Question about Toshiba Satellite A215-S4767 Notebook
On my toshiba laptop A215-S4767 the screen just goes black. I have to pull battery and reboot. Some article I read said something about bios but with no further details.
  • 458 Answers
Yes... a common problem with Toshiba...
you DO need to go to the Toshiba website... look for the support and drivers section.....
Match up your make/model from their choices.... and Download/ Install the WinPhlash BIOS Update It will Stop The Random Black Screens and Blank Freezes...
Posted on Nov 20, 2008
My built in microphone is not working with Skype on my laptop Toshiba A215 s4767. I have gone thru and checked drivers and checked settings and it says everything is working fine. When I do plug in a mic...
1. Open "Skype".
2. Click on "Tools" tab.
3. Click on "Options" from drop down menu.
4. Click General Settings.
5. Click Audio Settings.
6. Select the correct microphone from drop down menu next to "Microphone".
7. hope it helps .
8. mark as solution. thanks.
Aug 15, 2013 | Toshiba Satellite A215-S4767 Notebook
Monitor flickers then goes black
Your screen needs to be replaced. It is dying.
Aug 18, 2012 | Computers & Internet
I have a toshiba satellite a215-s4767 and it will plave a movie dvd but not a music cd what is up with that
The optical unit has 2 lasers: one for cd and one for dvd. The one for the cd has died. The only way to fix that is to replace the optical unit - a new one will cost you about $40, even cheaper if you get a second hand one
Jan 28, 2011 | Toshiba Satellite A215-S4767 Notebook
Toshiba Satalite A215 Laptop Bios Password
remove battery.....wait for 3 minutes....put it back and turn on...the bios wii get reset.....
if it still didnt got reset, then you need to remove cmos battery in the board by removing the back cover....
Apr 20, 2010 | Computers & Internet
Nothing on my toshiba satellite a215 will come on
Try the following.
1. Remove battery and plug in the AC Adapter and check if it works
2. Check the AC adapter LED indicator if its lighted or not(double check by a multitester)
If lighted - it works properly
if not - replace
3. Try to reinstall WINDOWS operating system by the use of the installer CD
4. If problem persist - the motherboard might be defective.
Thanks. Cheers!
Apr 18, 2010 | Toshiba Satellite A215-S4767 Notebook
Satellite A-215 goes to black screen. Has always
Sometimes my laptop does this as well. It seems to happen more and more when it is warm. You might try putting something underneath it and ensure it is getting enough air flow. Once I started doing this, mine has been doing it less and less. Hope this helps.
Mar 28, 2010 | Toshiba Satellite A215-S5818 Notebook
Toshiba A215 sat laptop turning off
maybe there's a msg display before turn it off...
Jan 07, 2010 | Toshiba Satellite A215-S4767 Notebook
Toshiba A215-S4767 will not start up correctly.
First off, Windows just didn't like the way the computer shut off, I would just restart normally and see what happens. Next when it boots up and you get into windows, Go to the control panel > Power Options > go to the hibernation tab and make sure hibernation is unchecked. Next go the setting that reads "shutting the lid". You want to open this setting with a drop down list and pick "Do Nothing", this will keep the laptop from entering standby mode just for shutting the lid. Laptops do not like hibernation or standby hates it and will give you all kinds of problems if you continue to use it.
Sep 27, 2009 | Toshiba Satellite A215-S4767 Notebook
Satalite a215-s4767 display is dead all other lites ok
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
Aug 16, 2009 | Toshiba Satellite A215-S4767 Notebook
Toshiba satellite A215-S4807/changed bios pw and cant remember it
no i'm affraid that the bios is locked and you cannot reset, you need the password to access the laptop.
try "toshiba" as the password and see what it does
keep us informed
regards The Fixya Team
Nov 19, 2008 | Toshiba Satellite A135-S2276 Notebook
Toshiba Satellite A215-S4767 Notebook Logo
313 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
