Question about Samsung TXE2546 25" TV
An oval-shaped rainbow-like colour pattern shows first, then, in a few minutes, picture starts to appear from the bottom and gradually extends towards the top thought never completely reach to top edge. When the picture is below the bottom edge, the TV usually shuts off. Flickering occurs all the times. Sounds work OK. The model of the TV is: Samsung TXE2546 Couldn't find anything outside of the TV to adjust verticle or horizontal position. Thanks for your help in advance!
    Sergeant:
  • 308 Answers
It May be due to one of several things. You could have some bad filter capacitors that are allowing electrical "noise" to disrupt the video, or there could be a bad solder connection or crack in the circuit board allowing a ground to "float", or there could be a problem in the Degaussing circuit, although that would be my last guess. I don't recall ever having that particular problem with any sets in my shop.
Posted on Dec 16, 2006
Olympus u820 image distortions colour and form
One answer time for a new camera the cost to repair is about the same as new.
Mar 15, 2017 | Olympus Stylus Stylus 820 µ Digital 820...
Tv has picture but blurry almost double picture but not quiete also has oval shape purple colour bottom center
for blurry picture,try rotating your antenna or repositioning it,as it is caused by reflections of signals.
for the purple spot,try shifting yur TV to another place in the room or repositioning it.
Aug 23, 2010 | Televison & Video
Rainbow e2 system. Will not power up
the water basin has a safety on it so the unit cannot run without it. if you look on the bottom of the rainbow you can see a small oval shaped space that you can depress just to test and see if it still runs it will only run with this depressed.
Oct 11, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Hitachi TV: 35TX30B Window in upper left view that won't go away
you using a digital desk top box with it ?
an old school tv
solid state old analog
what you are seeing is called picture in picture
one of those split screen functions of years past
remote may have a function button on /off for that
user manual for one
Hitachi 35TX59K 35TX50B 35TX30B Manuals
Apr 06, 2017 | Hitachi Televison & Video
Fuzzy picture, oval shaped, scrolling up slowly
I would start by checking the large filter capacitors in the power supply. I can't be sure since I'm not seeing the set, but it sounds like you're describing AC ripple. In a 20-year-old set, some of those electrolytics will be drying out. A few replacements may take care of the trouble for you.
Jan 01, 2009 | Panasonic PT-56WXF95 56" Rear Projection...
VS-50803 50" Mitsubishi No picture problem
Sounds like your picture tube has went out,, or maybe something simple,, to fix,, i would at least let a tv shop check it out ,, worth a chance ,, nothin 2 loose,, good luck
Oct 05, 2008 | Mitsubishi VS-50803 50" Rear Projection...
Colourful picture
Discoloration of this sort is caused by magnetism. All CRT TVs (like yours) have a de-gaussing coil around the picture tube that de-magnetizes the screen (more specifically the shadow mask) every time you turn it on. It is likely that the circuit that controls this coil is at fault. There is probably a cold solder joint where it connects to the main circuit board.
The other scenario is that someone (small child generally) has run a magnetic object very near to the screen, magnetizing the shadow mask (inside the picture tube) and causing a rainbow effect. This is less likely if the rainbow effect is a nice even circular shape. Generally if it's been magnetized by a magnet as described the discolored areas will appear blotchy.
In short, if you have some electronics skills, get in there with your soldering iron and touch up the connections to the de-gaussing coil. If not, find someone who does.
Oct 01, 2008 | Televison & Video
Plasma Problem
It could be the Logic board or/and one of the Logic Scan board failure. Parts availability depends on maker and may cost any where between $250 - $500. Labour depends on shop. Hope that'll help you. Good luck.
Jan 26, 2008 | Televison & Video
Televison & Video Logo
132 people viewed this question
Demonic-2011
Demonic-2011
Steve Allison
Steve Allison
