Question about HP NC4010 Notebook
I want to recover the system with f10
I updated the ram and when i rebooted, windows would not load, i do not have a disc drive and do not have the original discs anyway, i wish to recover the system but when i press f10 on start up all i get is the bios. anyone please help. is there a phone number i can call in the UK?
  • mr_bojangles Nov 20, 2008
    thanx for reply, i did what you sugested but to no avail, the ram (500) is built into these units and there is space to add extra, i removed the added ram and when rebooted it asked to accept the change, i did so but i got a message saying a dll was missing, how can i recover wiyhout the discs?
Try using a different RAM Module, maybe the RAM you installed is incompatible. Put the original RAM and look if the system start as usual.
After a RAM upgrade, it isn't neccessary to reinstall anything, the OS will detect the new RAM and will make it usable. No drivers, no recovery, nothing else is needed.
If the system fails to start after the upgrade, there is a problem with the new RAM module installed or possibly a latency conflict with the module that came with the PC and the new one.
Posted on Nov 20, 2008
NTLDR missing on XP desktop
NTLDR is the boot loader for windows XP. This is the part the kick starts the entire process of XP loading. It is located at C:\NTLDR One of the easier ways to fix this is Either boot in to the recover console from a Windows XP disc, or download Hiren Boot CD, burn it to a disc. Insert the CD into your Dell and reboot the computer. Note you may need to enter BIOS and enable boot to CD/DVD. Once at the Hiren menu, select Boot Mini XP. Once the Mini XP loads you can copy NTLDR loader from the mini xp to your C:\ drive. Then remove the disc and reboot the computer.
Jun 11, 2012 | Computers & Internet
My compaq presario CQ61 crashed. Have tried recovery but everything has failed. I have got as far as installing window files but it now is asking for the installation disc - I have not got one
You tried recover and it failed, and now you are trying to reinstall windows but you don't have system disc. Hmmm, have you tried rebooting and going into safe mode. Just curious, but you've probably wiped out your operating system by now doing the two things that failed.
You're going to need an operating system disc to get you out of this.
Apr 01, 2012 | Compaq Presario Computers & Internet
How do I reboot my ASUS EEE PC 701SD 7" 0.9 GHz
To start the systemrecovery:
  1. Restart the computer.
  2. When the Computer logo appears on the screen, press the Alt and F10 keys repeatedly.
  3. If you are prompted with a Microsoft Windows boot screen, press the Enter key.
  4. After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
If the ability to reinstall from the previous method is not available orfails, recovery of the Operating System will need to be from Recovery Media. Ifyou do not have a set of Recovery Media, you may purchase the set onlinefrom the manufacturer.Note: If your computer does not havean internal optical disc drive, an external optical disc drive will be requiredin order to recover the Operating System using Recovery Media.
  2. When the computer logo appears on the screen, press the F12 key repeatedly to enter the computer's Boot Menu.
  3. Press the CD-ROM drive eject button and insert the disc labeled System CD.
  4. Close the CD-ROM tray.
  5. Refer to on screen instructions to select either CDROM or USB CDROM.
  6. The computer will boot from the Recovery Media
  7. When prompted for the Recovery CD, remove the System CD and insert the Recovery CD.
Note: Ifthere are multiple Recovery CDs, please insert the first of the Recovery CDs.
  1. After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
Oct 30, 2011 | ASUS Eee PC 701 Notebook
Restore
These HPs typically have a partition permitting restoration to a condition of the factory defaults via F10 on rebooting the computer. I would certainly have tried system restore before any destruction return to factory defaults. If you can boot the computer from a USB stick (changing the boot sequence via F1 setup), and have it load in a Linux OS, you can recover some of your data files. PC User June 2011 offered such on its disc. Doubtlessly, an update of the technique is elsewhere available. You will want to update service packs after a restore, very likely.
Sep 09, 2011 | AMD Hewlett Packard Pavilion m8000n PC...
I have ran into a problem with my Acer Aspire 7520g. I started the laptop as usual and it started no problem. I then left the room and when i returned the laptop was switched off. When i now try to boot it...
Ok, you need to boot from your DVD with a Widows, install boot disc, inserted, and boot up on that DVD, then do a startup repair. OR... Run Acer eRecovery Management Copy the Acer factory default backup disk Image Create backup of the system Create a complete backup Creating an incremental backup Erase a backup point Using the option ‘‘Burn Disk’’ Burn a backup disc with the factory default settings Burn a backup disc with the parameters of user Copy the current system configuration to disc Burn a disc backup software Restore the system Restore system to factory default settings Restore system from backup user Recover the system from CD / DVD Re-install applications / drivers Other means of System Restore No Restore CD / eRecovery / password / ALT + F10 or F10
May 22, 2010 | Computers & Internet
Windows not loading
http://www.ehow.com/how_4478845_restore-acer-computer-factory-settings.html
May 05, 2010 | Computers & Internet
Recovery error 320 on sony vaio laptop
Ketanvasu your an idiot....If he's trying to recover the laptop obviously the thing isn't working...so how the hell is he supposed to burn cd's genius?
May 09, 2009 | Sony VAIO VGN-NR498E/S Notebook PC
Acer3690 windows vista wont start back up
If Vista came installed on the computer originally you should be able to just run a system recovery (either from the had drive or from recovery discs made after buying the computer). When turning on the computer press Alt+F10 to start the recovery process. If you get a loading bar with "Loading Windows Files" above it then you're on the right track. It will allow you to reinstall windows Vista and will also install all the drivers you need.
If you can't get the Alt+F10 to work and don't have the recovery discs then you will either need to contact Acer and get a sent shipped to you, or find someone with a set of OEM discs that can reinstall it for you.
Hope that helps :)
Mar 25, 2009 | Acer Aspire 3690-2196 Notebook
Having trouble with HP ..Windows XP
I suggest that :
  1. Press F8, choose command line (if you know) and backup any file that you need (copy to an external drive, pen drive, cd or other medium). Please skip this step if you allready have updated backups.
  2. you restore the windows XP with the original cd / dvd, and choose format disk.
  3. remove the cd / dvd when asked for reboot
  4. Restore your data files and update the operation system with Microsoft update.
Hope that helps. Please inform what hp model you have for further help.
Cheers,
Pedro
Aug 24, 2008 | Microsoft Windows XP Professional With...
HP NC4010 Notebook Logo
93 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
