Question about Maytag MES5770 Electric Kitchen Range
Oven display won't work
We have a Maytag ceramic top (model MES5770AAA). Today we had a particularly bad power outage. The electricity flickered on and off many times before dying out. Before the power went out completely, the oven display dimly showed the clock and kept turning the lock mode on and off. Once the power was restored about 6 hours later, we reset all GFI outlets and all circuit breakers. However, the oven clock did not display again, and nothing happens when any of the buttons are pressed. The four burners and the oven light work fine. The display is just dead, so the oven is useless. Everything else in the house is fine. Any help is appreciated. Thank you in advance.
  • Anonymous Mar 19, 2014
    oven has cooled completely down
    President:
  • 878 Answers
Rmedrano, Try pressing and holding the stop-time and cancel pads together for 5 seconds, see if it comes back to life. If not, try the cancel and clock keypads together for 3 seconds. First is the control lock-out funtion and the second is the display blank mode. If these fail to work, you are going to have to test for power at the board. The clock (ERC) has a 3 year warranty incase you have to call for service. Catriver.post back.
Posted on Dec 16, 2006
My ge oven stopped working after power surged code coming up on front panel: LCDBoard 'T_PP_Profile_V_3_35' Main relay V3.2, Aux Relay V3.2 EEPROM PARAMETER PAGE CRC 15 OEBC Initalization in progress
How to repair an oven: resetting the power - YouTube
? 3:13
https://www.youtube.com/watch?v=HenawxpSYow
Feb 14, 2011 - Uploaded by VideoJoeKnows
How to repair an oven: resetting the power might be the only thing you have to do....can you imagine? "You mean it ... My ovendoesn't work: what do I do now? ... How to Fix an F1 Error On a Kenmore or GE Range - Duration: 11:41. ... Oven Repair-Not heating after self clean-Kitchenaid,Whirlpool,Maytag ...
GE Oven quit working, after power outage - DoItYourself.com ...
www.doityourself.com/.../363632-ge-oven-quit-working-after-power-ou...
Oct 14, 2008 - Hi, our GE Glass Top Stove/Oven stopped working after a power outage ... My guess: the circuit board on the oven (behind the digital display) ...
Dec 29, 2015 | GE Ovens
Maytag cwe4800acb oven shuts off and display goes blank during heating
Display on maytag oven 8114p471-60 went blank - Fixya
www.fixya.com/.../t16018814-display_maytag_oven_8114p471_60_we...
Jan 20, 2013 - Stove top electric ignition still works fine, so there is power going to the .... maytag cwe4800acb oven shuts off and display goes blank during .
Oct 10, 2015 | Maytag CWE4800ACB 2.6 cu. ft. 24" Single...
Maytag ceramic top stove with the double oven, two small burners don't get hot anymore can I fix myself and how?
It is simple . Before the process make sure the the power is off .. There screws on the back after removing them you can lift the top n easily remove the none working ones . You can buy the spear ones online or local shop . I have done it myself or search YouTube with model number youse come a cross with repair option . Good luck .
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sam_bbe602d2c68da69b
Aug 06, 2013 | Cooktops
After a short power outage, my Maytag Gemini Gas Range upper oven came back on (it was on at the time the power outage happened) and I cannot shut it off from the panel. I have tried to reset the oven to...
Hello, Thank You for using FixYa. I will be helping you today.After looking at the wiring diagram for this unit it looks like the only thing that can be happening is the relay on the control/clock is fused closed thus energizing the heating element. Bad thing is this part is about $360.
Thank You and please rate my answer if it was helpful..
Jun 10, 2011 | Maytag MER6769 Gemini Electric Kitchen...
Inglis Niagara oven not working since power outage
try pushing cook and hold button once until lock comes on, then push cook and hold button again. The lock should be removed.
Aug 13, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Top burners work, oven not getting gas electronic ignition comes
The electronic ignition system (a ceramic plate that glows red) lets some power pass through to allow the gas to flwo when it has reached lighting temperature. The ceramic lighter needs replacing. Either that or the general electronic in the stove are shot.
Mar 11, 2009 | Maytag Admiral LER3330AAW / LER3330AAZ /...
Maytag Gemini Double Oven-bottom temp problem
after power outage clock on oven will not set unless the oven itaelf is on unable to set clock
Jan 16, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Whirlpool 465 large capacity electric ceramic top oven failure
How much time I need to set to do the oven self cleaning ?
I have electric Whirpool oven 465 automatic
Oct 18, 2008 | Maytag MES5870A Electric Kitchen Range
Display Malfunction
Hello murfraven,
Welcome,
You said, you went to set the timer while baking a pizza and I got a "set or en" on the display of my Maytag Gemini Ceramic Top electric oven.
How old is the range?
And the model number?
Threat it like an error code.
This can reset the system.
Turn the breaker off to cut the power for 5 minutes.
Then restart the breaker and try the range.
It's like rebooting your computer when its acting strange!
Usually it corrects some error problems if they are not serious.
Or they are sometimes just a glitch.
If this does not remedy the problem, then the switch itself is bad.
Let me know how it works out.
Huuum, Please remember to leave a rating
Oct 10, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Power outage issue
You unit is stuck in the "Display Model Mode". Hold the stop/clear button for at lest five seconds in insure the interlock activates. If it does not activate then the electronic range control (erc) is not functioning. Replace the erc (Clock/Display.)
Jan 10, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Open Questions:
See all Maytag MES5770 Electric Kitchen Range Questions
Maytag MES5770 Electric Kitchen Range Logo
761 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
freddyfox
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
