Question about ASUS P4P800 SE (890552603657) Motherboard
I cannot enable the on board sound card(sound Max)
HiI have just replaced a faulty hard drive,formatted and installed xp-pro, and now I have no system sound at all.Local techs have "disabled" the on board sound card,and I bought a PCI sound card,only to find I have no spare slots to use it!So I have attempted to re-enable sound in the Bios,advanced menu,but cannot identify clearly "sound card", and Im no expert by any means !So I need specific step by step instructions on how to enable the sound card please.(and what are jumpers? how do I fix them?) I presume the tech disabled it in the BIOS,but Ican't be sure?Help please BM in Oz
  • ASUS Master
  • 1,250 Answers
Check the driver status of your sound , in the device manager, if its not installed , then install the drivers or if your sound is not detecting then
go to the BIOS and load optimized bios default settings then check
Posted on Nov 20, 2008
Does the mother board Asrock 845GV (P4I45GV) support pci sata card
If you are trying to install Windows XP then -
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Nov 19, 2011 | Asrock 845GV (P4I45GV) Motherboard
I can,t instal windows xp in p4m800 with sata hard drive
hi... I suggest you need to FORMAT your hard drive do partitioning and then you can proceed to installing your Windows XP and OS...install audio driver if needed by your sound card...wallla..its seems as new...pls. rate and vote...good day
Feb 17, 2011 | Biostar P4M800 Pro-M7 (P4M8PROM7)...
I updated my Intel desktop board drivers after formatting with xp pro and when i reboot the screen was blank i think there was a bios update in the drives i down loaded.I have tried reset the bios with the...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Jan 20, 2011 | Intel Desktop Board D845GERG2 Motherboard
User Guide
CPU: Intel® Celeron® D 340 Processor
Operates at 2.93GHz
256KB L2 cache & 533MHz FSB Operating System: Genuine Microsoft® Windows® XP Home
Chipset: Intel® 845GV chipset Memory: 512MB DDR (PC 2700)
Expandable to 2GB Hard Drive: 80GB HDD Optical Drive: 48x Max. CD-RW Drive; 16x Max. DVD Drive Media Reader: 8-in-1 digital media manager (USB 2.0, Secure Digital™ (SD), Smart Media, Compact Flash, Memory Stick®, Memory Stick PRO, Micro Drive, Multimedia Card) Video: Intel® Extreme Graphics 3D
64MB Shared memory Sound: AC '97 Audio Network: Intel® PRO 10/100Mbps built-in Ethernet Modem: 56K ITU v.92-ready Fax/Modem Peripherals: Standard Multimedia Keyboard, 2-Button Wheel Mouse, Amplified Stereo Speakers Ports/Other: 5 USB 2.0 ports (1 in Media Manager; 4 in back), 1 Serial, 1 Parallel, 2 PS/2, Audio-In & Out Dimensions: 7.25"W x 14.125"H x 16"D
These are just general drivers mate
Intel Graphics Driver .....
Windows XP Operating Systems&lang=eng
Linux Operating Systems&lang=eng
Windows* 98SE and Millenium Edition Operating Systems&lang=eng
Windows NT* 4.0 Operating Systems&lang=eng
Realtek AC97 Audio Driver
Intel Ethernet Networking Driver
Intel® PRO/100 S Desktop Adapter File Name: version: 13.5
Intel® PRO/100+ Adapter File Name: version: 13.5
Intel® PRO/100+ Management Adapter File Name: version: 13.5
Shouldnt need any other device drivers as things should just be detected and installed automatically
Jan 24, 2009 | E-Machines eMachines Refurbished EMA...
Repeating Startup
U Will Have to Work in Safe Mode:
Press F8 Continuisly on Startup.
Go to Safe Mode:
Uninstall Unwanted Applications
Helped.Or Reformat;
Jan 09, 2009 | Microsoft Windows XP Home Edition
Windows XP Pro hangs on reboot after installation
Try removing your AGP card and enabling the onboard graphics again. It is possible your Radeon is a 3.3v, but this board only supports 1.5v cards. Take a look at the manual at
Dec 29, 2008 | Intel 845GE Motherboard
Install xp pro
windows xp cannot be installed on a system with pre loaded vista . because the boot loader of xp is older than vista as it cannot create boot loader . the order of installing operating systems is from LOWER 2 HIGHER ie XP to VISTA . first of all u nedd to format drive containing vista and then try installing xp
Dec 14, 2007 | Creative Labs Sound Blaster Live! 24-bit...
741GX-M Sound not working, sound cards not being recognised
plz check wether u have installed xp service pack 2. if u have done this then go to the cmos settings and check wether the onboard audio is enabled or not. then install the correct driver for that device
Oct 21, 2007 | EliteGroup 741GX-M Motherboard
ASUS P4P800 SE (890552603657) Motherboard Logo
153 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
