Question about Konica Cameras
Camera does not switch on when cover is slid open. problem is inside the front cover sliding mechanism. new front cover would fix the problem - can I get one?
  • jimwing Nov 24, 2008
    You ask me to rate my own solution ............... Whaddya expect?
OK Here's the problem and the fix ................... After removing the front cover (six screws) and carefully removing it you will find that the front thin metal cover has a plastic inner section that contains the slider mechanism. The plastic bit is attached to the metal cover by two or three strips of double sided adhesive tape and is a real b*st*rd to get apart, but this is what you have to do, so gently but firmly prise them apart, I raised one end with a watchmakers screwdriver and then used a 20 thou feeler to "cut" through the tapes, which can be reused on reassembly.
Once apart it is obvious how the thing works and the problem was seen to be a return spring that had slipped out of position. Using a large needle this was repositioned so that the cam returned to the "off" position. Reassembly is simply a reverse of this procedure.
The malfunction was caused by a few grains of Australian sand (last week only!) jamming the cam causing extra stress on the spring which jumped out of it's position - and here I mean a spring that is at best only three mills long! A magnifying glass helps.
If you can't work to very fine detail better leave it alone .................. All the best
Jim
Posted on Nov 21, 2008
HP Photosmart M22, won't turn on.
There is a magnetic reed switch in front of the power switch and a small permanent piece of magnet just behind the hp logo of the slide door. Try placing a stronger piece of magnet in front of the logo and slide the door again and listen for a click when the reed switch closes. If not sound then the switch could be defective. Replace switch if necessary.
Also make sure you update the M22 camera firmware for power problem before doing any hardware repairs.
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ps-32256-2&lc=en&dlc=en&cc=ca&lang=en&os=228&product=437204
If your firmware version number is LESS than 2.02.08 (for example, 2.02.04), then you should install this updated version of firmware.
File name: s.gif COL11035en_a.exe, (1/1 , 2.57M)
Enhancements: s.gif
  • Improves battery performance
  • Corrects discharging issue with rechargeable batteries
Jun 27, 2009 | HP Photosmart M22 Digital Camera
Card locked. Bought new card. Is in the
First I know you've said you've checked the card's slide switch, but just want to restate this first for others with the same problem who may not know of this switch.
Check to make sure that you didn't accidentally place the tiny locking slide switch on the side of your SD card in the "locked" downward position. The correct "unlocked" position should be slid up toward the direction of the connectors.
If you've tried this, and it's still showing locked, it's likely that the locking switch inside the camera's card slot is stuck. If you look inside the slot on the side of the slot where the SD card slide switch would be, you'll see a glint of gold color on the side. This is the camera's lock/unlock switch. The other glint's of gold that you may see at the far end of the slot are the reader's connectors (ignore those).
Somehow, the locking switch is making contact and has become stuck in the locked position. With a plastic toothpick, or other skinny NON-METALLIC item, tap against this switch to see if you can jar open the contact to its normal unlocked position. Also try blowing compressed air at it, as some gunk may have worked its way in there, jamming it closed. Occasionally, reinsert the SD card to see if the issue has been corrected.
If repeated tries fail, it may be time to consider opening the camera to force open this switch (not recommended unless you have some familiarity with electronics). In this case please see the following (xscrewdriver, hope you don't mind me referencing your blog):
http://www.myfixtips.com/blog/digital-camera/how-to-fix-a-%e2%80%98card-locked%e2%80%99-problem-125.htm
Jun 15, 2009 | Canon PowerShot SD1100 IS Digital Camera
Slider on olympus c60 broken
Probably!
The slider is held in its groove by a plastic liner and part of mine wore away with the upshot that when I slid it open, the tiny pin on the slider dropped back a little way. We are only talking a tiny amount here but it was enough to activate the switch to reclose the lens so the thing was sliding in and out of its own accord as I rocked the slider.
I simply superglued in a tiny piece of plastic in where the worn away bit was and it cured it!
