Question about Compaq Presario 700 470024-192 Notebook
No sound from headphoe when iserted
My headphone works properly with o.s. windows xp,but when it is inserted to vista there is no sound from the headphone,sond is from the laptop speaker.there is sound from the headphone if it is inserted before any media player starts,then if it is unplugged in the middle of a song then there is no sound from laptop speaker .plz kindly tell me the solution.
  • mighty7 Nov 21, 2008
    my headphone is not sounding very well
My headphone is also giving me problem. i can hear sounds from my speaker if the heardphone is not inserted but if inserted when working it does not affecting anything, Even the soundof my headphone is bad.pls kindly post me a solution
Posted on Nov 21, 2008
Cant get to play music without headphoes
Most modern computers come with internal speakers already installed, especially laptop computers.
These speakers may be sufficient if you are performing typical computer tasks, but when you play computer games, listen to music or watch movies on your computer, you may want louder and more vibrant sound.
You can achieve this by installing external speakers or headphones. These can be connected to your computer through the speaker or USB ports included on your computer.
Plug in the speakers or headphones.
If the speakers or headphones use a stereo plug, insert the plug into the speaker/headphone port normally located on the side or front of your computer.
This port is often color-coded green. If the equipment is connected using USB, locate a free USB port.
Some external speakers will also need to be plugged into a power outlet in the wall or your surge protector.
This may be all you need to do to get the speakers or headphones to work. If they do not, continue to the next step.
Open the audio settings on your computer.
From the Windows Start menu, open the Control Panel. Here you will find audio and sound settings.
Click the heading to see your sound and audio options.
Choose "Manage audio devices" in Windows 7.
Find your Playback device.
In the Playback tab, you can select your speakers and set them as the default for your system.
If you do not see your speakers or headphones, they have not been installed properly. Disconnect and reconnect them to see if it corrects the problem.
Configure your settings.
Select your device from the list and click "Configure" to test your settings.
You can adjust the volume by using the volume slider on your computer's task bar or using external controls on the speakers or headphones.
Install speakers
http://www.liutilities.com/how-to/install-speakers-to-a-computer/
Aug 05, 2013 | Acer Computers & Internet
The headphone and external speakers don't work on my acer but the internal speakers are fine
check if you plugged them in the proper port the green one is proper for speaker.
Mar 31, 2011 | Acer Aspire One A150-1006 Notebook
When i insert the plug to my laptop, the sounds from the speakers disappeared so i thought it's alright but no sounds are coming from both buds.what should i do? it still has a warranty but i want to fix...
If the computer was playing sound earlier but now now, we can try doing system restore (if it is windows XP, Vista or Windows 7),
Procedure for XP:
Click on start
Click on Programs / all programs
Click on Accessories
Click on System Tools
Click on System restore
Choose restore your computer to a previous time
Choose a bold date, couple of days previously when you know your computer was working fine and follow on screen instructions
If you do not have a hardware problem, this should solve by loading the old settings.
Procedure for Vista / Windows 7:
Click on Start / orb / pearl
Type system restore and follow onscreen instructions to restore your computer to earlier time.
Jan 02, 2011 | Skull Candy Lowrider Professional...
Sound will not play through headphones
Try here:http://www.computing.net/answers/windows- xp/headphones-amp-speakers-switching/55486.html Also:http://www.vistaheads.com/forums/microsoft-public-windows-vista-music-pictures-video/133605-sound-doesnt-switch-automatically-headphones-when-plugged.html Also:http://www.vistax64.com/sound-audio/198039-sound-doesnt-switch-speakers-headphones.html scroll down the page for the discussion.
Oct 18, 2009 | Philips (33-01-031) Headphones
HEADPHONE IS NOT WORKING
From what you are saying the headphones have a broken wire on the side not working or they are bad. Check the wires in your headphones and that will tell you if the headphones are bad.
Sep 27, 2009 | Intel DG43NB Motherboard
Driver problem in compaq presario c700 laptop
Try connecting the headphone properly.
Check if its properly inserted.
Go for windows update............... and then check if the problem is gone.
If all the above doesnot works I think there is a connection between the metals inside your headphone portal, ans as soon as you insert the jack it gets connected and you can hear sounds from both the sources.
Thank You.
Nov 13, 2008 | Microsoft Windows XP Professional With...
No sound.
Did you get sound through the entire system after plugging in the headphones? If so, the headphone jack is acting as a switch and probably has some dirt/debris that should be cleaned. The easiest way to do this is to get some electronic switch cleaner (one that contains a lubricant as well) and spray into the headphone jack. Insert and remove the headphoe plug a number of times and the problem should be resolved.
Update this if the problem returns and we'll look further.
Dan
Apr 02, 2008 | JVC TH-M303 System
Headphone Jack Problem
install (update) the compatible sound driver for vista.
Dec 01, 2007 | Microsoft Windows Vista Ultimate Edition
Compaq Presario 700 470024-192 Notebook Logo
110 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
