Question about Denon AVR-2807 Receiver
Electronic eye on tv does not capture remote rw
When I stand infront of the receiver in the clost it works with the remote, but when I go out in the main living room and press the button, the electronic eye does not get picked up by the tv and transmit the rw to the closet and change the chanel,
it was working earlier in the day then something happened?
any ideas on what to do
  • 165 Answers
Hello if you already changed the batterries you problably drop it or sit on it you better take it for repairing saludos
Posted on Dec 12, 2008
Why does TV turn off with the remote but won't stay off?
Greetings Charlotte,
All of the following assumes you are using the TV manufacturer provided remote ...
(ELSE: Get THAT remote, verify trouble & re-post fixya issue)
A few seconds is a really odd symptom (that's an IMMEDIATE cycle (2 power KEY HITS)... so before you rip into the electronic eye (Remote Recvr: tiny board at the control edge of your TV)... and/or change out the main power board...
(think... EVERYTHING else works remotely).
Try:
- unplug your set for at least ten minutes
- close the drapes (block sunlight from TV)
- find the receiver eye & remove ALL close obstructions
- check the remote & remove ALL covers/tape or soil.
- fresh batteries in the remote
- press power button as quickly as possible
Considering (I'm thinking)...
After MY studying HUMAN - MACHINE interface in a lifetime of trouble shooting... I came to know that when people become
VEXED by electronics... they tend to MASH buttons much-more deliberately (this can be a PROBLEM all by itself).
Critical timing on a button press used to be 500 to 900 milliseconds...
Meaning a longer press... went into special "handling" by program code (early software iteration (trial & errors).
((registered multiple KEY HITS = slower response, etc etc))
Your Remote Receiver is designed to register a continuous press (ON THE REMOTE) as ONE KEY HIT regardless of the DURATION... however
Any soil on the set (receiver) or remote (transmitter)...
visual objects, vases, mirrors... even sun-light can significantly change operation... as can TIRED BATTERIES (in the remote).
Failing all the cheap & easy suggestions above comment me back (+make & model) and I'll point you to procedures to get into your TV.
Hope this helps
TV Parts Universal TV Stands DLP Chips ShopJimmy
Jan 28, 2016 | Bush Televison & Video
Remote control does not turn tv on or off
Check to make sure that the batteries in the remote are new and that the batteries are installed correctly. Make sure there is nothing blocking the infrared receiver "eye" on the TV.
Jan 22, 2016 | Emerson TS 32 Flat Screen TV Stand for Up...
My remote wont turn on or off
First of all have you replaced the battery in the remote? They do need replacing every so often. Some times remotes do wear out and will not work then you have to get a replacement.Is there any thing covering the front of your unit you are operating. If you cover the electronic eye your remote will not work and also make sure the electronic eye on your remote is clean and clear.
Nov 02, 2015 | Audio Players & Recorders
Coby remote rc-057
could be many things, make sure nothing is around the tv that would block the receiving eye for the remote on the tv. sometimes the receiver in the set can go bad.
Jun 17, 2014 | Coby TFTV1923 19 in. LCD TV
I have no dirver of SAA7130 TV Card - Video Capture
Philips SAA7130 TV Tuner/FM Radio/Video PCI Capture Cardr I installed the hardware, no sound was coming, neither did the
remote work. After I troubleshot following the
guide on the official website of sabrent, I successfully solved the sound problem by reinstall the
driver.
However the remote still
does not work. I installed the remote driver, there is a icon on the taskbar :
"SAA7130 TVcard Remote control receiver".
I also made sure the
batteries are good, the sensor are installed correctly, but still couldn't solve
the problem,
Jan 27, 2011 | Philips SAA7130 TV Tuner/FM Radio/Video...
When you push either the remote or the switch at the door, the garage door will go down almost to the bottom and then come back up and the light will blink several times. This does not happen all the time....
Your safety reversing sensors must be connected and aligned correctly before the garage door opener will close. An obstruction in the path of the sensor will also cause your door to not close.
This sensor is an electronic beam, which is sent between two sending and receiving “eyes”. These eyes face each other and are located just inside your garage door. They may need to be adjusted so the beam from the sending eye is properly detected by the receiving eye. Once the receiving eye “sees” the beam from the sending eye, a green indicator light will glow on the top of the eye.
Jan 03, 2010 | Sears Craftsman LiftMaster Chamberlain...
Dish IR Remote 20.0 has problems after sunset.
The problem for me was the TV giving off IR signals that interfered with DISH's poorly designed remote. When the TV's room ambient light sensor was turned on and it became dusk outside the DISH remote would stop working. Moving the receiver away from the TV helps but the problem is not eliminated until the light sensor is turned off.
Until DISH corrects this poor design there may be no other viable solution.
Jul 09, 2009 | DISH Network IR Remote Control
Remote i on tv
From elsewhere... in case it helps
"...and an intermittent problem responding to the
remote. I had a service person check it out and was going to have it
repaired because it still looks and sounds very good. The part was
available at a cost of about $85-90 plus about $40 for the service.
However, the service person didn't want to come back again for
another service call because I was too far and it was not profitable
for him, so the part was never replaced.
The remote control is OK. It is the receiving module in the TV that
has a low voltage problem. If anyone is electronically handy it
probably is an easy fix to install a new module or it can be use
without the remote with the buttons on the TV."
Aug 03, 2008 | Toshiba 36A61 36" TV
Remote signal not received?
If u can get to the INSIDE front, clean the window of the receiver eye.(of cause the outside also!) If the wires going to the board can be unpluged, unplug, the push it back in. Possable that the receiver eye circuit is too heated up.Put a small (square boxed computer type fan) in the back of the tv to cool it down some.If u know how to "glue" a HEATSINK to the chip to get rid of the heat, may help.
note: it is possable that BOTH regulor and universal r/c are intermittance (sometimes works, sometimes don't work)
Jan 13, 2008 | Symphonic SC319C 19 in. TV/VCR Combo
Remote control
Do you have the remote IR cable plugged in ? If so, Can you see the "eye" on it from where you are trying to use the remote ?
Nov 20, 2007 | Philips SAA7130 TV Tuner/FM Radio/Video...
Denon AVR-2807 Receiver Logo
171 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
