Riso CR1610EP Drum stuck
The drum is partially out and will not move either in or out. How can I release it?
Hello. I have a machine model(Rico CR1610EP) I want to connect to a computer through Antrfys range when connected to the computer does not show any action that does not identify. Whether the requisite software to link me if you are required to tanks
Posted on Aug 25, 2009
  • 318 Answers
While the drum is partially out,try to turn the drum back in home possition-turn it until you hear the click sound.If you cant reach it from he front open the master making unit and turn the drum there until it reach home possition-Note-use cloves not to get you hands full of ink or cut by one of the plates,make sure the machine is switch off.
Posted on Nov 20, 2008
Colour Drum Stuck
Underneath the drum, in the front, is a little
Apr 10, 2014 | Riso RZ220 Duplicator
Riso rp3700 drum is stuck
Assuming that it is still in the locked position. Open the top and observe the position of the drum. Rotate the drum the normally locked position. i.e. The master clamp on the drum is in about the 2 O'clock position. Put in test mode, enter 556 and push start. That may release the drum.
PrntNow.com
Mar 17, 2013 | Riso RP 3700
RISO 1610. Start light is blinking. Drum release
Friend,this code refers to switches cover:
can cover the trash (disposal box) that has two switches, magazine master.Tente verify that the drum is in position for opening.
Apr 09, 2010 | Riso Office Equipment & Supplies
My Risograph CR1610EP will not make a master. I can hear it remove the old master. The JAM indicator comes on and the number 2 in the center of the drum. There is no master (old or new) on the drum.
We had the same problem in that once master was done, it did not print. We tried this solution.
Machine must be off. Top right hand corner the and - buttons with arrows on (to align your print either left or right) press these down simultaneously. While holding them switch machine on.
A number 203 will appear on your screen.
Release hold on buttons Press 101 on number board you will hear machine inking master. Allow it to run until complete.
Hope this helps.
Apr 04, 2010 | Riso Office Equipment & Supplies
Error Code -534 on my Riso RZ 390. Drum is stuck in machine and won't release.
D04-534 means incorrect ink cartridge set. This could be caused either a) it IS the incorrect ink cartridge, or b) the RF tag that is struck to the end of the ink bottle is damaged. Try a new ink bottle.
Make sure to use RISO ink designed and made specific for an RZ230.
Jan 03, 2010 | Riso RZ390 Duplicator
Drum stuck RISO RN2235ui
assuming you have a RN machine
you should of removed the master on the drum by hand if it was not used for more than a couple of weeks, and wipe dry under the clamp.
To get the drum out, hinge up the top of the machine over the top of the drum there is another small door, it hinges up like the top of the machine.
At this point ensure that the drum is in the home position i.e the clamp of the drum is at 12:00 (on top). if not turn drum to that point by hand.
Then try the button again to release the drum. If that fails there is a small **** under the drum at the front door area. there is a catch there that holds in the drum which you can move to the side with a flat screw driver.
May 14, 2009 | Riso RZ220 Duplicator
Riso CR1610EP won't cut a stencil
I have the same problem and can only fix it when I am in the print que and I go to the layout and choose the "page size" a second time after going in the "properties" a second time. For some reason sometimes it does not recognize the page sizes. Let me know if this works for you.
Apr 27, 2009 | Riso Office Equipment & Supplies
Drum timing is off
look at the back of the machine.. you will see approximately how the drum goes in.. release the drum and push it in gently.. if you remove the disposal box you will be able to see the drum.. try to slowly and gently turn the drum while lightly pushing it into the machine until it goes back in.. this may take some time and several tries for the timing on this is very precise!...... good luck!
Mar 17, 2009 | Riso Office Equipment & Supplies
Riso GR3750 T1 error Drum Jam
I had this problem too: just unlock the hook under the drum; disengage the drum then pull out the drum; then check the home position if not in position open the behind cover, pull the belt until you get the puller to the home position. You will get the same problem if you will not put the main drum puller to the home position. chimuntu@yahoo.com
Aug 06, 2008 | Office Equipment & Supplies
The hook is located just above the power supply once the back cover is off. Also there is a drum release centered under the drum that a screwdriver can disengage.
Apr 21, 2008 | Office Equipment & Supplies
306 people viewed this question
jasbo
jasbo