Chris, England
Apr 09, 2008 | Olympus Camedia C-60 Zoom Digital Camera
Olympus C-50 zoom
I have designed and produce on a limited basis a new slide/nut plate for the c-50 that is easy to install using existing screw. Just slide the old nutplate outand slide the new one in and attach screws solves the problem of the sliding door and the off/on switch behind the door ,I sell it for 25.00 +3.00 shipping
John Richardson jarg1@gwi.net
Mar 17, 2008 | Olympus Camedia C-50 Zoom Digital Camera
Nokia 6288 troubles
HI. 1ST U OPEN THE BACK COVER AND REMOVE THE BATTRY > NOW OPEN THE SCREW > PULL THE BACK COVER VERY CAREFULLY PULL UR MOBILE PCB VERY CAREFULLY AND REMOVE THE STRIP CONNECTOR SAME PROCEDURE FOR FRONT SIDE WHEN BOTH SIDES R OPEN THEN CLOSE SLID AND PULL THE STRIP FROM MOBILE'S SLIDE. THEN NEW STRIP ENTER THE SLID AND FLOWS THE SAME PROCEDURE IN REVERS CONDITION. NOTE -(WHEN U PULLED THE STRIP THEN MIND IT WHICH SIDE IS DISPLAY SIDE OR WHICH SIDE IS PCB SIDE.
Feb 20, 2008 | Nokia 6288 Cellular Phone
Not operating.
Hi
Sounds like the problem with mine - the fault is with a broken mechanism that operates the switch. The front cover can be removed (carefully) by unscrewing the six tiny allen screws retaining the front cover (two on the bottom and two each side).
Once the screws are removed gently lift off the front cover, you can then see how the slider pushes the small white (on mine) lever, to activate the mechanism - this can be done with the cover off to test it out.
Haven't been able to find a repair scheme yet, so I might resort to some micro mechanical modifications as I like the camera.
Not a fix I know but I hope this helps a little
Jim
Oct 23, 2007 | Konica Revio KD-400Z Digital Camera
Camera doesn't recognize lens cover...
I rednecked the crap out of mine. I pulled off the slide cover and placed a small piece of paper clip in the area of the copper to make a permanent contact. Then duct taped it secure and then cover the whole slide mechanism. I would not recommend this method but it worked.
Apr 28, 2007 | Sony Cyber-Shot DSC-T5 Digital Camera
Lens will not retract
In my case, there was dust in the switches that sense the cover movement.
  1. Close the sliding door and wait until the lens is drown inside (timeout).
  2. Open the screws that secure the front cover.
  3. Remove the sliding door covering the lens. There is no trick (hidden screws etc) so just use the force. The door is mounted by two-sided tape and adhesive.
  4. Remove the front cover. This is also mounted by two-sided tape / adhesive in the center, so you have to be a bit brave.
  5. The sliding door rails and the movement sensors are now visible. Clean all dirt.
  6. Try the door functionality.
  7. Mount the front cover after the lens works as it should. Close the screws.
  8. Mount the sliding door.
May 27, 2006 | Konica Minolta DiMAGE G400 Digital Camera
Cassette Jam
The most frequent cause of this type situation is not having a power source attached, or a depleted battery pack. Once the power source is available, some models require manually unlatching and opening the cassette compartment cover. When the cover is fully open, the videocassette will eject automatically. Please try the following procedures. 1. Attach the power source to the camcorder correctly or use a fully-charged battery pack. 2. Fully-open the cassette compartment cover until it stops while sliding and holding the OPEN/EJECT switch. The videocassette will eject automatically after a few seconds. If the videocassette still will not eject, seek assistance from a Canon Service Facility.
Sep 04, 2005 | Canon Optura 60 Mini DV Digital Camcorder
Open cover
The cover opens in two positions. To completely open the lens cover for shooting images, slide the lens cover over until you hear two clicks. When the camera is on the first position, you can playback images.
Aug 31, 2005 | Olympus Camedia D-510 Zoom Digital Camera
Cameras Logo
134 people viewed this question
Top Konica Cameras Experts
myxelpyxel
Level 1 Expert
Lawrence Oravetz
Are you a Konica Camera Expert? Answer questions, earn points and help others
