Question about Philips Audio Players & Recorders
My philips gogear sa 3245 froze while playing a song and once I pressed reset, it came back on. But the battery has gone from 4 bars to 2 - and it was fully re-charged last night. Is there a problem with the battery?
Upgrade the firmware. I had the same problem and it worked. Right now my fw version is 4.05/02
Posted on Jan 12, 2009
My go gear froze..."the music was playing and then it stop and froze on the song
try pressing the reset button it will NOT wipe off all of your music
Apr 22, 2010 | Philips GOGEAR SA6045 MP3 Player
My Philips GoGear MP3 Player is stuck
Been using this for a few months. Froze up on same song while on vacation last month, and continued to play same song on repeat until battery went down. Now is frozen with "Do Not Disconnect" as it was being charged on my laptop. Attempted to unplug and plug back in and Windows gives DO NOT DISCONNECT!!!!!
I am having the exact same problem!!!!!
Aug 02, 2009 | Philips GOGEAR SA6045 MP3 Player
My gogear freezes every couple of minutes!
Update the firmware first
It could be a hardware issue requiring replacement, but here are the things you can try to narrow it down:
1. Make sure the hold/lock is not engaged
2. Reset the player
3. Run an Updated using the latest version of the Philips Device Manager from Philips website
4. Run a Repair in Philips Device Manager
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
If these methods fail, call Philips to see if you are still in-warranty.
-Tha Mp3 Doctor
Mar 11, 2009 | Philips GOGEAR SA6045 MP3 Player
Philips GoGear Glitch
Make sure that there is available memory. If there is, then you will need to do a firmware upgrade and reload the songs onto the player. If you already have the latest firmware, then you will need to reformat the player either in Windows Media Player or the computer. If that fails, use the repair function in the Philips Device Manager.
-Tha Mp3 Doctor
May 28, 2008 | Philips GOGEAR SA6045 MP3 Player
8GB GoGear isnt working at all
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
Dec 17, 2007 | Philips GoGear HDD1830 MP3 Player
Resetting
To reset, press volume+ and play at the same time until the player shuts off.
Then:
-Tha Mp3 Doctor
Sep 11, 2007 | Philips GoGear HDD1830 MP3 Player
Uh oh
Reset the device first - volume + and play/pause at the same time while the device is turned on
if that fails:
-Tha Mp3 Doctor
Apr 14, 2007 | Philips HDD1630 MP3 Player
My Philips MP3 Player Won't Play My Songs. What Do I Do?
-Tha Mp3 Doctor
Sep 27, 2006 | Philips HDD1630 MP3 Player
308 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
