Question about RCA 20F530T 20" TV
  • m1keshay Sep 25, 2008
    Color onscreen is tinted red but blue and green are perfect in Menu operations. I do get true black and white with color turned all the way down. Tint control doesn't come close to correcting problem.
  • 308 Answers
If, when you turn down the color control all the way you have a black and red picture, then your picture tube is most likely weak and it's time to replace the set. If the black and white picture is normal, then the set could have a problem in the chroma circuit. Either way, it would not likely be worth repairing.
Posted on Dec 16, 2006
Display colors are all wrong
This may have to do with your Windows Theme settings.
Step 1. Right click on your Desktop and click Properties
Step 2. Click on the Themes tab
Step 3. Select a different Theme (try the Classic Theme)
See if that solves your problem.
Sep 24, 2009 | HP G60-230US Notebook
Viewsonic VP930b color problem - Red tint
Go to the setup menu on the LCD panel by pressing button 1 on the front. See if there is an option to reset the lcd to factory settings. Reset it and report if it helps not.
Jul 29, 2009 | ViewSonic VP930b 19" LCD Monitor
Can"t find white or comfortable background screen other than a light green that is hurting my eyes
If you have a screen that gets "tints" of various colors on a corner or edge, check that the monitor plugin cable is not near or laying on top of a power cable, the magnetic field around a power cord will cause a monitor to get strange tints or lines in the screen. Option two if the entire screen has a tint equally all over it is possibly the color is out of adjustment or failing - a technician should be able to adjust it internally.
Apr 29, 2009 | AOpen A75PF Monitor
Red lighting in background of photo
Many digital cameras have different settings for the background color, my Samsung L200 for example has a setting that will make the pictures normal, black and white, sepia OR have a red, blue or green may want to check those settings... Otherwise... check to ensure the lense itself is not smudged... I have seen a smudged/dirty lense cause a similar issue.. what type of camera is it??
Feb 15, 2009 | Samsung L200 Digital Camera
No blue just red and green tint
adjust the blue bias on the high voltage block .
it has focus and bias for all three colors
Dec 26, 2008 | Samsung PCL5415RB 54" Rear Projection...
Background has a bluish tint instead of white
the lens , glass inside your scanner is dirty with dust you need to clean this up and calibrate once again cheers
Nov 26, 2008 | Canon CanoScan 9950F Flatbed Scanner
Too much green color
Problem solved. I tried playing DVD and the TV picture was fine. So I double-checked cable wires from cable box - one of the wires was loose (obviously it was the red color input). After tightening, the TV picture is good as new.
Mar 20, 2008 | Sony FWD-50PX1 50 in. HD-Ready Plasma...
Picture is Red Tint (Execpt Menus)
Did you ever find out what it was?
Oct 14, 2007 | Polaroid FLM-3201 Television
A constant red tint problem (AV-56P787)
This is an indication that the red gun is being driven too hard. Have you tried to adjust the red color control? If not try this first and if the control can not adjust the color then you will have to find out if the control grid on the red tube is working and has the proper voltages present. Which you will need the following equipment to do. Multimeter Oscilloscope Along with these you will need a schematic to show you what the signals and voltages should be. And I might also suggest having a pattern generator and using the color bar signal since more then likely that is the one being used in the schematic as the reference signal.
Mar 11, 2007 | JVC AV-56P575 56" Rear Projection...
Red screen
how to lower the red screen voltage?
Nov 07, 2006 | Sony KP-53HS30 53" Rear Projection...
RCA 20F530T 20" TV Logo
314 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
