I used G program for washing. After washing, the washing machine drained out water and get water inlet for rinsing. Right-after it was full, it drained out and stopped immediately.
Did you try having the control board tested for faults?
Not yet. Please tell me how to test the control board!
You would need the equipment of highly trained appliance techs. They have special know-how and equipment that will test boards.
Thank you!
You think the problem came from the control board faulty? Any other reasons?
Some boards are made good, some aren't. The best advice to give is when you buy a major expensive appliance like this, ALWAYS GET THE EXTENDED WARRANTY!!! It will cover you on items such as control boards.
SOURCE: washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
My machine is Electrolux front-loaded washing machine, model No. is EWF 551.
I have checked and found no problem with the drain pump, hose, door switch. Does anyone help me? Can you give me the service manual of this machine?
