Question about Epson Stylus C46 InkJet Printer
Printer wont print the paper goes through the motion but no print
I have recently renewed the cartriges so there is plenty of ink
  • clothears Feb 11, 2009
    The printer tends to print the headings on each sheet and nothing else.
  • pankaj rautela
    pankaj rautela May 11, 2010
    what's the light indicator showing
I just recently experienced this same problem and was of course perplexed. I began my troubleshooting with the printer itself to determine whethter or not I could at least get a test page printed which I was able to do. This rules out bad cartridges or bad printer. By deductive reasoning I was able to determine that the printer was still in communication with the computer otherwise it wouldn't do one thing when I hit the print button. Finally I opened up my task manager and noticed my total memory being used at the time was 2.9 gigs out of a maximum of 3.5 gigs since that's all Win XP recognizes period. The majority of that memory usage was for web pages which I closed but the memory was still not released. I then turned of the computer and the printer and restarted them both and Viola!!!, it prints again. I summized that within the intricate workings of the Win XP OS it no longer had enough memory to store the print queue thereby causing a blank page to just pass through the printer printless. I hope this helps.
Massadon
Posted on Feb 05, 2009
    Problem Solver:
  • 17 Answers
Even when you change your ink sometimes you get dried up ink in the feeder lines take your ink cartridges out, take a damp cloth and wipe over the tiny holes were cartrides go, replace cartridges and press down several times firmly about 5-6 times on each cartridge that should start ink flowing
Posted on Nov 20, 2008
The printer is not writing on the paper when I try to print something. It is making what sounds to be all the right noises and is going through the motions, but it is not putting ink on the paper. I...
If you do not use your printer often, at least a couple of times a week, the ink on the heads can dry and clog up, even changing the inks and doing many head cleans, somrtimes wont fix it.
You can also have problems when the ink tank/sponge for waste ink gets full.
Try a few head cleans, nothing more you can do if you have fresh inks in
Aug 19, 2010 | Canon MultiPASS MP370 All-In-One InkJet...
Hi,I am experiencing nothing printing on paper even though ink cartridges have been replaced and cleaning has been performed.ink absorber warning appears and says that absorbers are almost full and to push...
your print head is either clogged or damaged, A print head is the unit your ink cartriges sit in. If its a nedw or newer printer (under warranty) you can contact the manufacturer and they will send you a new print head at little to no cost-good luck
Dec 19, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Epson Stylus 1520 won't print black
when you replace a cartrige make sure you take off only the yellow tape .. if you take off the white tape also then the cart wont work anymore .. careful about using off brand ink .. i used the cheep stuff for about a year before they changed the formula without telling me .. it clogged the heads completely .. .. nice wide format printer .. hope you get it working ..
Oct 01, 2009 | Epson Stylus 1520 InkJet Color Printer
All 8 new ink cartridges, new MT tank, nothing prints. it goes thru the motions of rinting, but no little to no ink is on paper, less and less ink each subsequent print. Most recent print has a hint of...
take your ink cartridge out from your printer. you can see at the ink carriage there are little pipes where the ink usually flow from cartridge. If head cleaning and power cleaning does not work, then try to clean those pipes by using 96% alcohol fluids and **** the pipes using something.
Sep 12, 2009 | Epson Stylus Pro 4800 InkJet Printer
Nothing prints out on paper.
Did you remove the little sticky tabs from each new cartridge? They allow air in, and ink out.
May 31, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Canon i960 qill not put ink on paper
I called Canon. I also had green 1 flash and amber 1flash everytime I turned on the printer. That right there indicates an elecrical problem. The flashes mean it needs serviced and with it not printing now means it's not wirth fixing, out of warranty. Canon did offer a code for reduced price new or referbished print from them.
May 27, 2009 | Canon MultiPASS F60 All-In-One InkJet...
I haven't used the printer in a while (about 6 months) then last week I turned it on and tried to use it. Went to print a test page and it went through the process but nothing came out on the paper. I...
Take out the cartriges and hold one at a time between your forefinger and thumb tightly. Hit your wrists together and see if ink comes out the bottom of the cartrige. Be careful not to mess ink on your clothes or carpet etc. This sharp "shock" will bleed the cartrige and hopefully the cartrige will work. Clean all messed ink from any contacts and the jet area of the cartrige before inserting back into the plotter.
Dec 14, 2008 | HP DesignJet 750c plus InkJet Printer
Printer makes all the moves,but the paper comes out blank.
my usb epson cx5800f won't scan because the scan goes off before scanner
Oct 11, 2008 | Epson Stylus CX5800F All-In-One InkJet...
Change ink cartridge
I have a lexmark x2740 printer and have recently replaced the ink cartridge with a genuine lexmark ink and now my printer wont print, it goes through the motions of printing but only a blank page comes out.
Sep 16, 2008 | Office Equipment & Supplies
Hp photosmart c3180 just hooked up, new, comunicates with computer on all levels. print or copy will not put anything on paper, goes through all motions but does not put anything on paper, new supplied ink...
There is no reason for it not to print ink onto the paper unless it's defective or both carts are dried up. I would return it for an exchange.
Hope that helps...
Geno
Mar 27, 2008 | Computers & Internet
Epson Stylus C46 InkJet Printer Logo
122 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
