust forms on the plate which may give the impression that the metal is flaking off. In fact it is just the crust of the crepe batter. Remove it with a metal spatula and rough sand paper. Do not worry about scratching the metal. Do not use a portable electrical device.
Once you have cleaned the plate, you will need to season it again as if it were new. It is best to scrape off some of the crust from time to time to avoid the crust from becoming too thick. Use the special abrasive stone in a circular movement.
Jul 23, 2015 | Waring Commercial WSC160 Electric 16in...
Kneading paddle gets stuck in loaf after baking and is hard to remove
Hi, it is common for this to happen with bread machines. It often helps if you have a modern machine and you can choose the crust color and you choose Light Crust. The other thing you can do is if you are using recipes that use water in the liquid phase use milk instead. If you paddle still sticks then you just need to turn the loaf on its side and use a popsicle stick, tooth pick etc and trace around the loaf where the paddle is and dig it out.
Aug 09, 2011 | Kitchen Appliances - Others
My panasonic SD 255 breadmaker, after quite a lot of use, is now baking bread with a harder crust than it did in its youth. We can get a softer crust by using the Sandwich loaf setting but then we can...
You never said if you remembered to select the LIGHT Crust setting each time. Did you? Are you? If you ARE using the LIGHT Crust setting and finished loaves are still too dark, I would have to say it's time for a replacement breadmaker. Nothing lasts forever my friend. Besides, it sounds like you got your money's worth anyway, right?
I've owned over 200 breadmaker myself so you can bet that what I'm saying is true. Sorry for the bad news friend.
Hope this helps!
Jun 15, 2011 | Panasonic SD-YD250 Bread Maker
The crust of the bread is thick and hard. What is
Are you using water? Water will make a crust crunchier, while substituting milk will give you a squishier crust. Also depends on what kind of bread you're making.
Aug 06, 2009 | Breadman Kitchen Appliances - Others
The bread is too dry
Welcome to FixYa, if you appreciate our solution, please rate our services.
Breadmakers usually don't have as many crust settings as this one does. Darker crust settings usually equate to dryer bread because the bread bakes longer. The longer the bread bakes, the more moisture is removed. Accordingly, if you've tried this many recipes with dry texture, try progressively lighter crust settings until you get the moisture you desire. As for me, I rarely bake my bread in the machine (I don't like the hole in the bottom of the loaf). I do, however, appreciate the dough setting which does all the hard work, and I just bake it in the pan. I think the results are better and I get a better shaped loaf.
If this information has been helpful, don't forget to give me an appropriate rating. Thanks again and good baking!
Jan 30, 2009 | Black & Decker B2300 Bread Machine
Crust is too hard!
First be sure your dough consistency is correct.
It should be very soft almost sticky. To make it a bit softer you can
add an extra tablespoon of fat.
Oct 22, 2008 | Toastmaster 1193 Bread Maker
Hard crust
Do you take it out right away?  If you let it rest in the machine for about an hour the crust stays soft as the bread sucks back in the moisture it gave off during baking.  Doing this does not make the bread soggy.  It's just physics.  If you take the bread out immediately the heat (+moisture) will be drawn out and diffused into the cooler environment.  Hope this helps.
Oct 17, 2008 | Sunbeam 5891 Bread Maker
Miele dishwasher film and crust on the inside-
Hard water has this "crust" which are minerals floating around that ionically attach to everything. Some machines from Miele have a water softener inside the machine. Special dishwasher softener Salt is added that cleans minerals off Xeolite beads. When cleaned they attract mineral ions. If you don't use the salt then the beads fill up on minerals until they can't hold any more minerals. The salt is used in the regeneration cycle. It washes the mineral ions off the xeloite replacing them with salt ions. As new water enters the machine mineral ions slowly knock off the salt ions and attach themselves to the beads again. This whole process keeps the crust off the dishes and the walls of the machine.
Use a dishwasher cleaner that removes scale. And if you don't have a salt light on your Miele you can instead purchase soap tablets that contain water softener built in. Miele dishwasher tablets have it. You can order them online or call Miele.
Dec 17, 2007 | Miele 23 in. Novotronic G841 Built-In...
Black & Decker B2300 Bread Machine Logo
234 people viewed this question
Top Black & Decker Kitchen Appliances - Others Experts
Greg Cann
Greg Cann
Irene Tulloch
Are you a Black & Decker Kitchen Appliances - Other Expert? Answer questions, earn points and help others
