Question about MSI 661FM2-LSR Motherboard
Drive SATA 3.0 Gb not detected by msi 7060
I'm a portuguese guy who want's to solve this problem at once!
I'v a motherboard MSI 7060, and i've buy a drive SATA 3.0 GB but at BIOS doesn't detected this drive! Only the DVD drive who is IDE.
This motherboard early works whith a dirve HHD-SATA (1.5) and now with a new hdd drive not's work!
i want to install XP and i cant detect the hdd drive.
Yesterday i put the HDD-Hitashi SATA3.0 works at 1.5Gb, but in BIOS or in INSTALL XP is not detected too!
What i could do to solve this sheet at once!
I'm sorry my english who is not perfect, but i think you will understaind.
Greetins in advance!
Pedro Vieira
  • 3 more comments
  • Anonymous Nov 20, 2008
    I'm sorry, but the old drive doesn't work!
    that i can't do a live update, because i can't go on to windows or another SO, ok?
    it is a hdd hitashi 3.0 gb/s (not space but speed).
    thi hdd drive doesn't have jumper!
    can help me?
  • pedrolavado Nov 20, 2008
    Hello, i'm sorry but the 3 Gb it not space but SPEED.
    I continue with a problem, because i can't do any LIVE UPDATE, because i don't have any HDD with a value SO or other system to Start work!
    The Hdd before is broken!
    Please help me...
  • pedrolavado Nov 22, 2008
    I'm sorry, but when i get to update bios she doesn't do, look, it tells me this: "Source File not Found!"
    But i' have it all!
    I can't undestand!
    Please help me or this computer goes to river down!
    OK, the BIOS as been Updated, but i see no diferences!
    and the HDD SATA it isn0t detected.
    What i do next?
  • pedrolavado Nov 23, 2008
    Please, I'm again with problems!
    I do not now to do next!
    can any body help me, please?
    Pedrolavado
    President:
  • 1,073 Answers
3GB Sata driver? i dident know there existed so smal drivers
Anyway, if your bios dosent detect the driver u probably need to update the bios drivers.
Go to MSI site:
http://global.msi.com.tw/index.php?func=proddesc&maincat_no=1&cat2_no=&cat3_no=&prod_no=158
Instal LIVE UPDATE and let msi check you computer for laterst drivers u need to instal
Posted on Nov 20, 2008
  • Nicolas
    Nicolas Nov 21, 2008
    OK, here is the direct link for bios download.
    http://global.msi.com.tw/index.php?func=...
    The latest bios is the one 1.2
    Go to a friend or an internet cafe, download the bios and store it on a flopy or burn it on a cd or use an USB-stick
    Update you bios.
    After that check setup in you bios, if the settings in your bios is set to detect ATA discs change it to detect sata discs. U will find it under Bios-Advance settings.
Msi 7060 ver1 motherboard manual
Max is 2GB for that motherboard.
Apr 27, 2012 | MSI Computers & Internet
My hard disk is 80GB (IDE) when i try to connect another hard disk 320GB (SATA) the mainboard doesnot detect 320GB SATA hard disk and my pc restart every moment note: MSI 848P NEO-V
Hello samanozy ,
Some older motherboards will not support a too wide HDD whatever the interface.
Another point is to know if you have set the boot priorities in the BIOS . Your machine is maybe attempting to boot from the Sata drive .
Best regards ,
fanaudi .
May 13, 2011 | MSI 848 NEO-V P4/Intel...
80 GB SATA hard disk detected at the time of booting, but at the time of windows xp installation "no drive installed on your machine " message showing. Can you help me?
The XP disc you use might not contain the SATA drivers slip streamed into it.
For more details about slip streaming you can use the following link
http://www.digitgeek.com/how-to-slipstream-sata-drivers-into-xp-cd/
It will be great if you Let me know once you solved it
Nov 18, 2010 | MSI K8MM-V Motherboard
I am not able to detect sata hard disk in msi mother board
Your model K8MM-V motherboard does not have a SATA controller only IDE disk controllers and therefore it cannot detect a SATA hard drive.
To install a SATA hard drive on this motherboard you need to purchase a PCI SATA disk controller and install it on the PCI expansion slot and then attach the SATA hard disk to this SATA controller.
Aug 21, 2010 | MSI K8MM-V Motherboard
Msi k8mm-v board not detecting SATA 320 GB HDD
peets, is this drive a slave drive? if so, make sure you have the jumper ******** the hdd set for "slave" , the instructions that came with it and on top of the hdd itself shows you where that is. You should have it set up for this anyways so you can format it to your liking(i.e. if your going to partition it out or use the whole 320GB for your data). after doing this you will need to go to you bios screen when you boot up your computer(setup). Go to standard or advanced bios settings and see if the new hdd is there, your bios should recognize it, if not, make sure you write down all the info for your hdd (size, cylinders, heads, type) and input the info for a correct installation and when you are finished, make sure you save the info (F10) and (Y) computer will restart and it should see the new hdd. Also, I take it you have CD/DVD driveconnected to your primary SATA or IDE port, this should not be a problem, if so send a msg back.
Dec 14, 2009 | MSI K8MM-V Motherboard
Not ditect SATA HARDISK
Hi
I know what is problem,some of mother is made only SATA HDD data transfer rate 1.5 GB per second.Now all are SATA HDD data read rate 3 up to g GB per second .Follow the instruction label on the hard drive.
If you use your Motherboard 3GB data read hard drive you can customise setting jumper source of data rate 1.5 then MSI Motherboard detect SATA hard drive.
Good Luck.
Nov 26, 2009 | Intel Motherboard
HOW TO DETECET SATA DRIVEES IN MSI MS-6799
Though sata drives are normally plug and go, sometimes you need the drivers installed first.
Does the bios recognize the sata drive ?
Nov 12, 2009 | MSI PT8 NEO-LSR, 601-6799-010, FSB800...
Ineed cd support for MSI 661FM2-V (MS-7060)motherbord, because i lost the original and now i want to install xp sp2 on sata HDD
you can get manual, driver, bios for your motherbord at the MSI mainboard website http://global.msi.eu/index.php?func=proddesc&maincat_no=1&prod_no=158
choose XP driver
Succes with installation
I hope this information is helpfull
Aug 29, 2009 | MSI 661FM2-LSR (7060020R) Motherboard
MSI 661FM2-LSR Motherboard Logo
841 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
