Question about GE Profile Spectra JGBP79 Gas Kitchen Range
Oven not heating
Hi, hope you can help me with this one. The oven is suddenly not heating. It's dead. All other functions seem fine. I press 'bake' then 'start' and the normal couple of clicks happen, but the ignitor doesn't heat, thus, no gas. No gas, no Christmas cookies. The broiler is fine. There is no error message displayed. I unplugged/replugged it several times hoping that would do something; no luck. Where do I start?? Thanks for any advise. If you fix the problem I'll send you some cookies!
  • 1 more comment
  • Nancy Irons Dec 16, 2006
    Thank you and yes, that's something I'll attempt myself. Any assistance would be most appreciated.
    You were right!!! I was able to get the part locally this morning and just finished installing it. Not too difficult, only took about an hour and cost less than $55. The oven is cured. Thank you so much! Where shall I send the cookies?
  • bostonbaker Dec 26, 2007
    I have this same problem, which I thought was caused by the tiny red gas lever (under the warming drawer and to the back left) being bumped to the OFF position. However, after moving it back to ON, per the owner's manual instructions, I still have no function in the oven -- there is no clicking, nor is there any lighting of the gas flames. (The sealed burners on the stovetop continue to work without issue.) If anyone has experienced the same problem, I would appreciate advice. At this point, I am thinking that if this involves a service person coming it, plus labor to fix whatever might be wrong, that a full replacement of the appliance might be the best bet overall. This came with the condo, I think it was inexpensive (~$250, from what I have read) and was new in January 2002. Thanks for any input!
    Scholar:
  • 76 Answers
Nzirons, Most likely, the bake igniter is shorted out and it has to be replaced. The part number for the igniter is WB2X9154.You can buy it for $60.00 to $80.00. If you are handy and have the right tools (Philips #1 and straight 1/4" screwdrivers, 1/4" and 5/16" nut drivers or socket wrenches, wire cutter and wire stripper) you probably can do it yourself. I would recommend to call a local appliance tech. just because of the safety issue. If you are going to do it yourself, let me know and I can help you with step by step instructions. Gendos
Posted on Dec 16, 2006
  • Gennadiy Kagan Dec 17, 2006
    I am glad I could help you. Unfortunately, I do not eat cookies because I'm on no carbs diet. Thank you for your comment. Merry Christmas!
    Gendos
Oven will not heat at all. Stovetop works fine
Phillip, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Oven Wont Heat or Not Working Bake and Broil Element Testing Oven...
Electric Stove Troubleshooting Oven Not Working
Top 6 Reasons Electric Oven Wont Heat Electric Range Troubleshooting
Stove Terminal Block Replacement Frigidaire Electric Range Repair part...
Jun 17, 2016 | Kitchen Ranges
Kenmore electric range model 790 oven stopped functioning, both broiler and bake. however, oven light still comes on.
I believe there is a thermal fuse (also called a TCO or Thermal Cut-Out) located either on the back of the oven, or between the top of the oven and the cooktop that has opened up. Did this happen after running a self-clean cycle?
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Sep 09, 2014 | Kenmore Kitchen Ranges
I have a 30 inch Frigidaire self cleaning oven. The oven will no longer heat up in a normal amount of time using the bake function. Sometimes I can smell gas when using bake. It cant reach the desired...
Sorry to read about your problem, I hope this helps you out.
Bad gas control valve or oven temp control
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 22, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Oven slow to heat
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
May 10, 2010 | DCS RDS-364GD-SS Dual Fuel Kitchen Range
Oven wont bake
sounds pretty simple a bake element
Oct 03, 2009 | Jenn-Air JGR8750 Gas Kitchen Range
How do I use the self cleaning functions - kitchenaid oven
Please allow me to help you first with some background of self cleaning functions:
Self-cleaning ovens use an approximately 900 degrees Fahrenheit (482 degrees Celsius) temperature cycle to burn off spills leftover from baking, without the use of any chemicals. A self-cleaning oven is designed with a mechanical interlock (patented in 1982) to keep the oven door locked and closed during and soon after the high-temperature cleaning cycle, which can be approximately three hours. The door stays locked to prevent burn injuries. You can open the oven door after the oven cools to approximately 600 F (315 C).
If baking spills are not wiped up after baking, there may be some smoke during an oven cleaning cycle. It is a good idea to remove any pets from the area when running the oven's self-cleaning cycle. There have been reports of oven-heated Teflon-coated items releasing odorless fumes deadly to birds.
Self-cleaning ovens have the added benefit of more insulation, which helps the energy efficiency for regular baking. This is similar in concept to an increased R-factor for home insulation.
You will also save energy costs by using the self-cleaning cycle right after baking, to make use of the already partially heated oven.
Please check this website mentioned bellow which would give you a detailed method of how to perform it:
http://cleaning.lovetoknow.com/Self_Cleaning_Oven_Instructions
Hope this would help you .
God Bless.
Jul 05, 2009 | KitchenAid Kitchen Ranges
TAPPAN gas range model 30-3991-00/03 oven won't work.
the button your holding is the switch that tells the board that the consumer whats to bake.so if holding the switch causes that message to work[or oven to heat] and letting go of that button ,then no work .its that button ,but its all part of the board .just that part of its funktion is broken.,if it was lets say your oven ignitor or oven gas safty valve ,the board/oven control[the one with the button]would continue to try after you have selected bake [pushed button]or would give error code.hope that helps you. God bless you , tom
Jan 05, 2009 | Tappan Kitchen Ranges
GE Profile Spectra JGBP79 Gas Kitchen Range Logo
208 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
