Question about Samsung SF-560 Plain Paper Laser Fax
PAPER TRAY NOT RELEASING
SAMSUMG SF560 FAX MACHINE
WHEN WE PUSH TRAY DOWN AND LOAD PAPER INTO TRAY - THEN INSERT INTO MACHINE. THE FAXES IN THE MEMORY SHOULD AUTOMATICALLY PRINT, BUT THEY DON'T.... FURTHER INVESTIGATION FOUND THE MECHANISM IN SIDE THE TRAY WAS STILL IN LOCKED POSITION..... WE HAVE TRIED NOT PUSHING THE MECHANISM DOWN BUT WHEN YOU INSERT IT, IT AUTOMATICALLY SETS IT.... HELP.....
  • Anonymous Mar 31, 2014
    paper tray was empty tried to remove to refill but it is stuck and the spring loaded up is stuck up inside how do you access it to push it down and open the tray
  • 25 Answers
After puting paper in the tray you should press the start button. GOOD LUCK.
Posted on Nov 21, 2008
We have messages in the memory but keep getting message to 'load Paper' there is paper in the machine . I hvae tried putting fresh paper in , but it comes up with the same load paper message?
first thing is you have to insert new A4 sheet in to the rec/paper tray.then press the STOP key.after machine try to feed the paper in to the printer unit and you can get print.( if the machine cant feet the paper,the machine have some paper feeding problem and you have to get technical support to solve this problem)
Mar 07, 2011 | Canon L220 Plain Paper Laser Fax
I have downloaded driver for SF560. connected to computer by usb cable. wont print, frommcomputer ??
look at the model number at the back if it is only sf560 it can not print from a pc. it must be sf560p
Feb 19, 2011 | Samsung SF-560 Plain Paper Laser Fax
I have Panasonic KX-FL612 fax machine , the paper gets jammed and the fax is saved in memory . when i release the jammed paper I can not print the fax in memory . How can I print the fax in memory ?
when fax gives msg ,fax in memory,just remove jammed paper .put fresh papers in tray.if the msg is coming on screen that fax in memory just press START key.there is a green button labeled as fax start .u will receive all faxes in memory.MIAN AKHLAQ .do not forget to rate the solution.
May 13, 2009 | Panasonic Office Equipment & Supplies
Fax machine Canon L220
Ok first of all you have to deside how you are you going to use the fax,there is a option for Manual mode,Fax only and Fax Tel mode.
I normally set all my faxes with Fax only mode and then set the incomming ring to 7 rings before it switch to fax.This give you enought time to answer the phone.If you answer the phone and it is a fax you just press the green button.
You load your paper at the vertical tray,this is the last paper tray from thefront.
For sending faxes-put your documents face down in the dockfeeder dail the number and press green button.
Remember to connect the incomming fax line to the "L" jack on you machine and the extention tellephone to the jack with a handset showing on top of it.
Jan 14, 2009 | Canon L220 Plain Paper Laser Fax
The printer keeps saying check paper - re load
check the paper, and reload it
check the paper sensor in paper tray, somtimes when you slide paper in to the tray it pushes under the sensor and holds it up, it is supposed to sit on top of the sensor and push it down
Jul 08, 2008 | Brother IntelliFAX 4100 Laser Fax
Samsung SF560 error message door open & jam, no toner.
I have put a new toner in and it says "[jam 1] or no cartridge" please help this is an office fax and desperately needs to be working.
Many thanks,
Adrian.
Apr 15, 2008 | Samsung SF-560 Plain Paper Laser Fax
Loading paper
is the tray going up when you put the paper in and close it? is the sensor there? there has to be a lever that is free floating in the tray, when you put paper it goes up and shows has paper, when out it goes down for add paper.
Jan 14, 2008 | Canon FAX-L1000 Plain Paper Laser
Samsung SF-560 Plain Paper Laser Fax Logo
75 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
