Question about HP Officejet 4110 All-In-One InkJet Printer
I m not able to scan in pdf
The Error also reports Global Handle not valid 1500:82:28 and the Windows send error report shows IOCR Application encountered a problem
3 Suggested Answers
SOURCE: IOCR application has encountered a problem and needs to close.
hi,
i think u get that error message when u scan a document and store in pdf format, there is several reason for that, u can try any one of the following steps,
1) in add an remove program, remove or uninstall  a software called OCR by read iris.
2) down grade ur adobe reader to version 7 r below, it should resolve the issue.........
Regards,  raj_p5983
Posted on Jan 22, 2009
SOURCE: IOCR application error while saving a scanned doc
Download another OCR software, like Xerox textbridge and try recognizing the text with it.
Posted on Nov 26, 2009
Testimonial: "Thank you very much. I found and downloaded "Photocopier Expert 7" (shareware) and it works perfectly. Thanks again "
Hello we have created an error report that you can send to us . we will treat this report as confidential and anonymous?
What?
Hello WE have created an error report that YOU can send to us.
So you are creating the error reports to people who have no errors?
Smells like some sort of Nigerian 419er scam.
Oct 21, 2015 | Dell Precisions Workstations T3610 BTX...
Tip
Disabling error reporting in windows xp
You might have seen this disturbing error report while you browse internet or running some application. Here are the step by step instructions on it.
Step 1: Right Click on My Computer and go to properties
Step 2: Go to Advance Tab (1) and Click on Error Reporting (2) Under start up and recovery
Step 3: Select the Radio button near Disable error reporting (1) and Check the option But Notify me when Critical error occurs and Click on OK and OK again.
http://soluzia.net/How-to-disable-error-reporting-in-windows-xp.php
on Jan 05, 2010 | Computers & Internet
Installed hallmark card studio 2011 upon launch keep recieving send error message to microsoft.
The installation must have gone wrong somewhere, Uninstall and install again.
If the program works anyway. Just disable the "Send Error Report" message:
To access the settings for the reporting feature:
  • Click Start.
  • Right-click My Computer, then click Properties.
  • Click the Advanced tab.
  • Click Error Reporting.
To configure the error reporting feature:
  • By default, error reporting is enabled. To disable it, click Disable error reporting. To continue to be notified when errors occur without being prompted to report the errors, click to select the But notify me when critical errors occur check box.
  • Specify whether you want to use error reporting for the Windows operating system, for programs, or for both Windows and programs.
  • To report errors only for selected programs, click Choose Programs, click All programs in this list, and then click the programs that you do not want to include.
  • To add a program that is not listed, click Add, type the name of the program, or click Browse to find the program on your computer.
Mar 01, 2011 | Computers & Internet
Werfault.exe -application error\r\n
You can try to disable this service by following the below steps:
Step 1: Open your computer's Control Panel by selecting "Start" > "Control Panel" from your computer's Start menu.
Step 2: Choose the "System and Maintenance" > "Problem Reports" menu option from the Control Panel menu.
Step 3: Select "Change Settings" > "Advanced Settings" from the Problem Reports program menu and turn off the automatic problem reporting feature in Windows.
Step 4: Exit the Problem Reporting application by selecting "File" > "Exit" from the File menu. Werfault.exe will now only run on your computer in the event of a catastrophic application problem.
If disabling the application does not work, y
ou should keep in mind that many malware programs can show up on your system as seemingly legitimate files by using file names that are very similar to those of legitimate files. Whenever you are in doubt about a particular file, always scan your system for viruses.
Jun 10, 2010 | Dell Dimension 4400 PC Desktop
How do I delete the error reporting to microsoft
if it is Showing ” Internet Explorer has encountered a problem and needs to close. We are sorry for the inconvenience ” Click “Don’t Send ” and everything get closed ,This Window error Report generated by microsoft is sometimes create problems for you , it is suggested you to dont ever click Send Error Reports or ” Please tell Microsoft about this problem ” because it will send all yours computer details to Microsoft , and creating problems for you.so its better to disable that error repor,so that such problem not arise in future,There are three methods to disable Microsoft error reporting.
  • To get rid of this MS Error Reporting, Right-click the My Computer icon on your desktop and choose Properties.
  • In the System Properties , go to the Advanced tab and click Error Reporting.
  • Select disable error reporting This will make any crashing program’s window simply close itself.
  • You could also click But Notify Me When Critical Errors Occur, but it might be even safer if you select Enable Error Reporting.
Inspite of this technique you can also disable error reporting via control panel as well as via editing registry . icon_smile.gif
Tags: Dont Send, Error Reports, Microsoft, Window Error
May 19, 2010 | Computers & Internet
I have the Acer S2W 3300u scanner and although I installed the drivers for Windows XP, it shows the error message "EXE application has encountered a problem and needs to close. We are sorry for the...
I have the same scanner and the drivers that came with the scanner don't work. Windows XP uses a generic twain driver that works, also most pictures viewer like XnView or Picasa uses the same. I'm using one called Wia-flatScanner_21 1.0(32-32).
Apr 01, 2009 | Acer Scan to Web 3300U Flatbed Scanner
hi,
Regards,  raj_p5983
Jan 21, 2009 | HP Officejet 6310 All-In-One InkJet...
How do i retrieve fax report from hp 4215 all in one
1 Press Setup.
2 Press 1, then press 1.
This selects Print Report and then selects Automatic Reports Setup.
3 Press ! to scroll through the following report types:
– Every Error: prints whenever there is any kind of fax error (default).
– Send Error: prints whenever there is a transmission error.
– Receive Error: prints whenever there is a receiving error.
– Every Fax: confirms every time a fax is sent or received.
– Send Only: prints every time a fax is sent.
– Off: does not print fax reports.
Note: If you select Send Only, you will also receive error reports if there is
any kind of error generated.
4 Press OK to select a report
More information? you can download manual here
http://h10032.www1.hp.com/ctg/Manual/c00095626.pdf
Sep 05, 2008 | HP Officejet 4215v All-in-One Printer
Send error report
there is not necessary to send the error reports
Oct 08, 2007 | Microsoft Windows XP Professional With...
HP Officejet 4110 All-In-One InkJet Printer Logo
52 people viewed this question
Seeker5211
Seeker5211
