Question about Audiovox VE-720 7 in. TV/DVD Combo
LED display is not working
Everything else is operational. The system is out of warranty. Is there a simple solution that I can fix myself? I guess the lightbulb is out, but it is my guess only. Thanks.
I get a hissing sound and it change from cabl to air by its self and picture is a little snowy too.
Posted on May 07, 2008
SOURCE:
My disto a8 tilt sensor is not working at all, its only the tilt sensor thats not working everything else seems to be working ok. when I try to turn on the tilt sensor- error 163 with a spanner symbol...
if it is still under warranty then you are simple if you do not have it repaired under warranty
it could be a major fault but as soon as you carry out a fix the warranty is void regardless of the fault
while everything else appears to be working , there could be something else somewhere that is the actual cause of your problem
Sep 02, 2017 | Leica DISTO A8 Rangefinder
Bose Lifestyle 12 Music Center DISPLAY display light number its not working anymore
I have had problems similar to this on many devices and it is usually a dud LED (light). You can technically de-solder the current LED and replace it but it's not a job for anybody without very good soldering skills.
Check to see if your system is still in warranty as this should be covered. Any electronics repair shop should be able to fix this for you.
May 08, 2011 | Bose Lifestyle 12 System
I have a simple problem with the SAITEK pro flight yoke. The LED display does not turn on. The usb is plugged correctly and the yoke functions correctly. All is working properly but the LED DISPLAY. ...
For how low have you had the Yoke?
This a known fault with the front display on the Yoke failing, it's caused by the LED's being faulty or a inperfect contact there.
If the Yoke functions correctly then it might be one of the above.
If you still have warranty, meaning if you purchased the Yoke less then 2 years ago, try to ask for a replacement for it either from the retailer of from Saitek.
hope it helps...
Apr 03, 2011 | Saitek Pro Flight Yoke System Flight...
My laptop battery i guess hit critical stage but now the system wont work with ac power
DC connector problem:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jan 26, 2011 | Acer Aspire 7520-5185 Laptop
My panasonic sa-ht70 led stop displaying . Everything else seems to be operating fine.
The front board will need to be replaced. The front board has the buttons(i like the touch buttons in the Samsung HT-Z320) and te display.
Jun 23, 2010 | Panasonic Home Theater System System
SOHC-4836V stopped working. Has this message...Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. (Code 19) Can I fix this myself?
if you have the installation disc for it you can reinstall the drivers
get the drivers from the internet and update it for your operating system...
(I'm guessing you either upgraded or clean installed a new operating system)
Sep 30, 2009 | Lite On Computers & Internet
Samsung HT-X40 also shuts off after displaying Protection
You probably have the same problem that myself and several others have had, and let me guess, its outside of the warranty? How good are you with a soldering iron? If you are not afraid to do some soldering you can fix it, check out these instructions that i found:
http://lemurt.wordpress.com/2008/08/18/defenition-of-waranty-void/
you will need 474k or .47uf 100v capacitors and a soldering iron, but you can fix it, worked for me.
Aug 08, 2009 | Samsung HT-X40 System
LED display stopped working
Hi!!! your clock or control board has malfuction.You can get access from the back of the unit pull the unit out and look at the back remove the screws..Your control board clock board went bad..Good luck..
Jan 04, 2009 | Belling XOU252 Electric Single Oven
RCA RTD315W Receiver/DVD LED display
If you are referring to the information display, it doesn't activate until you take the system out of standby (the bright blue LED at the corner is shining). When you hit the OFF button (on the system or the remote) and the blue LED shuts off, your info display comes on and says WELCOME.
Dec 27, 2008 | RCA RT2500 System
Known issue ?
My best guess from what you have said is that you may have some speaker wiring shorting (or bad speaker) or else you have a bad output transistor or a poor solder connection in the output amp area. If it isn't the wiring/speaker problem but the other then you will most likely need to see a repair guy to get it fixed. Hope this helps.
Mar 12, 2007 | Denon DHT500SD System
Audiovox VE-720 7 in. TV/DVD Combo Logo
Top Audiovox Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
