Question about Samsung HP-R5072 50 in. Plasma HDTV
No response to side buttons and remote control - only on/off.
I recently bought this Samsung 50' plasma TV. It only responds to the front on/off button. After its on, it will only respond once to either the side control buttons or one remote control command. Therefater it does not respond. Picture and sound is okay.
    Master:
  • 763 Answers
So the problem was your remote control? just make sure that battery was have enough energy to work on your tv or change battery it must be weak. otherwise buy a new universal remote control or try to borrow from someone if its your remote is the real problem. To be sure contact your service provider for this and use your warranty. youve said that you bought this recently and it has to be a warranty for this.
thank you for using fixya
CHARCOIS
Posted on Nov 20, 2008
  • 685 Answers
Have you tried reprogramming your remote control?also i'm looking for the manuel for your tv while you try that i'll look up a couple other things.
TV POWERS ON NO PICTURE
I had the same thing happen to my Samsung 46" led TV. It was a compassitor. We called around to TV repair guys cause we didn't have a lot of money. One of the guys came out and fixed it for $50 on the side.
Apr 28, 2015 | Panasonic Viera TH-50PX80U Plasma TV
Toshiba Plasma TV 50HP95 while watching TV screen went black and power light started blinking. No response from remote or buttons on the side of the unit. TV is approx. 7 yrs old.
Blinking of the power button denotes an internal circuit fault. If you wish to get more about the blinking codes to Samsung TVs, check this link. http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option
Sep 24, 2013 | Samsung FPT5084 50 in. Plasma HDTV
Samsung lcd tv can't find a source, buttons on remote control don't respond, nor buttons on the control panel on the right side of the TV device
consult the owner manual or call Samsung---this set likely has a lockout feature that locks both the remote and the keyboard out.
You might also want to research this by taking the model number and Google key words "remote lockout" etc.
Jun 01, 2012 | Samsung Televison & Video
Virgin remote control code for volume on my 50" samsung plasma tv
To set up the volume control on your Telewest remote control, to be able to change the TV volume, please follow the instructions below.
1. Using the table below find your make of TV and the code which matches it.
2. Press and hold down Volume + and mute on your remote control at the same time for at least three seconds, until the green light in the top right-hand corner of your remote control flashes twice.
3. Release the buttons and enter the first four digit code from the table below. (You must do this within ten seconds).
4. As you enter the first three digits the green light on your remote control will give a short blink.
5. As you enter the fourth digit, the green light will flash twice to confirm that the volume is set.
If setting the volume is not successful, please repeat the above steps with the second or third codes from the table below.
Samsung 0065, 0584, 0037
Nov 18, 2011 | Samsung 50 in. Plasma TV
I HAVE A 50 INCH PLASMA TV THAT WAS GIVEN TO ME WITH NO POWER PLUG OR REMOTE . I WENT AND BOUGHT A POWER PLUG ,PLUG IT IN AND NOTHING HAPPENED . DO I NEED THE REMOTE TO OPERATE THE TV ON AND OFF/
Hi
If the set doesn't power ON, what is the use with a remote control? If it power ON properly, the power indicator light at its front panel will light up. Look for this. If it doesn't, make sure that you have got a set which has to be repaired. If it does power up, just get a remote control to operate it. OK.
Jul 11, 2011 | Hitachi P50H401 50 in. Plasma HDTV
Panasonic TH50PX500U plasma stuck on one channel and the TV is not responding to the control buttons on the tv or remote control. I can't even pull up the menu screen. Anyone know what the problem could...
I have a 5 years old TH-50PX500U Panasonic Plasma TV that has almost similar problem as yours. At times, the response on both TV buttons and remote control is very slow or no response at all. I am pretty sure that this is a defect in the TV control circuit. I am still searching for answer to this problem.
Jan 20, 2010 | Panasonic Televison & Video
Tv not responding to remote
This may sound silly but does the remote have a funtion button or buttons at the top of the remote? It may be set to operate a DVD or VCR instead of the TV.
Failing that check the batteries, it is very rate that your TV will stop accepting IR signals.
Hope this helps,
Cheers
Jan 06, 2010 | Sanyo DP50747 50 in. Plasma TV
Samsung 50" Plasma TV no response to remote ctrl & buttons
No need to exchange the Logic Board.
Need to exchange the IR modue.
Jan 30, 2009 | Samsung SP-R4232 42 in. Plasma HDTV
The TV does not respond to the remote control nor the buttons in the front panel
Sounds like power supply switch needs to be changed to normal setting. If you are comfortable with electronics i will talk you through it if not you will need a tech or back to cosco it goes if you have a warranty.
Oct 10, 2007 | Maxent MX-50X1 50 in. Plasma Television
Samsung HP-R5072 50 in. Plasma HDTV Logo
64 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
