Question about BenQ DV3250 Television
Sound distortion lcd tv
My benq lcd comes on perfect for about half hour to 40 minutes. After that I get bad distortion coming through the speakers, they havent been thrashed at all, therefore not blown. The distortion seems to come in waves, almost like there is interference, however the speakers can be turned of, the antenna unplugged, and nothing connected. Has anyone else had this problem?
2 Suggested Answers
markfreedman
  • 312 Answers
SOURCE: I just bought the BenQ
Hi, Actually Your OK. Not to Worry. BenQ is known for making good equipment. The configuration I give you will be an upgrade to the single cable coming from the box.
How do you solve the problem? There may have been other cables supplied with your set that
will connect to your box. If there is an RCA cable with 3 sections. Yellow Red and White. They go from the cable box straight into the set. Yellow is composite Video Signal without sound. Connect it to the Yellow output on the Box to the Yellow Input on the BenQ. The Red goes to the Right Channel Audio Output of the Cable box to the Right Channel Audio Input (also Red) on the Back of the BenQ. Finally the White Connector goes to the Left Channel Audio Output of the Box to the White Left Channel Audio Input on the BenQ. You will probably have a choice of "Video One or Video Two. I think Two should work with your configuration. When turning on the set set the input to whichever section 1 or 2 or 3 sometimes. And Everything should come up fine.
THIS IS BETTER QUALITY THAN YOU HAD BEFORE.
The set you now have is full High Definition. So if your box is unable to receive High Definition, you are missing out on HDTV. If you get a BluRay Disk Play, such as a Samsung or Sony (I recommend Samsung for reliability), You will be Thrilled with the Video Image. Your BenQ also has decent speaker outputs to connect bigger speakers.
I hope this has been a help.
Have a Happy New Year,
Best, Mark
Posted on Jan 01, 2011
Speakers have a crackle in the sound also rear speakers not working
can mean several things. The crackle is subjective and can mean distortion. Distortion most of the time comes out of the amplifier. Could be you have blown a capacitor in the power supply of the amplifier, making it work with quasi half the voltage. There is no need to change the polarity on a speaker, because when one is not working infuse, it won't distort the music. You only could have difficulty with the stereo sound. It could be a bit unclear where the sound is coming from and could sound a little less powerful.Check the speakers on a different amplifier, to hear if I'm right. Only if you switched on sound while the amp was giving full power, you could have blown the speakers, but most of the time they don't give any noise after that.
Jan 16, 2015 | Ranger Communications 1998 1999 2000 Ford...
Teac A R300 right speaker has s badly distorted sound after 20 minutes. When I turn it off nad turn it on again, Same problem after 20 minutes. Left channel working perfect.
Have you changed the speakers to see if it is a driver, or amplifier, issue? If it follows the speaker, get it reconed. If it follows the channel, look into that channel.
Aug 19, 2014 | Audio Players & Recorders
The model of the BENQ Lcd Monitor is FP783 When I open the Monitor it is working around half an hour later on the screen become black but the the led is remain on. If you wait the screen never come back...
There are two boards that I would be checking, the power supply often has bulging capacitors that need to be replaced, the second concern is the inverter board has usually two three that need to be addressed, 'very common problems" the inverter energizes the back lights.
Jan 31, 2011 | BenQ FP783 17 IN LCD WEBCAM/SPK Monitor
When my samsung LNT5271F is turned it has a DELAYED DISTORTION on the right side half of the tv ,, after about 30 minutes the distortion will get a little clearer but not completely, then a DARK SHADOW...
I have the same TV and it's doing the same thing but on the left side. We had a local repair shop come out to diagnose and he told us this is the result of a loose ribbon cable on the LCD panel that would require replacement of the LCD panel - cost would be about the same as a new TV.
Aug 31, 2010 | Samsung LN-T5271F 52 in. LCD Television
I recently purchased a 52 inch LCD. I have
This could be the speakers are vibrating onto the casing and need padding out more to prevent this.If this isnt the case, you may have a sticking coil on one of your speakers..When the sound distorts, remove one speaker in turn to see which one(s) are the offending unit(s) and replace. Is there a buzzing noise coming from the speakers especially in low volume? If so then you may have a faulty capacitor in your power supply producing hum on sound. Hope this helps :)
Oct 17, 2009 | Toshiba Televison & Video
Sound proplem
its the audio amp, its fried and needs to be replaced. match the numbers up and purchase/replace boards, this will solve your problem.
Nov 28, 2008 | Dell W2600 26 in. LCD Television
Distorted sound
Sounds like you have a bad speaker or where the mounts for the speaker are broke.
Dec 03, 2007 | Televison & Video
Sound on LC-20SH4U LCD TV takes 15 minutes to come on
Probably heat sink compound on the audio IC. Fixed them before. I would imagine under $100 depending where you live.
Good luck
Aug 01, 2007 | Goodmans W280NS Television
BenQ DV3250 Television Logo
67 people viewed this question
Top BenQ Televison & Video Experts
Marvin
Marvin
Lawrence Oravetz
Are you a BenQ Televison and Video Expert? Answer questions, earn points and help others
