Question about SAMTRON 55V 15" CRT Monitor
Monitor disply movable horizontal lines.
Here is the samsung skymaster model.in this, when i switched on monitor it start normally but some problem in display . disply is normal in size but movable(blinked) horizontal line is appear fully on display.
  • 348 Answers
Yes you first check the supply at vertical ic 12v if present then replace that vertical ic if supply is not present then check the regulator ic in smps if faulty then replace it
Posted on Nov 20, 2008
Samsung syncmaster magic cx 715B my samsung cx715B monitor, have a multiple horizontal line.what is the solution of this?
The multiple horizontal lines are indicative of screen failure. There really is no repair, except to replace the display.
May 05, 2015 | Samsung Computers & Internet
Monitor
Try getting anything that may have a magnetic field away from the LCD (speakers, phones, any electronic product), does the problem persist?
Jan 08, 2008 | Samsung SyncMaster 245BW Monitor
Samsung T240 Problem
try check the cables and connection
Dec 17, 2013 | Samsung SyncMaster T240 Monitor
Pink and Green Horizontal lines across screen
Normally, horizontal lines on an LCD or LED monitor indicate a bad control board inside the monitor. However, occasionally the problem can be caused by loose or bad cable connections. The only things that you can really do is to disconnect both ends of the monitor cable and reconnect them firmly. Also, you can disconnect the monitor cable completely and just leave the power cable. With only the power cable attached, you can turn the monitor on and off. The monitor should have a "startup screen" or display a message that says something like "Video Cable Disconnected". If the green and pink lines are still present without your computer connected, then the monitor has gone bad. The good news is that Samsung SyncMaster monitors usually carry a 3 year warranty, whereas most monitors only have a 1 year warranty. You may be able to have the monitor replaced at no cost to you if it's less than 3 years old.
Jul 27, 2013 | Samsung SyncMaster Computers & Internet
Monitor has horizontal lines on half the screen but only sometimes
I would just replace it, the cost to troubleshoot and repair will be more than new.
Jul 13, 2017 | Samsung Computers & Internet
Horizontal lines obscuring images at bottom of screen.
well your prediction is right you just have to replace the monitor or if it is in warranty period just drop in to the samsung service center so they might help you.
Jan 04, 2010 | Samsung SyncMaster 193V 19" Flat Panel LCD...
Green vertical line is coming in the middle of the
monitor is probably going bad. Try hooking up a different monitor up to the computer, one that you know works properly. If the same problem exists then its the video card, if the problem goes away then its the original monitor that is bad.
Aug 16, 2009 | Samsung Computers & Internet
Monitor No display
1. Power is comming or not.
2.Check Horizontal Transistor.
3. Disply cable. 1,2,3, pins & 13, 14 pins continuty.
4. Filament supply , drypoints in neck board.
5. filament supply diode, capacitor.
Oct 23, 2008 | Samsung SyncMaster 551 15" CRT Monitor
SAMTRON 55V 15" CRT Monitor Logo
130 people viewed this question
Top Samtron Computers & Internet Experts
Daniel Sweetlin
Daniel Sweetlin
Level 1 Expert
Richard Lilja
Richard Lilja
William Miller
William Miller
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
