Question about JVC KD-S71R CD Player
Playing an Ipod through my JVC kd-s71r
Can i play an external component through this player ?
Is there a port at the back that will take a Line input adaptor ?
I have a jvc system in another vehicle, i got an adaptor (KS-U57) which connected to the back of the jvc player, i then got the relevant cables which had a headphone jack on the other end which fits into my ipod, which i can now play through the system, will the above JVC system to the same ?
If so will i need the same or a different adaptor ?
Thanks
Simon
2 Suggested Answers
SOURCE: Using an external mp3 player on my JVC KD-LX111
You could try using an FM transmitter which plugs into the earphone jack on your Mp3 player, then all you have to do is tune the radio to pick up the transmitters frequency.
Posted on Apr 18, 2008
iadame
  • 676 Answers
SOURCE: JVC KD-S71R CD Player -
This model does not have an auxilary connection.
Posted on Sep 08, 2011
Tip
Some information of DVD player for Audi A6
Audi always be a kind of luxurious and comfortable car, but the technological develop fast , the original function can't not meet the driver need now. So the special made Audi A6 DVD player come out. There is some information of Audi A6 DVD player for you.
The outlook of Audi A6 DVD player match the Audi completely. People will not think that the Audi A6 DVD player is not the original DVD player. The resolution of 800*480 will display the high effect of picture for you. The operation system and capacitive touch screen always make the operation easily.
The Win CE operation system can be operated easily. The Audi A6 DVD Player can react quickly. And the you can play audio and video by most of format. It will provide a high quality display for you. The Bluetooth function also help people a lot. If you want to connect some device you can find USB port in the side of Audi A6 DVD player which is the place you reach easily. you can surf by WiFi and 3G internet.
Hope these tip can help!
Audi A6 DVD Audi A6 Navigation Audi A6 GPS Audi S6 Navigation Audi RS6...
on Jun 17, 2014 | Car Audio & Video
Where can I find the connections the go on the back of the stereo
Usually behind the stereo in the console. Either a square or rectangle in shape. You can obtain adapters for differing units that allows the use of the original wiring harness without rewiring. Just a simple plug and play option.
Jan 01, 2015 | Car Audio & Video
My ripspeed incar dvd player has got no picture but has got the sound what can i do to make this work
First thing comes to mind is a possible update to the system. Have you had it for a while now? If so, you should go to the computer and go the maker of the unit. Check under software updates or downloads to see if there has been a remedy or fix that the maker has published, if so...then do as it says to do and see if this resolves the problem before you get into the actual technicals of the unit. It may need nothing more. I hope this helps.
May 18, 2014 | Car Audio & Video
DVD won't place discs
Did that just begin out of nowhere? IS the Dvd spinning, if you listen closely and the player is making noise as well? That would be the lens trying to get a read on it but if it's scratched (I'm sure you tried others) sometimes the lens just go bad out of nowhere...Mu original 500 Sony PS1 in 1998 lost its lens about 3 months in...I can't think of anything else right this moment....I hope you fix it...
Mar 23, 2013 | Car Audio & Video
Can't switch to the auxiliary
try useing it.. plug your aux cord into whatever your using (mp3 player) as maybe your radio won't switch to aux until it senses that there is audio being played through the input aux cord?
Mar 20, 2013 | Car Audio & Video
RCA CABLES
RCA cables are the best way to get the audio from your head unit to the amp. If your head unit doesn't have RCA outputs, you might be able to use the speaker outputs of the head unit to connect to the "high power" or "high level" inputs of the amp, if the amp has such inputs (check your manual).
Mar 23, 2008 | Lightning Audio LA1.300.2 Car Audio...
JVC KD-S71R CD Player Logo
173 people viewed this question
Top JVC Car Audio & Video Experts
Radames Pagan
Radames Pagan
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
