Question about Refrigerators
Fridge Light Needs Replacing
Can remove bulb in LEC R404WG 4C Fridge
I am going to leave it as it is and get a new fridge later.
Posted on Nov 20, 2008
Lec fridge-freezer TF5089 faulty door light switch - how do I remove the switch from the fridge to check it?
Prying it out is the only way I know of. When you get it partially out you may be able to get hold of it with waterpump pliers or regular slip-joint pliers adjusted for a wide grip, and pull it the rest of the way out. They are made to be removed this way, so it shouldn't be damaged. If you push in the button and the light remains lit your refrigerator section may not be getting cold, because a bad door switch can send out a signal that the refrigerator door is open, in which case the freezer may not be blowing cold air into the refrigerator section. The door switches are fairly cheap online, especially compared to a service charge.
Mar 22, 2014 | LEC TF50152W White 172 l Fridge Freezer...
Replacing switch that operates interior light of under counter LED fridge
Is it a plastic insert switch? Make sure the power is off, prise out from rear with flat headed screwdriver
Apr 24, 2012 | LEC Refrigerators
Replacing door interior light switch of under counter LEC fridge
If it's the rectangulat one, it prises out of the hole with a flat screwdriver. Make sure it's unplugged before working on it. Do you suspect a faulty switch?
Removing bulb from fridge/freezer.
Usually the light bulb base is a screw, to remove it you need to rotate it clockwise (facing your fridge). I highly recommend you to use a towel to handle the lightbulb for safety reasons.
If you are replacing it, please be aware that you should use a 25W or 45W light bulb.
Hope it helps.
Sep 29, 2009 | Fisher and Paykel Refrigerators
I have a lec r450w fridge and the internal bulb needs replacing. There does not seem to be an obvious way to get to the bulb. Do i need to unscrew the temparature control dial to open the panel ?
No, you dont need to touch the temperature control knob. You access the lamp and lampholder from underneath. Get a small thin screwdriver, slide it up the left-hand-side of the opaque plastic (that allows the light to shine through into your fridge). Prize it down, it is not brittle so it should not snap. the opaque cover will come out and the bulb is right there to unscrew. the cover goes back in easier than it comes out, so just reverse the process. Make sure you isolate power to the fridge before you begin.
Aug 01, 2009 | Refrigerators
Where abouts is the thermostat inside the fridge there are white and yellow wires that go to either side of the fridge and the yeallow ones are broken what are these wires for it is a kelvinator C375vm
It sounds like you have a cyclic defrost fridge,Kelvinators were originally fitted with heat assist thermostats,so in order for the fridge to come back on a yellow wire heater was run around the cooling evaporator in the fridge compartment start running again at approx +4C so when the element fused the fridge did not start again until approx +12C.So instead of replacing heater a different thermo was used that came back on at +4c deg regardless.Kind Regards.
Jul 09, 2009 | Refrigerators
Tail light bulb needs replacing
You must remove the cargo carpet lining from inside the trunk in the corner behind the taillight. Five nuts removed the sealed light assembly. Once removed, the bulbs are behind quarter turn sockets.
Jun 29, 2009 | 1999 Lincoln Continental
The light bulb needs replacing but..
It would have been really helpful if you could have provided the model number. You can always find it at the back of your freezer. Here are some links to videos which should be useful for you.
Jul 22, 2017 | Refrigerators
BUZZING NOISE ON WHIRLPOOL GOLD FRIDGE/FREEZER
YOU MAY HAVE A BAD LIGHT BULB, SOCKET OR LIGHT SWITCH. TRY WIGGLING THE SWITCH TO SEE IF THERE IS ANY CHANGE IN THE BULB INTENSITY. IF NO CHANGE, TRY REPLACING THE LIGHT BULB. IF NO CHANGE, THE SOCKET NEEDS REPLACED.
Apr 08, 2008 | Refrigerators
Refrigerators Logo
592 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
