Question about E-Machines eMachines Desktop PC
CDRom stops working when I connect IDE cable
I am rebuilding my emachines 5220. The CD/DVD-Rom works when the IDE cable is not connected but stops working the moment I connect the IDE cable. I mean it loses power whenever I connect.
Any ideas?
    Genius:
  • E-Machines Master
  • 1,250 Answers
Put some different power connector other than you have used now, then check
Posted on Nov 20, 2008
When IDE cable is connected to CD ROM, CDROM is not working
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
Dec 22, 2010 | Intel 865G Motherboard
Emachine ET1331G-03w Documentation
To install an IDE CD rom, you will need to open your computer and you will see an IDE Slot, your computer usually has two of them either directly next to each other or under each other, there is usually one white one and one blue one. IDE Slots look like this:
The white IDE Slot is usually for the Hard Disks and the blue IDE Slot id usually for the CD Roms.
The white IDE Slot is the Primary Slot and the blue is the secondary.
You will need an IDE cable to plug in to your blue IDE Slot then you will need to plug the cable in to your CD Rom and make sure that your CD Rom is set to run/work as the master. If your computer only has one IDE Slot or you do not have an extra IDE Cable you can plug the CD Rom in to the Primary IDE Slot with the Hard Disk assuming you are only using one Hard Disk.
If you are going to use the Primary IDE Slot you will need to make sure that your CD Rom is set to run/work as a slave and it must not be set as the master. The way to change it is by moving the pins at the back of the CD Rom, they are found at the back next to the place where you plug the IDE Cable in to or next to the power input. You will be able to tell if your CD Rom is set as a slave or as a master by checking the image on the top part of the CD Rom, this image will tell you how to set your CD Rom as a master or as a slave.
Thank you for using FixYa! Have a nice day and please remember to rate this solution.
Warm regards,
BearWeb
Jan 09, 2010 | E-Machines eMachines Desktop PC
Psu
Hmmm.... mainly you have:
-20 or 24-pins connector, that is unique and goes directly to motherboard (powers motherboard and its components)
-4 or 8-pins connector that powers CPU
-the rest would be connectors for ROM (CD/DVD/BlueRay) and HDD devices (there are: molex and sata power conectors)
If you totaly unshure, there is manual:
Illustrated How to Replace an ATX Power Supply
Sep 05, 2009 | Computers & Internet
No matter what i do cd rom not detecting
check whether the powe plug has been inserted properly and the power plug is working fine. Even though if the power plug inserted is working fine and CD ROM not detecting means CD ROM was damaged.
Sep 04, 2009 | Intel Motherboard
Sir When i connect cd rom & hard disk together on my computer then the does not work.Kindly give me a solution.
There is a jumper in HDD and CDrom
  • Set the hard disk jumper to Master Connect the drive using the Master connector on the primary IDE cable.
  • Set the CDD jumper to Slave Connect the drive using the Slave connector on the primary IDE cable.
To know about jumper settings verify this link
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph03792&lc=en&dlc=en&cc=us&product=3872037
Aug 28, 2009 | Computers & Internet
My cd drive will read cds but not dvds i try to istall somethig it wont work
Hi dkush29306,
while the other two posters have pointed out the obvious, that CDROM drives only read CDs, and that you need a DVD drive to read DVDs, i would like to add something to this.
I will asume you have a CDROM COMBO Drive, that *should* play CDRs and DVDs.
if you find it does spin CDs up and read them, but not DVDs then i might be able to offer some suggestions.
firstly, make sure there is no software conflicts (like two CD Writing softwares trying to use the CD Drive at the same time.. ). you shouldnt have to worry about drivers for the CDROM, as the default OS ones should suffice. but they may be corrupt. you could goto Device Manager if you are on Windows, and uninstall and reinstall the driver for the CDROM. it should find it automatically in the install wizard.
ok at this point i don't see how software could cause any other issue , so we should look at it being a hardware issue:
if you have the ability, try changing the IDE Ribbon Cable that connects the CDROM to the Motherboard. if that doesnt work, try changing which plug in the IDE cable the CDROM plugs into. these plugs usually have a blue plug at one end (motherboard end), and there is two plugs at the other end, or master and slave. keep the jumper pin on the CDROM set to Cable Select, so you dont need to change it to slave, when its plugged into the slave port, or master pin if set to the master port.
finally, if none of that helps (and it probably won't ) you might find that the actual fault is due to the laser in the CDROM not focusing tightly enough and therefore cannot read the data on a DVD ROM because of this. the only way to tell if this is ok or not, is to plug it into another computer and see if it can read DVDs.
you might just be better off spending 20-50$ and buying a new CDROM Combo drive from your local computer hardware store.
Jul 17, 2009 | Computers & Internet
I cannot boot windows xp
Hi praph_wicked, normal order would be, floppy drive first, CDROM second & Primary hard disk drive third.
How ever if your bios does not comply you can always press the F8 key every two seconds & that should bring up (Please select boot device). Which will look like this;
Choose the CDROM drive with the windows CD in it.
If you have just one CDROM drive, make sure the jumper on the back side of the CDROM is set to "Master". If you have two CDROM drives connected, set one as master & the other to slave.
If using an IDE cable for the two CDROM drives. The CDROM at the end of the data connector is to be set as master, the 2nd CDROM connects to the next IDE connector & Its jumper is set to slave.
Mike
Dec 13, 2008 | EliteGroup P4M800-M7 Motherboard
Dvd rom drive
is cable on master jumpers or slave ?
Feb 07, 2008 | NexxTech (COB6V5216) Burner
Connection Problems
If you have other Optical Drive in your computer like a CDwriter then installed it where that LG 52x CDROM drive. Observe if the same problem occur after 2 or 3 hours. Try connecting the CDROM drive to the IDE ports (Secondary IDE port) like setting its jumper to Master. Ensure that the connection to its power supply is firm. Change the setting of your POWER OPTIONS which is under the CONTROL PANEL and change the setting for TURN-OFF HARD DISK to NEVER.
Apr 08, 2007 | LG (GCR-8523BB) Internal 52x CD-ROM Drive
My cd rom is not shown/detected by my computer. The computer says no cd rom connected,but all the connections are intact,
Have you set the jumpers at the back of the cdrom to slave if you already have another peice of hardware on the same idr cable, if not and only the cdrom is in the ide cable it should be set to master. Also check the bios to see if it is recognised, press F2 or DEL on start up and see if it's there under standard bios settings.
Feb 03, 2007 | AOpen CD 952E Internal 52x CD-ROM Drive
E-Machines eMachines Desktop PC Logo
32 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
